查看: 5724|回复: 5
STM8红外程序(外中断接收)
ID:268765 发表于 2017-12-29 11:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
STM8红外程序
  1. #include "stm8s.h"
  2. #include "stm8s003f3p.h"
  3. #include "STM8_IR.h"
  4. #include "STM8_DELAY.h"
  5. #define IR_READ (PC_IDR&(0x01<<7))
  6. volatile uchar Flag_ir_start = 0;//启动标志位
  7. volatile uint IR_time = 0;
  8. volatile unsigned long IR_data;
  9. volatile uchar IR_temp[4];
  10. void LED_Init(void)
  11. {
  12.         PA_DDR |= (0x01<<3);//设置PA3为输出
  13.         PA_CR1 |= (0x01<<3);//设置PA3为推挽输出,速度为2MHz
  14.         PA_CR2 &=(uchar)(~(0x01<<3));
  15.
  16.         PA_ODR &=(uchar)(~(0x01<<3)); //关闭led
  17. }
  18. void TIM1_Init(void)
  19. {
  20.         TIM1_CR1 = 0x00;  //向上的计数方向,中断计数不停
  21.
  22.         TIM1_IER = 0x01;
  23.
  24.         TIM1_PSCRH = 0x00;  //进行16分频
  25.         TIM1_PSCRL = 0x0f;  //16Mhz/(15+1)=1Mhz-->1us
  26.
  27.         TIM1_ARRH = 0x00;
  28.         TIM1_ARRL = 20;   //20us
  29.
  30.         TIM1_CR1 |=0x01;
  31.
  32. }
  33. //外中断接收红外数据
  34. void EXIT_Init(void)
  35. {
  36.         //01是PA,23是PB,45是PC,67是PD引脚
  37.         //P?IS[1:0] 设置触发方式,00是下降沿触发
  38.         EXTI_CR1 &=(uchar)(~(0x03<<4));  // PC下降沿触发
  39.         EXTI_CR1 |= (0x01<<5);
  40. }
  41. void IR_Init(void)
  42. {
  43.
  44.         PC_DDR &=(uchar)(~(0x01<<7));
  45.         PC_CR1 &=(uchar)(~(0x01<<7));
  46.         //PC_CR1 |= (0x01<<7);//上拉输入
  47.         PC_CR2 |= (0x01<<7);//打开外部中断
  48.     EXIT_Init();//RISING and falling EDGE
  49. }
  50. //位反转算法
  51. uchar reverse8( uchar c )
  52. {
  53.      c = ( c & 0x55 ) << 1 | ( c & 0xAA ) >> 1;
  54.      c = ( c & 0x33 ) << 2 | ( c & 0xCC ) >> 2;
  55.      c = ( c & 0x0F ) << 4 | ( c & 0xF0 ) >> 4;
  56.      return c;
  57. }
  58. void IR_rx(void)
  59. {
  60.         static uchar Flag_end=0;
  61.         static uchar IR_num = 0;
  62.
  63.         uchar i,temp;
  64.
  65.         //TIM1_CR1 &=(uchar)(~(0x01<<0));//关闭计数器
  66.
  67.         TIM1_CR1 |= (0x01<<0);  //开启计数器
  68.
  69.         //800us,17000us
  70.         if(IR_time<=40)////杂波
  71.         {
  72.                 IR_data=0;
  73.                 IR_num=0;
  74.                 IR_time=0;
  75.
  76.                 //TIM1_CR1 &=(uchar)(~(0x01<<0));//关闭计数器
  77.
  78.                 return ;
  79.         }
  80.         //13000us
  81.         if(IR_time >= 650)//13ms则启动成功
  82.         {
  83.                 Flag_ir_start = 1;
  84.                 IR_num = 0;
  85.                 IR_data=0;
  86.         }
  87.
  88.         if((Flag_ir_start==1)&&(IR_time<=130))//2600us
  89.         {
  90.
  91.                 IR_data<<=1;
  92.                 if(IR_time>=85)//1700us
  93.                 {
  94.                         IR_data |= (0x01<<0);
  95.                 }
  96.                 IR_num++;
  97.                 if(IR_num>31)
  98.                 {
  99.                         Flag_end = 1;
  100.                         Flag_ir_start=0;
  101.                         IR_time = 0;
  102.                 }
  103.         }
  104.
  105.         if(Flag_end)
  106.         {
  107.                 Flag_end = 0;
  108.
  109.                 TIM1_CR1 &=(uchar)(~(0x01<<0));//关闭计数器
  110.
  111.                 IR_temp[0] = (uchar)((IR_data>>0)&0xff);
  112.                 IR_temp[1] = (uchar)((IR_data>>8)&0xff);
  113.                 IR_temp[2] = (uchar)((IR_data>>16)&0xff);
  114.                 IR_temp[3] = (uchar)((IR_data>>24)&0xff);
  115.
  116.                 IR_data=0;
  117.                 IR_num=0;
  118.
  119.                 if(IR_temp[0]!=(uchar)(~IR_temp[1]))
  120.                 {
  121.                         //校验失败
  122.                         //PA_ODR ^= (0x01<<3);
  123.                 }
  124.                 else
  125.                 {
  126.                         IR_temp[1] = reverse8(IR_temp[1]);//位反转算法
  127.
  128.                         if(IR_temp[1]==0x45)//0xa2
  129.                         {
  130.                                 //PA_ODR ^= (0x01<<3);
  131.                                 PA_ODR |= (0x01<<3);
  132.                         }
  133.                         if(IR_temp[1]==0x46)
  134.                         {
  135.                                 PA_ODR &=(uchar)(~(0x01<<3));
  136.                                 //PA_ODR |= (0x01<<3);
  137.                         }
  138.                         //PA_ODR &=(uchar)(~(0x01<<3));
  139.                 }
  140.
  141.         }
  142.
  143.         IR_time = 0;
  144. }
  145. @far @interrupt void EXTI_PORTC_IRQHandler(void)
  146. {
  147.         IR_rx();
  148. }
  149. //定时器1溢出中断服务
  150. @far @interrupt void timer1_isr(void)   //10us
  151. {
  152.         //TIM1_CR1 &=~(0x01<<0);  //关闭计数器
  153.         TIM1_SR1 &=~(0x01<<0);  //清除中断标志
  154.
  155.         IR_time++;
  156.
  157.     //TIM1_CR1 |= (0x01<<0);  //开启计数器
  158.
  159.         //PA_ODR |= (0x01<<3);
  160.
  161.         //return ;
  162. }
  163. /*
  164. void IR_rx(void)
  165. {
  166.         static uchar Flag_end=0;
  167.         static uchar IR_num = 0;
  168.
  169.
  170.         TIM1_CR1 &=(uchar)(~(0x01<<0));//关闭计数器
  171.
  172.         //800us,17000us
  173.         if(IR_time<=80)////杂波
  174.         {
  175.                 IR_data=0;
  176.                 IR_num=0;
  177.                 IR_time=0;
  178.                 //PA_ODR ^= (0x01<<3);
  179.                 return ;
  180.         }//
  181.         //13000us
  182.         if(IR_time >= 1300)//13ms则启动成功
  183.         {
  184.                 Flag_ir_start = 1;
  185.                 IR_num = 0;
  186.                 IR_data=0;
  187.                 //
  188.                 //PA_ODR |= (0x01<<3);
  189.         }
  190.
  191.         //
  192.         if((Flag_ir_start==1)&&(IR_time<=260))//2600us
  193.         {
  194.
  195.                 IR_data<<=1;
  196.                 if(IR_time>=170)//1700us
  197.                 {
  198.                         IR_data |= (0x01<<0);
  199.                 }
  200.                 IR_num++;
  201.                 if(IR_num>31)
  202.                 {
  203.                         Flag_end = 1;
  204.                         Flag_ir_start=0;
  205.
  206.                         //PA_ODR ^= (0x01<<3);
  207.
  208.                 }
  209.
  210.         }
  211.
  212.         if(Flag_end)
  213.         {
  214.                 Flag_end = 0;
  215.
  216.                 IR_temp[0] = (uchar)((IR_data>>0)&0xff);
  217.                 IR_temp[1] = (uchar)((IR_data>>8)&0xff);
  218.                 IR_temp[2] = (uchar)((IR_data>>16)&0xff);
  219.                 IR_temp[3] = (uchar)((IR_data>>24)&0xff);
  220.
  221.                 IR_data=0;
  222.                 IR_num=0;
  223.
  224.                 if(IR_temp[0]!=(uchar)(~IR_temp[1]))
  225.                 {
  226.
  227.                 }
  228.                 else
  229.                 {
  230.                         //PA_ODR ^= (0x01<<3);
  231.
  232.
  233.                         if(IR_temp[1]==0xa2)
  234.                         {
  235.                                 //PA_ODR ^= (0x01<<3);
  236.                                 PA_ODR |= (0x01<<3);
  237.                         }
  238.                         if(IR_temp[1]<0x7f)
  239.                         {
  240.                                 PA_ODR &=(uchar)(~(0x01<<3));
  241.                                 //PA_ODR |= (0x01<<3);
  242.                         }
  243.                         //PA_ODR &=(uchar)(~(0x01<<3));
  244.                 }
  245.
  246.         }
  247.
  248.         IR_time = 0;
  249.
  250.         TIM1_CR1 |= (0x01<<0);//开计数器
  251. }*/
  1. /********************************************\
  2.                    _ooOoo_
  3.                   o8888888o
  4.                   88" . "88
  5.                   (| -_- |)
  6.                   O\  =  /O
  7.                ____/`---'\____
  8.              .'  \\|     |//  `.
  9.             /  \\|||  :  |||//  \
  10.            /  _||||| -:- |||||-  \
  11.            |   | \\\  -  /// |   |
  12.            | \_|  ''\---/''  |   |
  13.            \  .-\__  `-`  ___/-. /
  14.          ___`. .'  /--.--\  `. . __
  15.       ."" '<  `.___\_<|>_/___.'  >'"".
  16.      | | :  `- \`.;`\ _ /`;.`/ - ` : | |
  17.      \  \ `-.   \_ __\ /__ _/   .-` /  /
  18. ======`-.____`-.___\_____/___.-`____.-'======
  19.                    `=---='
  20. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
  21.         佛祖保佑          永无BUG
  22.
  23.                 楠A407舍长出品
  24.
  25. \********************************************/
  26. #include "stm8s.h"
  27. #include "stm8s003f3p.h"
  28. #include "STM8_IR.h"
  29. #define uchar unsigned char
  30. #define uint  unsigned int
  31. _Bool Flag_ir = 0;
  32. void STM8_CLK_Init(void)
  33. {
  34.
  35.     CLK_HSICmd(ENABLE);//HSI = 16MHz
  36.
  37.     CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //f_psc = 16MHz/1
  38.
  39.
  40. }
  41. //--------------------主函数分割线---------------------
  42. //
  43. //
  44. //-----------------------------------------------------
  45. void main(void)
  46. {
  47.         unsigned char re ;
  48.         unsigned char reg;
  49.
  50.         _asm("sim");//关全部中断
  51.
  52.         STM8_CLK_Init();//内部HSI,16MHz
  53.
  54.         LED_Init();
  55.         IR_Init();
  56.
  57.         TIM1_Init();
  58.
  59.         _asm("rim");//开全部中断
  60.
  61.         while(1)
  62.         {
  63.
  64.                 //IR_test();
  65.
  66.
  67.         }
  68. }
STM8_IR_test.rar (4.02 MB, 下载次数: 79)
收藏收藏3 分享淘帖 顶 踩
ID:373 发表于 2018-4-26 10:42 | 只看该作者
学习下,不知道能不能用上
ID:106794 发表于 2018-7-23 08:55 | 只看该作者
感谢分享
ID:538350 发表于 2019-5-22 15:54 | 只看该作者
楼主程序不对呀
ID:146191 发表于 2019-6-1 15:48 | 只看该作者
Null520 发表于 2019-5-22 15:54
楼主程序不对呀
是不对。。定时器是不是开早了。而且没见到差值或清0 CNTR
ID:439389 发表于 2019-7-9 21:58 | 只看该作者
不错,学习学习!
