程序如下,4*4矩阵键盘,语法哪边错了还是,编译不了,编译显示错误error C129: missing ';' before '{'
#include <reg52.h> #define uchar unsigned char; #define uint unsigned int;
sbit led=P2^0; uchar code duan[]{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay50ms() { uchar a,b; for(a=0;a<200;a++) for(b=0;b<250;b++); }
void main() { uchar key_l,key_h; uchar key; led=1; while(1) { P1=0xf0; key_h=P1; if(key_h!=0xf0) { delay50ms(); if(key_h!=0xf0) { key_h=P1; //11100000 key_h=key_h|0x0f; //11101111 P1=key_h; //11101111 key_l=P1; //11100111 key=key_l; // } } switch(key) { case 0xe7:P2=duan[0];break; case 0xd7:P2=duan[1];break; case 0xb7:P2=duan[2];break; case 0x77:P2=duan[3];break; case 0xeb:P2=duan[4];break; case 0xdb:P2=duan[5];break; case 0xbb:P2=duan[6];break; case 0x7b:P2=duan[7];break; case 0xed:P2=duan[8];break; case 0xdd:P2=duan[9];break; case 0xbd:P2=duan[10];break; case 0x7d:P2=duan[11];break; case 0xee:P2=duan[12];break; case 0xde:P2=duan[13];break; case 0xbe:P2=duan[14];break; case 0x7e:P2=duan[15];break; } } }
[此贴子已经被作者于2010-11-14 17:59:31编辑过]
