查看: 1961|回复: 2
为啥这个温度控制不管用
回帖奖励 55 黑币 回复本帖可获得 11 黑币奖励! 每人限 1 次
ID:241873 发表于 2018-2-5 14:17 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit DSPORT=P3^7;
sbit A1=P1^0;
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;}
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}
unsigned char Speed=2;
unsigned        int        DQ;
void Delay1ms(unsigned int y)
        unsigned int x;
        for(y;y>0;y--)
                for(x=110;x>0;x--);
* ???         : Ds18b20Init
* ??                  : ???????1,????0
unsigned char Ds18b20Init()
        unsigned int i;
        DSPORT=0;                         //?????480us~960us
        i=70;
        while(i--);//??642us
        DSPORT=1;                        //??????,??DS18B20???????15us~60us?????
        i=0;
        while(DSPORT)        //??DS18B20????
                i++;
                if(i>5000)//??>5MS
                        return 0;//?????
        return 1;//?????
* ???         : Ds18b20WriteByte
* ????                   : ?18B20??????
* ??           : com
void Ds18b20WriteByte(unsigned char dat)
        unsigned int i,j;
        for(j=0;j<8;j++)
                DSPORT=0;                        //???????????????1us
                i++;
                DSPORT=dat&0x01; //????????,??????
                i=6;
                while(i--); //??68us,??????60us
                DSPORT=1;        //??????,??1us??????????????????
                dat>>=1;
* ???         : Ds18b20ReadByte
* ??           : com
unsigned char Ds18b20ReadByte()
        unsigned char byte,bi;
        unsigned int i,j;
        for(j=8;j>0;j--)
                DSPORT=0;//??????1us
                i++;
                DSPORT=1;//??????
                i++;
                i++;//??6us??????
                bi=DSPORT;         //????,????????
                /*?byte????,??????7???bi,???????????0?*/
                byte=(byte>>1)|(bi<<7);
                i=4;                //???????48us?????????
                while(i--);
        return byte;
* ???         : Ds18b20ChangTemp
* ????                   : ?18b20??????
* ??           : com
void  Ds18b20ChangTemp()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xcc);                //??ROM????
        Ds18b20WriteByte(0x44);            //??????
//        Delay1ms(100);        //??????,???????????,????????
* ???         : Ds18b20ReadTempCom
* ??           : com
void  Ds18b20ReadTempCom()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xbe);         //????????
* ??           : com
int Ds18b20ReadTemp()
        int temp=0;
        unsigned char tmh,tml;
        Ds18b20ChangTemp();                                 //???????
        Ds18b20ReadTempCom();                        //????????????????
        tml=Ds18b20ReadByte();                //??????16?,?????
        tmh=Ds18b20ReadByte();                //?????
        temp=tmh;
        temp<<=8;
        temp|=tml;
        return temp;
void        main()
        unsigned int j,tp,i;
        tp=Ds18b20ReadTemp;
                Coil_OFF;
                        if(tp>570)
                        Coil_A1
     Delay1ms(Speed);
     Coil_AB1
     Delay1ms(Speed);
           Coil_B1
     Delay1ms(Speed);
     Coil_BC1
     Delay1ms(Speed);
           Coil_C1
     Delay1ms(Speed);
     Coil_CD1
     Delay1ms(Speed);
           Coil_D1
     Delay1ms(Speed);
     Coil_DA1
     Delay1ms(Speed);
          for(i=0;i<100;i++)
                        Coil_A1
     Delay1ms(Speed);
     Coil_AB1
     Delay1ms(Speed);
           Coil_B1
     Delay1ms(Speed);
     Coil_BC1
     Delay1ms(Speed);
           Coil_C1
     Delay1ms(Speed);
     Coil_CD1
     Delay1ms(Speed);
           Coil_D1
     Delay1ms(Speed);
     Coil_DA1
     Delay1ms(Speed);
                                Delay1ms(1);
        for(j=0;j<6;j++)
             Coil_OFF;
             Delay1ms(100);
                        Coil_OFF;
                         Delay1ms(100);
