第一次在论坛发帖,比较紧张,条理有点乱,请大家见谅!
电路图和程序摘自STC官网,这样的驱动方式只要占用3个单片机IO口却能驱动8位数码管,还是很方便的,中午在家里用仿真软件仿真,确实可行。现将电路图和程序奉上。
C程序代码:
- /* --- STC MCU International Limited -------------------------------*/
- /* --- STC 1T Series MCU Programme Demo ----------------------------*/
- /* --- Fax: 86-755-82944243 ----------------------------------------*/
- /* --- Tel: 86-755-82948412 ----------------------------------------*/
- /* If you want to use the program or the program referenced in the */
- /* article, please specify in which data and procedures from STC */
- /* 本程序经过测试完全正常, 不提供电话技术支持, 如不能理解, 请自行补充相关基础. */
- /************* 本程序功能说明 **************
- 用STC的MCU的IO方式控制74HC595驱动8位数码管。
- 用户可以修改宏来选择时钟频率.
- 用户可以在显示函数里修改成共阴或共阳.推荐尽量使用共阴数码管.
- 显示效果为: 8个数码管循环显示0,1,2...,A,B..F,消隐.
- #include "reg52.h"
- /****************************** 用户定义宏 ***********************************/
- #define MAIN_Fosc 11059200UL //定义主时钟
- //#define MAIN_Fosc 22118400UL //定义时钟
- /******************** 下面的宏自动生成, 用户不可修改 **************************/
- #define Timer0_Reload (MAIN_Fosc / 12000)
- /************* 本地常量声明 **************/
- unsigned char code t_display[]={
- // 0 1 2 3 4 5 6 7 8 9 A B C D E F 消隐
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,0x00}; //段码
- unsigned char code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位码
- /************* 本地变量声明 **************/
- //sbit P_HC595_SER = P3^2; //pin 14 SER data input
- //sbit P_HC595_RCLK = P3^4; //pin 12 RCLk store (latch) clock
- //sbit P_HC595_SRCLK = P3^3; //pin 11 SRCLK Shift data clock
- sbit P_HC595_SER = P1^5; //pin 14 SER data input
- sbit P_HC595_RCLK = P1^4; //pin 12 RCLk store (latch) clock
- sbit P_HC595_SRCLK = P1^7; //pin 11 SRCLK Shift data clock
- unsigned char LED8[8]; //显示缓冲
- unsigned char display_index; //显示位索引
- bit B_1ms; //1ms标志
- void main(void)
- unsigned char i,k;
- unsigned int j;
- TMOD = 0x01; //Timer 0 config as 16bit timer, 12T
- TH0 = (65536 - Timer0_Reload) / 256;
- TL0 = (65536 - Timer0_Reload) % 256;
- ET0 = 1;
- TR0 = 1;
- EA = 1;
- for(i=0; i<8; i++) LED8[i] = 0x10; //上电消隐
- j = 0;
- k = 0;
- // for(i=0; i<8; i++) LED8[i] = i;
- while(1)
- while(!B_1ms) ; //等待1ms到
- B_1ms = 0;
- if(++j >= 500) //500ms到
- j = 0;
- for(i=0; i<8; i++) LED8[i] = k; //刷新显示
- if(++k > 0x10) k = 0; //8个数码管循环显示0,1,2...,A,B..F,消隐.
- void Send_595(unsigned char dat) //发送一个字节
- unsigned char i;
- if(dat & 0x80) P_HC595_SER = 1;
- else P_HC595_SER = 0;
- P_HC595_SRCLK = 1;
- P_HC595_SRCLK = 0;
- dat = dat << 1;
- void DisplayScan(void) //显示扫描函数
- // Send_595(~T_COM[display_index]); //共阴 输出位码
- // Send_595(t_display[LED8[display_index]]); //共阴 输出段码
- Send_595(T_COM[display_index]); //共阳 输出位码
- Send_595(~t_display[LED8[display_index]]); //共阳 输出段码
- P_HC595_RCLK = 1;
- P_HC595_RCLK = 0; //锁存输出数据
- if(++display_index >= 8) display_index = 0; //8位结束回0
- void timer0 (void) interrupt 1 //Timer0 1ms中断函数
- TH0 = (65536 - Timer0_Reload) / 256; //重装定时值
- DisplayScan(); //1ms扫描显示一位
- B_1ms = 1; //1ms标志
全部资料51hei下载地址:
HC595驱动8个数码管.zip
(53.16 KB, 下载次数: 263)
