查看: 7378|回复: 7
3D打印机Marin固件 Corexy自动调平固件下载
ID:272634 发表于 2018-1-7 10:42 | 显示全部楼层 |阅读模式
  1. /* -*- c++ -*- */
  2. /*
  3.     Reprap firmware based on Sprinter and grbl.
  4. Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
  5. This program is free software: you can redistribute it and/or modify
  6. it under the terms of the GNU General Public License as published by
  7. the Free Software Foundation, either version 3 of the License, or
  8. (at your option) any later version.
  9. This program is distributed in the hope that it will be useful,
  10. but WITHOUT ANY WARRANTY; without even the implied warranty of
  11. MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  12. GNU General Public License for more details.
  13. You should have received a copy of the GNU General Public License
  14. along with this program.  If not, see <http://www.gnu.org/licenses/>.
  15. */
  16. /*
  17. This firmware is a mashup between Sprinter and grbl.
  18.   (https://github.com/kliment/Sprinter)
  19.   (https://github.com/simen/grbl/tree)
  20. It has preliminary support for Matthew Roberts advance algorithm
  21.     http://reprap.org/pipermail/reprap-dev/2011-May/003323.html
  22. */
  23. /* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */
  24. /* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */
  25. #include "Configuration.h"
  26. #include "pins.h"
  27. #ifdef ULTRA_LCD
  28.   #if defined(LCD_I2C_TYPE_PCF8575)
  29.     #include <Wire.h>
  30.     #include <LiquidCrystal_I2C.h>
  31.   #elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
  32.     #include <Wire.h>
  33.     #include <LiquidTWI2.h>
  34.   #elif defined(DOGLCD)
  35.     #include <U8glib.h> // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/)
  36.   #else
  37.     #include <LiquidCrystal.h> // library for character LCD
  38.   #endif
  39. #endif
  40. #if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
  41. #include <SPI.h>
  42. #endif
  43. #if defined(DIGIPOT_I2C)
  44.   #include <Wire.h>
  45. #endif
Corexy自动调平固件 (自动调平).zip (2.82 MB, 下载次数: 73)
ID:272634 发表于 2018-1-7 10:44 | 显示全部楼层
Marin固件的程序在压缩包里面
ID:138918 发表于 2019-4-30 14:28 | 显示全部楼层
看看 不知道可不可以 拿来参考下
ID:108573 发表于 2020-2-20 09:13 | 显示全部楼层
怎么都是arduino的,有没有STM32的
ID:762137 发表于 2020-5-27 07:27 | 显示全部楼层
学习一下,我虽然是个菜鸟,看着还是挺牛的
ID:778969 发表于 2020-6-14 14:20 | 显示全部楼层
学习一下  第一次完这个结构的打印机
ID:802858 发表于 2020-7-14 00:18 | 显示全部楼层
marin固件太多了
ID:449082 发表于 2020-7-21 16:45 | 显示全部楼层
Arduino:1.8.9 (Windows 7), 开发板:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Error reading file (C:\Program Files (x86)\Arduino\hardware\arduino\avr\boards.txt:0): Invalid line format, should be 'key=value'
为开发板 Arduino/Genuino Mega or Mega 2560 编译时出错。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
这什么原因?
