DHT11温湿度检测程序
arduino单片机源程序如下:
- #include "dht.h"
- #define TIMEOUT 10000
- #define pin D2
- // return values:
- // 0 : OK
- // -1 : checksum error
- // -2 : timeout
- int dht::read11()
- // READ VALUES
- int rv = read();
- if (rv != 0) return rv;
- // CONVERT AND STORE
- humidity = bits[0]; // bit[1] == 0;
- temperature = bits[2]; // bits[3] == 0;
- // TEST CHECKSUM
- uint8_t sum = bits[0] + bits[2]; // bits[1] && bits[3] both 0
- if (bits[4] != sum) return -1;
- return 0;
- // return values:
- // 0 : OK
- // -2 : timeout
- int dht::read22()
- // READ VALUES
- int rv = read();
- humidity = word(bits[0], bits[1]) * 0.1;
- int sign = 1;
- if (bits[2] & 0x80) // negative temperature
- bits[2] = bits[2] & 0x7F;
- sign = -1;
- temperature = sign * word(bits[2], bits[3]) * 0.1;
- // TEST CHECKSUM
- uint8_t sum = bits[0] + bits[1] + bits[2] + bits[3];
- return 0;
- // return values:
- // 0 : OK
- // -2 : timeout
- int dht::read()
- // INIT BUFFERVAR TO RECEIVE DATA
- uint8_t cnt = 7;
- uint8_t idx = 0;
- // EMPTY BUFFER
- for (int i=0; i< 5; i++) bits[i] = 0;
- // REQUEST SAMPLE
- pinMode(pin, OUTPUT);
- digitalWrite(pin, LOW);
- delay(20);
- digitalWrite(pin, HIGH);
- delayMicroseconds(40);
- pinMode(pin, INPUT);
- // GET ACKNOWLEDGE or TIMEOUT
- unsigned int loopCnt = TIMEOUT;
- while(digitalRead(pin) == LOW)
- if (loopCnt-- == 0) return -2;
- loopCnt = TIMEOUT;
- while(digitalRead(pin) == HIGH)
- // READ THE OUTPUT - 40 BITS => 5 BYTES
- for (int i=0; i<40; i++)
- unsigned long t = micros();
temperature.rar
(1.77 KB, 下载次数: 23)
