查看: 1700|回复: 0
下面这个程序如何改成红绿灯交替亮?
ID:277738 发表于 2018-1-19 14:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#define uint unsigned int
#define dula P0                //段选信号的锁存器控制
#define wela P2                //位选信号的锁存器控制,这里只用到P2.4-P2.7
sbit beep=P2^3;
unsigned int pp;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar j,k,l=255;
uchar a1,a0;
uchar shijian,deng=2;
void delay(unsigned int i)
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(unsigned char sh_c,unsigned char g_c)
   wela = wela&0x0f;
   dula=table[g_c];
   wela = wela|0x80;
   delay(5);
   wela = wela&0x0f;
   dula=table[sh_c];
   wela = wela|0x40;
   delay(5);
        TMOD=0x01;
        TR0=1;
        TH0=(65536-46080)/256;// 由于晶振为11.0592,故所记次数应为46080,计时器每隔50000微秒发起一次中断。
        TL0=(65536-46080)%256;//46080的来历,为50000*11.0592/12
        ET0=1;
        EA=1;
                if(shijian==0)
                        switch(deng)
                                case 0: shijian=50;                  //红灯
                                                deng=1;
                                                break;
                                case 1: shijian=15;                  //黄灯
                                                deng=2;
                                                break;
                                case 2: shijian=50;                  //绿灯
                                                deng=3;
                                                break;
                                case 3: shijian=15;                  //黄灯
                                                deng=0;
                                                break;
                if(pp==20)
                {        pp=0;
                        shijian--;
                a0=shijian%10;
                a1=shijian/10;
                display(a1,a0);
                switch(deng)
                        case 1: P1=0X00;                         //红灯
                                        break;
                        case 2:                         //黄灯
                                        if(shijian%2==0)
                                        P1=0x00;
                                        if(shijian%2==1)
                                        P1=0xff;
                                        break;
                        case 3:                 //绿灯
                                        if(shijian%2==0)
                                        P1=0x55;
                                        if(shijian%2==1)
                                        P1=0xaa;
                                        break;
                        case 0:        if(shijian%2==0)          //黄灯
                                        P1=0x00;
                                        if(shijian%2==1)
                                        P1=0xff;
                                        break;
void time0() interrupt 1
{        TH0=(65536-46080)/256;
        pp++;
