查看: 1579|回复: 0
基于NL6221操作EEPROM源码
ID:268839 发表于 2017-12-29 14:14 | 显示全部楼层 |阅读模式
NL6221操作EEPROM源码
  1. /*
  2. * =====================================================================================
  3. *
  4. *       Filename:  eeprom.c
  5. *
  6. *    Description:  EEPROM interface realize interface.
  7. *
  8. *        Version:  0.0.1
  9. *        Created: 08.08 11:09:07
  10. *       Revision:  none
  11. *
  12. *         Author:  Lin Hui (Link), linhui.568@163.com
  13. *   Organization:  Nufront
  14. *
  15. *--------------------------------------------------------------------------------------
  16. * ChangLog:
  17. *  version    Author      Date        Purpose
  18. *  0.0.1      Lin Hui    2014.08.08   Create and realize the interface.
  19. *
  20. * =====================================================================================
  21. */
  22. #include "eeprom.h"
  23. /*
  24. * ===  FUNCTION  ======================================================================
  25. *         Name:  eeprom_data_read
  26. *  Description:  Read eeprom data interface.
  27. *   Parameters:  @addr: eeprom data address.
  28. *                @length: eeprom data length which will be read.
  29. *                @buf: buffer stored eeprom data, it must be large or equel 'length'.
  30. *       Return:  n, return the buffer data read.
  31. *                -1, read eeprom data error.
  32. *         Note:
  33. * =====================================================================================
  34. */
  35. int eeprom_data_read(const int addr, const int length, char * buf)
  36. {
  37.     int i;
  38.     int temp = addr;
  39.
  40.     for (i = 0; i < length; i++) {
  41.         BSP_I2CByteRead(temp++, (unsigned char *)&buf[i]);
  42.     }
  43.
  44.     return i;
  45. }                /* -----  end of function eeprom_data_read  ----- */
  46. /*
  47. * ===  FUNCTION  ======================================================================
  48. *         Name:  eeprom_data_write
  49. *  Description:  write data to eeprom interface.
  50. *   Parameters:  @addr: eeprom data address.
  51. *                @length: eeprom data length which will be read.
  52. *                @buf: buffer stored eeprom data, it must be large or equel 'length'.
  53. *       Return:  n, return data length which had write.
  54. *                -1, write data to eeprom error.
  55. *         Note:
  56. * =====================================================================================
  57. */
  58. int eeprom_data_write(const int addr, const int length, const char * buf)
  59. {
  60.     int i;
  61.     int temp = addr;
  62.     for (i = 0; i < length; i++) {
  63.         BSP_I2CByteWrite(temp++, (unsigned char *)&(buf[i]));
  64.     }
  65.     return i;
  66. }                /* -----  end of function eeprom_data_write  ----- */
  67. //eeprom init
  68. int eeprom_init(void)
  69. {
  70.       BSP_I2CInit(EEPROM_ADDR); //该地址记得要右移一位,比较AT24C02,比如I2C地址为0xA0,,就设置为0x50
  71.           return 0;
  72. }
eeprom i2c.zip (1.51 KB, 下载次数: 6)
