查看: 2492|回复: 3
这个单片机程序怎么改可以解决每次按键按下,数码管都闪一下 求大佬看看
回帖奖励 5 黑币 回复本帖可获得 5 黑币奖励! 每人限 1 次
ID:287703 发表于 2018-4-14 14:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. sbit feng =P1^2;             //蜂鸣器
  2. sbit P3_2 =P1^4;             //11
  3. sbit P3_3 =P1^3;             //14
  4. sbit P3_4 =P1^5;             //12
  5. sbit P2_1 =P2^1;             //jia
  6. sbit P2_2 =P2^2;             //jian
  7. sbit P2_3 =P2^3;                 //qdjia
  8. sbit P2_4 =P2^4;                  //qdjian
  9. sbit P2_5 =P2^5;                 //kai
  10. sbit P2_6 =P3^3;                 //kai DENG
  11. bit Light_look=1;        //光源关断标志
  12. unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  13. unsigned char code segbit[]={0x08,0x04,0x02,0x01};
  14. unsigned char  disbuf[4]={0,0,0,0};
  15. //数据传输//
  16. void sdata(void)
  17. {unsigned char b,c,num;
  18.          if(b==0)
  19.         {
  20.           b++;
  21.          num=segbit[m];
  22.           for(c=0;c<8;c++)
  23.                   {P3_2=0;
  24.                    P3_3=num&0x80;
  25.                    num<<=1;
  26.                    P3_2=1;
  27.            }
  28.         }
  29.         if(b==1)
  30.         {
  31.             b--;
  32.                 if(m==2)
  33.                 {
  34.                 num=fseg[disbuf[m]]|0x80;
  35.                 }
  36.                 else
  37.                 {
  38.         num=fseg[disbuf[m]];
  39.                 }
  40.                  for(c=0;c<8;c++)
  41.                    {  P3_2=0;
  42.                          P3_3=num&0x80;
  43.                          num<<=1;
  44.                          P3_2=1;
  45.                    }
  46.
  47.         }
  48.              m++;
  49.              if(m==4)
  50.                  {m=0;
  51.                      }
  52. }
  53. //延时0.1ms个单位//
  54. void delay (unsigned char h)
  55.   {
  56.     while(h--);
  57.   }
  58. //数据输出//
  59. void out(void)
  60. {
  61.   P3_4=0;
  62.   delay(500);
  63.   P3_4=1;
  64. }
  65. void display(void)
  66. {
  67.     disbuf[0]=qd%10;
  68.         disbuf[1]=qd/10;
  69.         disbuf[2]=minute%10;
  70.         disbuf[3]=minute/10;
  71. }
  72.   //按键控制//
  73. void bcon(void)
  74.    {
  75.         if(P2_1==0)
  76.      {delay(25);
  77.            if(P2_1==0)
  78.             {
  79.                   minute++;
  80.            feng=0;
  81.                   while(!P2_1);
  82.                    feng=1;
  83.                   if(minute>30)
  84.                    {
  85.                    minute=1;
  86.                    }
  87.                 }
  88.          }
  89.          if(P2_2==0)
  90.      {delay(25);
  91.            if(P2_2==0)
  92.             {
  93.                   minute--;
  94.                   feng=0;
  95.                   while(!P2_2);
  96.            feng=1;
  97.                   if(minute==0)
  98.                    {
  99.                    minute=30;
  100.                    }
  101.                 }
  102.          }
  103.           if(P2_3==0)
  104.      {delay(25);
  105.            if(P2_3==0)
  106.             {
  107.                   qd++;
  108.                   feng=0;
  109.                   while(!P2_3);
  110.            feng=1;
  111.                   if(qd>3)
  112.                    {
  113.                    qd=1;
  114.                    }
  115.                 }
  116.          }
  117.          if(P2_4==0)
  118.      {delay(25);
  119.            if(P2_4==0)
  120.             {
  121.                   qd--;
  122.                   feng=0;
  123.                   while(!P2_4);
  124.            feng=1;
  125.                   if(qd==0)
  126.                    {
  127.                      qd=3;
  128.                    }
  129.                 }
  130.          }
  131.          if(P2_5==0)
  132.      {delay(25);
  133.            if(P2_5==0)
  134.             {
  135.           TR0=1;
  136.                   z=qd;
  137.                   P2_6=0;
  138.                   voice_time_cnt=cnt_voice_time1;
  139.                   while(!P2_5);
  140.                 }
  141.          }
  142. }
  143.   //主函数//
  144. void main(void)
  145. {
  146.   TMOD=0x02;
  147.   TH0=0x06;
  148.   TL0=0x06;
  149.   ET0=1;
  150.   EA=1;
  151.   P2_6=1;
  152.   feng=1;
  153.   Init_PWM1();
  154.   CCAP1L=CCAP1H=0;
  155.   Light_look=1;
  156.   while(1)
  157.   {
  158.    switch(z)
  159.   {          case 0:CCAP1L=CCAP1H=0; break;
  160.           case 1:CCAP1L=CCAP1H=132;break;
  161.           case 2:CCAP1L=CCAP1H=134; break;
  162.           case 3:CCAP1L=CCAP1H=160;break;
  163.   }
  164.    display();
  165.    sdata();
  166.    out();
  167.   }
  168. }
  169. //中断程序//
  170. void t0(void) interrupt 1 using 0
  171.   {
  172.         bcon();         //按键扫描函数
  173.         if(voice_time_cnt)  //控制蜂鸣器声音的长短
  174.         {
  175.                 feng=0;         //蜂鸣器响
  176.                 --voice_time_cnt;    //蜂鸣器响的声音长短的计数延时
  177.         }
  178.         else
  179.         {
  180.                 feng=1;      //蜂鸣器停止
  181.         }
  182.     tcount++;
  183.     if(tcount==4000)
  184.           {
  185.             tcount=0;
  186.                 second++;
  187.                 if(second==60)
  188.         {
  189.           second=0;
  190.               minute--;
  191.         }
  192.      }
  193.         if(minute==1&&second==59)
  194.          {
  195.            feng=0;
  196.          }
  197.         if(minute==0)
  198.   {
  199.         feng=1;
  200.     TR0=0;
  201.     minute=0;
  202.         qd=0;
  203.         z=0;
  204.         P2_6=1;
  205.   }
  206. }
收藏收藏1 分享淘帖 顶 踩
ID:213173 发表于 2018-4-14 21:13 | 只看该作者
这种原始的按键程序当然会干扰其它程序运行。给你一个例程参考。
//8位数码管时钟+闹钟
//K1键调整选择,K2键+,长按连+,K3键-,长按连-,K4键闹钟设置
//定时器初始化程序根据晶振频率选择
//用计数法代替软件延时,消除按键干扰其它程序
//数码管采用分时动态显示,2ms显示1位
#include <reg51.h>
#define uint unsigned int
#define key_S 300                                                //宏定义短按(约20ms)
#define key_L 6000                                        //宏定义长按(约2/3s)
#define key_M 3000                                        //宏定义长按(约1/3s)
sbit K1 = P3^0;                                                //时钟调整选择/退出
sbit K2 = P3^1;                                                //++,长按连+
sbit K3 = P3^2;                                                //--,长按连-
sbit K4 = P3^3;                                                //闹钟调整选择/退出
sbit Buzzer=P2^5;                                                //蜂鸣器
sbit led138c=P2^4;                                        //38译码器位选
sbit led138b=P2^3;                                         //38译码器位选
sbit led138a=P2^2;                                        //38译码器位选
uchar code table[]={                                        //0~F数组
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71};
uint Cnt2ms;                                                        //定义2ms秒变量
uchar hour=0,min=0,sec=0;                        //定义时、分、秒变量
uchar hour_1=0,min_1=0;                                //定义闹钟时、分变量
uchar  Choice=0,Choice_1=0;                //调整走时的选择变量、设置闹钟的选择变量
bit Buzzer_sign;                                                //蜂鸣器闹钟标志
bit Twinkle,second=1;                                //闪烁标志、秒标志
bit flag=0;        //2ms数码管动态显示标志
        定时器T0/T1初始化程序 @12MHz
void Timer_Init()
        TMOD = 0x21;                                        //设置T0模式1,T1模式2
        TL0 = 0x30;                                                //设置定时初值2ms
        TH0 = 0xF8;                                                //设置定时初值2ms
        TL1 = 0x06;                                                //设置定时初值250微秒
        TH1 = 0x06;                                                //设置定时重载值250微秒
        TR0 = 1;                                                        //定时器0开始计时
//        TR1 = 1;                                                        //定时器1开始计时
        EA=1;        //开总中断
        ET0=1;                                                        //开定时器1中断
        ET1=1;                                                        //开定时器1中断
        定时器T0/T1初始化程序 @11.0592MHz
void Timer_Init()
        TL0 = 0xCD;                                                //设置定时初值2ms
        TL1 = 0x1A;                                                //设置定时初值250微秒
        TH1 = 0x1A;                                                //设置定时重载值250微秒
        TR0 = 1;                                                        //定时器0开始计时
        EA=1;        //开总中断
        ET0=1;                                                        //开定时器1中断
        ET1=1;                                                        //开定时器1中断
          按键扫描程序
void key_scan()
        static bit key1_sign,key4_sign;                        //按键自锁标志变量
        static uint count1,count2,count3=0,count4=0;//消抖计数变量
        if(!K1)                                                        //检测按键1按下
                count1++;                                        //消抖计数1自+1
                if((count1>=key_S)&&(key1_sign==0))//检测消抖计数与按键1自锁标志
                        key1_sign=1;                        //按键1自锁标志置1
                        Choice++;                                //调整选择变量自+1
                        if(Choice>=4)                        //调整时间选择0正常走时,1调时,2调分,3调秒
                                Choice=0;                        //调整时间选择清0
                                Cnt2ms=0;                        //时间变量Cnt2ms清0
                key1_sign=0;                                //按键1自锁标志清0
                count1=0;                                        //消抖计数count1清0
        if(!K2)
                count2++;
                if(count2>=key_L)                        //长按快调
                        if(Choice==1)                        //选择变量1调时
                                hour++;
                                if(hour>=24)
                                        hour=0;
                        if(Choice==2)                        //选择变量2调分
                                min++;
                                if(min>=60)
                                        min=0;
                        if(Choice==3)                        //选择变量3调秒
                                sec++;
                                if(sec>=60)
                                        sec=0;
                        if(Choice_1==1)                        //选择变量1调时
                                hour_1++;
                                if(hour_1>=24)
                                        hour_1=0;
                        if(Choice_1==2)                        //选择变量2调分
                                min_1++;
                                if(min_1>=60)
                                        min_1=0;
                        count2=key_M;
        else                                                        //按键抬起
                if(count2>key_S && count2<key_L)//短按
                                hour++;
                                if(hour>=24)
                                        hour=0;
                                min++;
                                if(min>=60)
                                        min=0;
                                sec++;
                                if(sec>=60)
                                        sec=0;
                                hour_1++;
                                if(hour_1>=24)
                                        hour_1=0;
                                min_1++;
                                if(min_1>=60)
                                        min_1=0;
                count2=0;                                        //count2清0
        if(!K3)
                count3++;
                if(count3>=key_L)                        //长按
                                hour--;
                                if(hour>=24)
                                        hour=23;
                                min--;
                                if(min>=60)
                                        min=59;
                                sec--;
                                if(sec>=60)
                                        sec=59;
                                hour_1--;
                                if(hour_1>=24)
                                        hour_1=23;
                                min_1--;
                                if(min_1>=60)
                                        min_1=59;
                        count3=key_M;
        else                                                        //按键抬起
                if(count3>key_S && count3<key_L)//短按
                                hour--;
                                if(hour>=24)
                                        hour=23;
                                min--;
                                if(min>=60)
                                        min=59;
                                sec--;
                                if(sec>=60)
                                        sec=59;
                                hour_1--;
                                if(hour_1>=24)
                                        hour_1=23;
                                min_1--;
                                if(min_1>=60)
                                        min_1=59;
                count3=0;                                        //count3清0
        if(!K4)                                                        //检测按键1按下
                count4++;                                        //消抖计数1自+1
                if((count4>=key_S)&&(key4_sign==0))//检测消抖计数与按键1自锁标志
                        key4_sign=1;                        //按键1自锁标志置1
                        Choice_1++;                                //调整选择变量自+1
                        if(Choice_1>=4)                        //调整闹钟时间选择0闹钟关闭,1调时,2调分,3开启闹钟
                                Choice_1=0;                        //调整时间选择清0
                key4_sign=0;                                //按键1自锁标志清0
                count4=0;                                        //消抖计数count1清0
                数码管显示程序
void display()
        static uchar num=0;                                //分时显示变量
        if(flag==1)
                flag=0;
                if((Choice_1>0)&&(Choice_1<3))//闹钟设置显示部分
                        switch(num)
                                case 0:
                                        P0=0x00;        //消隐
                                        led138a=0;led138b=0;led138c=0;//时十位位码
                                        P0=table[hour_1/10];        //时十位段码
                                        num++;
                                 break;
                                case 1:
                                        P0=0x00;        //消隐
                                        led138a=1;led138b=0;led138c=0;//时个位位码
                                        if((Twinkle==1)&&(Choice_1==1))//时点闪烁
                                                P0=table[hour_1%10]|0x80;
                                                P0=table[hour_1%10];//时个位段码+点
                                        num++;
                                 break;
                                case 2:
                                        P0=0x00;        //消隐
                                        led138a=0;led138b=1;led138c=0;//-
                                        P0=0x40;        //-
                                        num++;
                                 break;
                                case 3:
                                        P0=0x00;        //消隐
                                        led138a=1;led138b=1;led138c=0;//分十位位码
                                        P0=table[min_1/10];        //分十位段码
                                        num++;
                                 break;
                                case 4:
                                        P0=0x00;        //消隐
                                        led138a=0;led138b=0;led138c=1;//分个位位码
                                        if((Twinkle==1)&&(Choice_1==2))//分点闪烁
                                                P0=table[min_1%10]|0x80;
                                                P0=table[min_1%10];//分个位段码+点
                                        num++;
                                 break;
                                case 5:
                                        P0=0x00;        //消隐
                                        led138a=1;led138b=0;led138c=1;//-
                                        P0=0x40;        //-
                                        num++;
                                 break;
                                case 6:
                                        P0=0x00;        //消隐
                                        led138a=0;led138b=1;led138c=1;//秒十位位码
                                        P0=0x40;        //秒十位段码
                                        num++;
                                 break;
                                case 7:
                                        P0=0x00;        //消隐
                                        led138a=1;led138b=1;led138c=1;//秒个位位码
                                        P0=0x40;//秒个位段码
                                        num=0;
                                 break;
                else        //正常走时显示部分
                        switch(num)
                                case 0:
                                        P0=0x00;        //消隐
                                        P0=table[hour/10];        //时十位段码
                                        num++;
                                 break;
                                case 1:
                                        P0=0x00;        //消隐
                                        if((Twinkle==1)&&(Choice==1))//时点闪烁
                                                P0=table[hour%10]|0x80;
                                                P0=table[hour%10];//时个位段码+点
                                        num++;
                                 break;
                                case 2:
                                        P0=0x00;        //消隐
                                        P0=0x40;        //-
                                        num++;
                                 break;
                                case 3:
                                        P0=0x00;        //消隐
                                        P0=table[min/10];        //分十位段码
                                        num++;
                                 break;
                                case 4:
                                        P0=0x00;        //消隐
                                        if((Twinkle==1)&&(Choice==2))//分点闪烁
                                                P0=table[min%10]|0x80;
                                                P0=table[min%10];//分个位段码+点
                                        num++;
                                 break;
                                case 5:
                                        P0=0x00;        //消隐
                                        P0=0x40;        //-
                                        num++;
                                 break;
                                case 6:
                                        P0=0x00;        //消隐
                                        P0=table[sec/10];        //秒十位段码
                                        num++;
                                 break;
                                case 7:
                                        P0=0x00;        //消隐
                                        if(Choice_1==3)
                                                P0=table[sec%10]|0x80;//闹钟启动后秒个位+点
                                        else if((Twinkle==1)&&(Choice==3))//秒点闪烁+点
                                                P0=table[sec%10];//秒个位段码
                                        num=0;
                                 break;
                闹钟程序
void Buzzer_nz()
        if((Choice_1==3)&&(hour_1==hour)&&(min_1==min)&&(sec<30))
                Buzzer_sign=1;
        else Buzzer_sign=0;
        if((second==1)&&(Buzzer_sign==1))        //计时周期1s
                TR1 = 1;                                        //定时器1开,蜂鸣器响一下
                second=0;                                        //定时周期1s变量清0
                主程序
void main(void)
        Timer_Init();                                        //初始化定时器
                key_scan();                                        //按键扫描
                display();                                        //显示
                Buzzer_nz();                                //闹钟
  定时器0中断服务程序  200微秒
void timer0() interrupt        1
        Cnt2ms++;                                        //时间变量Cnt2ms自+1
                flag=1;
        if((Cnt2ms>125 && Cnt2ms<250)||(Cnt2ms>375 && Cnt2ms<500))//闪烁频率2Hz
                Twinkle=1;                                //闪烁标志
        else Twinkle=0;
        if(Cnt2ms>=500)                    //在此可以调整精度
                Cnt2ms=0;                                //变量Cnt2ms清0
                second=1;
                if(Choice!=3)                        //调整选择变量为3停止走秒
                        sec++;                                //秒自+1
                if(sec>=60)                                //如果秒>=60
                        sec=0;                                //秒清0
                        min++;                                //分自+1
                        if(min>=60)                        //分>=60
                                min=0;                        //分清0
                                hour++;                  //小时自+1
                                if(hour>=24)        //小时>=24
                                        hour=0;                //小时清0
  定时器1中断服务程序  250微秒
  (无源蜂鸣器驱动程序)
void timer1() interrupt 3
        static uint count3=0;                        //中断计数变量
        count3++;                                                //中断计数变量count3自+1
        Buzzer=~Buzzer;                                        //蜂鸣器端口取反
        if(count3>=500)                                        //0.1秒时间到500
                count3=0;                                        //计数清0
                Buzzer=1;                                        //蜂鸣器端口清0
                TR1 = 0;                                                //定时器1关闭
ID:287703 发表于 2018-4-16 11:01 | 只看该作者
//8位数码管时钟+闹钟
//K1键调整选择,K ...
谢谢大佬的指点,
ID:308778 发表于 2018-4-16 20:56 | 只看该作者
是不是按键中断处理耗时过长?怎么解决的?
