查看: 4589|回复: 3
单片机热电偶温度表数码管显示量程0-999度源程序
说明:程序是根据串口时序图做的,在时钟高电平期间读取,不是在时钟下降沿读取。手册上举例说明强调时钟下降沿读取,目前网上程序有这二种。
单片机源程序:
  1. #include "reg51.h"
  2. #include "intrins.h" //_nop_();延时函数用
  3. #define  uchar unsigned char        //用uchar代替unsigned char,1字节0-255
  4. #define  uint  unsigned int        //用uint代替nsigned int,2字节0-26653
  5. sfr P3M0=0XB2;
  6. sfr P3M1=0XB1;
  7. sbit SO = P1 ^ 0;        //P1.0口与SO相连
  8. sbit SCK = P1 ^ 1;        //P1.1口与SCK相连
  9. sbit CS = P1 ^ 2;        //P1.2口与CS相连
  10. uint j;
  11. uint wendu;
  12. uint Read_AD();        //AD转换数据数据读取,并返回值
  13. void Display_temp();        //温度显示
  14. uchar qian = 0, bai = 0, shi = 0, ge = 0, xiao = 0;        //初始化LED
  15. uint temp;
  16. uchar code tab_1[10] = { 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90 };        //共阳LED段码表
  17. uchar code tab_2[10] = { 0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78, 0x00, 0x10 };
  18. //含小数点共阳段码 "0"   "1"  "2"  "3"  "4"  "5"  "6"  "7"  "8"  "9"
  19. uchar code tab_3[4] = { 0x01, 0x02, 0x04, 0x08 };        //位码
  20. uint Read_AD()// AD转换数据读取子函数,并返回值
  21. {
  22.         uchar i;
  23.         unsigned int Temp_2;
  24.         Temp_2 = 0;
  25.         CS = 0;
  26.         _nop_();
  27.         for (i = 0; i < 16; i++)        //16位数据读取
  28.         {
  29.                 Temp_2 <<= 1;//向左移一位
  30.                 SCK = 1;//上升沿脉冲
  31.                 _nop_();
  32.                 _nop_();
  33.                 _nop_();
  34.                 if (SO == 1) Temp_2 = Temp_2 | 0x01;
  35.                 SCK = 0;
  36.         }
  37.         CS = 1;
  38.         SCK = 0;
  39.         Temp_2 = Temp_2 & 0x7FF8;        //取3-14位,变换为温度值
  40.         Temp_2 = Temp_2 >>3;
  41.         return (Temp_2);
  42. }
  43. void zhuanhuan()
  44. { uint tempB;
  45.         tempB = (wendu&3)*25;
  46.         wendu=wendu>>2;
  47.         wendu = wendu;
  48.
  49.           if (wendu >= 999)        //最高读取温度设定为999摄氏度
  50.                         wendu=999;
  51.                 bai = wendu / 100;        //取百位数字
  52.                 wendu = wendu % 100;
  53.                 shi = wendu / 10;        //取十位数字
  54.                 wendu = wendu % 10;
  55.                 ge = wendu %10;        //取个位数字
  56.                 xiao = tempB / 10;
  57.
  58. }
  59. void Display_temp()        //温度显示子函数
  60. {
  61.                 P3 = 0x00;
  62.                 P0 = tab_1[bai];
  63.                 P3 = tab_3[0];//显示百位数字
  64.                 for (j = 300; j > 0; j--) ;        //延时
  65.
  66.                 P3 = 0x00;
  67.                 P0 = tab_1[shi];
  68.                 P3 = tab_3[1];//显示十位数字
  69.                 for (j = 300; j > 0; j--) ;
  70.
  71.                 P3 = 0x00;
  72.                 P0 = tab_2[ge];
  73.                 P3 = tab_3[2];        //显示个位数字
  74.                 for (j = 300; j > 0; j--) ;
  75.
  76.                 P3 = 0x00;
  77.                 P0 = tab_1[xiao];
  78.                 P3 = tab_3[3];//显示小数位
  79.                 for (j = 300; j > 0; j--) ;
  80.
  81. }
  82. void main()        //主程序
  83. { unsigned char i;
  84.         P3M0=0X00;
  85.         P3M1=0X0F;
  86.         CS = 1;
  87.         SCK = 0;
  88.         for (j = 300; j > 0; j--) ;
  89.         while (1)
  90.         {
  91.                 wendu = Read_AD();        // 热电偶数据读取,返回温度
  92.                 zhuanhuan();
  93.                 for(i=20;i>0;i--)
  94.                         Display_temp();        //温度显示
  95.         }
  96. }
参与人数 1黑币 +100 收起 理由
admin + 100 共享资料的黑币奖励!
收藏收藏3 分享淘帖 顶 踩
ID:89286 发表于 2018-1-19 20:34 | 只看该作者
thanks for sharing
ID:262356 发表于 2018-1-19 23:13 | 只看该作者
谢谢分享
ID:136090 发表于 2018-3-21 15:29 | 只看该作者
这能能不能用?
