查看: 16195|回复: 10
[原创]P10单元板驱动程序
ID:3271 发表于 2011-1-18 13:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
包含画点、画直线、画矩形、画圆函数等,非常实用。
#include <w78e052.h>
#include <intrins.h>
#include "ASCII.h"
#include"math.h"
#define uint unsigned int
#define NOP     _nop_()
typedef unsigned char u8;
typedef unsigned int  u16;
typedef unsigned char u32;
sbit OE     = P0^2;
sbit A1     = P0^3;
sbit B1     = P0^4;
sbit SHCP=P0^5;    //11脚SHCP    移位时钟
sbit STCP=P0^6;    //12脚STCP    锁存时钟
sbit DATA=P0^7;    //数据输入
sbit BEEP=P1^1;
unsigned char ip,tp,min,sec;
u16 time;
unsigned char PLAYBUF[64];
u8 code yi_dong[31] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,12,11,10,9,8,7,6,5,4,3,2,1,0};
u8 code tab[10] = {"0123456789"};
const uchar code table[160]=
0x10,0x00,0x08,0x0E,0x7F,0x70,0x22,0x40,0x14,0x40,0xFF,0x7E,0x08,0x48,0x08,0x48,
0xFF,0x48,0x08,0x48,0x2C,0x48,0x2A,0x88,0x4A,0x88,0x89,0x08,0x2A,0x08,0x10,0x08,
0x00,0x00,0x00,0x40,0x78,0x40,0x0B,0xF8,0x10,0x48,0x17,0xFE,0x20,0x48,0x7B,0xF8,
0x08,0x40,0x4B,0xFC,0x48,0x40,0x28,0x40,0x17,0xFC,0x28,0x40,0x46,0x40,0x81,0xFE,
 ;  源文件 / 文字 : 工
 ;  宽×高(像素): 15×
 0x00,0x00,0x00,0x00,0x3F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x00,0x00,
 ;  源文件 / 文字 : 作
 ;  宽×高(像素): 15×16
 0x08,0x80,0x0C,0x80,0x09,0x00,0x13,0xFE,0x12,0x80,0x34,0x88,0x50,0xFC,0x90,0x80,
 0x10,0x80,0x10,0x84,0x10,0xFE,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x80,
 ;  源文件 / 文字 : 室
 ;  宽×高(像素): 15×16
 0x00,0x00,0x02,0x00,0x01,0x00,0x3F,0xFE,0x20,0x04,0x40,0x08,0x3F,0xFC,0x04,0x00,
 0x08,0x20,0x1F,0xF0,0x01,0x10,0x01,0x00,0x3F,0xF8,0x01,0x00,0x01,0x00,0xFF,0xFE
//数据串行输入
void serial_input(uchar dat)
 uint m;
 for(m=0;m<8;m++)
  if(dat & 0x80)
   DATA=0;
   DATA=1;
  SHCP=0;
  SHCP=1;
        NOP;
  NOP;
  SHCP=0;
  NOP;
  NOP;
  dat=dat<<1;
void delay()
 unsigned int i = 50000;
 while(i--);
//并出
void serial_output()
 STCP=0;
 STCP=1;
//行显控制
void HC138_scan(uchar temp)
   OE=1;
   A1=0x01 & temp;
   B1=0x01 &(temp>>1);
//整屏显示
void display()
 uint i,j,k;
 unsigned char buf;
 serial_output();
 for(k=0;k<4;k++)              //显示的四行
  for(j=0;j<2;j++)         //显示3、4列
   for(i=0;i<2;i++)      // 显示1、2列
    buf = PLAYBUF[24+(k<<1)+i+(j<<5)];
    serial_input(buf);
    buf = PLAYBUF[16+(k<<1)+i+(j<<5)];
    serial_input(buf);
    buf = PLAYBUF[8+(k<<1)+i+(j<<5)];
    serial_input(buf);
    buf = PLAYBUF[(k<<1)+i+(j<<5)];
    serial_input(buf);
  serial_output();
  HC138_scan(k);
void point(unsigned char x,unsigned char y,bit c)
 unsigned char i;
 if(x>=32) return;
 if(y>=16) return;
 i=0x80;
 i>>=x-((x>>3)<<3);
 if(c)
  PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] |= i;
  PLAYBUF[(y<<1)+((x>>4)<<5)+((x>>3)&0x01)] &= ~i;
//画线
void line(u8  x1, u8  y1, u8  x2, u8  y2, bit color)
 u8  x, y, t;
 if((x1 == x2) && (y1 == y2))
  point(x1, y1, color);
 else if(fabs(y2 - y1) > fabs(x2 - x1))
  if(y1 > y2)
   t = y1;
   y1 = y2;
   y2 = t;
   t = x1;
   x1 = x2;
   x2 = t;
  for(y = y1; y <= y2; y ++)
   x = (y - y1) * (x2 - x1) / (y2 - y1) + x1;
   point(x, y, color);
  if(x1 > x2)
   t = y1;
   y1 = y2;
   y2 = t;
   t = x1;
   x1 = x2;
   x2 = t;
  for(x = x1; x <= x2; x ++)
   y = (x - x1) * (y2 - y1) / (x2 - x1) + y1;
   point(x, y, color);
void rectangle(u8 x1,u8 y1,u8 x2,u8 y2, bit color)
 line(x1,y1,x2,y1, color);
 line(x1,y1,x1,y2, color);
 line(x1,y2,x2,y2, color);
 line(x2,y1,x2,y2, color);
void filled_rectangle(u8 x1,u8 y1,u8 x2,u8 y2, bit color)
 u8 i;
 for(i=y1;i<=y2;i++)
  line(x1,i,x2,i, color);
//在指定位置画一个指定大小的圆
//(x,y):中心点
//r    :半径
void circle(u8 x0,u8 y0,u8 r, bit color)
 int a,b;
 int di;
 a=0;
 b=r;
 di=3-2*r;             //判断下个点位置的标志
 while(a<=b)
  point(x0-b,y0-a, color);             //3
  point(x0+b,y0-a, color);             //0
  point(x0-a,y0+b, color);             //1
  point(x0-b,y0-a, color);             //7
  point(x0-a,y0-b, color);             //2
  point(x0+b,y0+a, color);             //4
  point(x0+a,y0-b, color);             //5
  point(x0+a,y0+b, color);             //6
  point(x0-b,y0+a, color);
  a++;
  /***使用Bresenham算法画圆**/
  if(di<0)di +=4*a+6;
   di+=10+4*(a-b);
   b--;
void load_playbuff(unsigned char *p)
 unsigned char i;
 for(i=0;i<64;i++)
  PLAYBUF = *p++;
void clear_playbuff(unsigned char n)
 unsigned char i;
 for(i=0;i<64;i++)
  PLAYBUF = n;
unsigned char op;
void put_char(u8 x,u8 y,u8 c,bit color)
  unsigned char tmp_char=0,i,j;
  for (i=0;i<16;i++)
    tmp_char=AsciiLib[((c-0x20)*16)+i];
    for (j=0;j<8;j++)
      if ( (tmp_char >> 7-j) & 0x01 == 0x01)
        point(x+j,y+i,color); // 字符颜色
        point(x+j,y+i,!color); // 背景颜色
void put_chinese(u8 x,u8 y,u8 *c,bit color)
 u8 i=0;
 u8 j=0;
 u8 tmp_char=0;
 u8 tmp_char2=0;
  for (i=0;i<16;i++)
    tmp_char=c[i*2];
 tmp_char2=c[i*2+1];
    for (j=0;j<8;j++)
   if ( (tmp_char2 >> 7-j) & 0x01 == 0x01)
        point(x+j+8,y+i,color); // 字符颜色
        point(x+j+8,y+i,!color); // 背景颜色
void display_move(unsigned int c)
 unsigned char i;
 for(i=0;i<16;i++)
  PLAYBUF[i*2] = (PLAYBUF[i*2]<<1)+(PLAYBUF[i*2+1]>>7);
  PLAYBUF[i*2+1] = (PLAYBUF[i*2+1]<<1)+(PLAYBUF[i*2+32]>>7);
  PLAYBUF[i*2+32] = (PLAYBUF[i*2+32]<<1)+(PLAYBUF[i*2+1+32]>>7);
  PLAYBUF[i*2+32+1] = (PLAYBUF[i*2+32+1]<<1)+((c>>i)&0x01);
 unsigned int i=1000;
 BEEP=0;
 P0=0x00;
 TMOD = 0x1;
 TH0=0xfc;
  TL0=0x18;//12Mhz
 ET0 = 1;
 TR0 = 1;
 EA = 1;
 min=0;
 sec=0;
 time=0;
 rectangle(0,0,31,15,1);
 circle(15,8,4,1);
 while(i--)
  display();
 //load_playbuff(&table[2*32]);
 put_char(0,0,tab[min/10%10],1);
 put_char(8,0,tab[min%10],1);
 point(15,6,1);
 point(15,9,1);
 point(16,6,1);
 point(16,9,1);
 put_char(16,0,tab[sec/10%10],1);
 put_char(24,0,tab[sec%10],1);
  display();
  if(time>=1000)
  time=0;
  sec++;
  if(sec>=60)
   sec=0;
   min++;
   if(min>=60)
    min=0;
  point(15,5,1);
  point(15,10,1);
  point(16,5,1);
  point(16,10,1);
  point(15,6,1);
  point(15,9,1);
  point(16,6,1);
  point(16,9,1);
/*******************************定时器中断**************************/
void OSInterrupt(void) interrupt 1
    TMOD=0x1;
 TH0=0xfc;
  TL0=0x18;//12Mhz,1ms_delay
 time++;
/*******************************结束********************************/
收藏收藏3 分享淘帖 顶1 踩
ID:76053 发表于 2015-4-3 16:10 | 只看该作者
楼主,你移动显示怎么写的啊?
ID:55154 发表于 2015-11-1 00:02 | 只看该作者
楼主,你的是什么单片机咯?
ID:44685 发表于 2015-11-3 00:29 来自手机 | 只看该作者
赞,我找了好久了。谢谢楼主。
ID:67453 发表于 2018-8-31 21:46 | 只看该作者
初学 者参考资料
ID:393255 发表于 2018-9-10 05:45 | 只看该作者
看了楼主的源码学到很多,感谢。
ID:68189 发表于 2018-10-12 11:24 | 只看该作者
ASCII.h 文件内容呢〈〉?
ID:275852 发表于 2019-6-28 06:47 | 只看该作者
void display_move(unsigned int c),main函数没用到
ID:82944 发表于 2022-3-23 21:44 | 只看该作者
看了楼主的源码学到很多,感谢。
ID:140644 发表于 2022-3-30 14:19 | 只看该作者
当初我试了读高通字库移动显示P10单元板
