电子密码锁仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
资料包:
密码锁的单片机源程序如下:
- 1.按键说明: 按键K1~K3为数字"1~3",K5~K7为数字"4~6",K9~K11为数字"7~9",
- K13为"0",K14为设置键,K15为取消键,K16为回车键.
- 2.程序说明: 按数字键输入正确密码,回车确定.LED亮.否则5次错误,蜂鸣器响.按键暂时失效.
- 按设置键进入修改密码,先输入旧密码,再输入两次新密码,回车确定.
- 关电后密码自动保存.
- 3.使用说明: 先找到程序中"E2Read(num0,0x05,sizeof(num0));"语句屏蔽后下载到单片机,
- 操作一次密码设置(初始密码为"0"),以清除EEPROM内原有数据,关电.解除屏蔽再下载. **********/
- #include "Lcd1602.h"
- #include "Key.h"
- #include "Eeprom.h"
- bit BeedOn = 0; //蜂鸣器标志
- bit set = 0; //设置标志
- bit On = 0; //密码打开标志
- bit clag = 0; //清除输入指针标志
- uchar Paserror = 0; //密码错误次数
- uchar Passcou = 0; //更改密码引索
- uchar T0RH=0,T0RL=0;
- uchar num0[8],num1[8],num2[8];
- void ConfigTime0(uchar ms);
- void main()
- EA = 1;
- ConfigTime0(2);
- Lcd1602Init();
- E2Read(num0,0x05,sizeof(num0));
- LcdShowStr(0,0,"Please input...");
- while(1)
- KeyDriver();
- void InCoumNum(uchar *buf,uchar n) //输入数据
- static uchar i;
- if (clag)
- i = 0;
- clag = 0;
- if (i < 8)
- buf[i] = n;
- i++;
- LcdShowStr(16-i,1,"*");
- else
- i = 0;
- bit ContNum(uchar *dat1,uchar *dat2) //对比数据
- uchar i;
- for (i=0;i<8;i++)
- if (*dat1++ != *dat2++)
- return 0;
- return 1;
- void ClsNum(uchar *dat) //清除数据
- uchar i;
- for (i=0;i<8;i++)
- *dat++ = 0;
- void CopyNum(uchar *dat1,uchar *dat2) //复制数据
- uchar i;
- for (i=0;i<8;i++)
- *dat1++ = *dat2++;
- void PasErrCou() //密码错误次数显示
- uchar str[1];
- Paserror++;
- str[0] = Paserror+'0';
- LcdShowStr(0,1,"ERROR");
- LcdShowStr(6,1,str);
- if (Paserror >= 5)
- BeedOn = 1;
- void SetPass()
- if (!On && !set)
- LcdClsFull();
- LcdShowStr(0,0,"Set the Passwor");
- set = 1;
- void Esc() //复位
- Passcou = 0;
- On = 0;
- set = 0;
- BeedOn = 0;
- Pout = 1;
- clag = 1;
- ClsNum(num1);
- ClsNum(num2);
- void Enter()
- if (!set)
- if (!ContNum(num1,num0))
- ClsNum(num1);
- LcdClsStr(0,1,16);
- PasErrCou();
- else
- LcdClsFull();
- LcdShowStr(0,0,"Welcome to use!");
- LcdShowStr(0,1,"Turn ON");
- ClsNum(num1);
- Paserror =0;
- Pout = 0;
- On = 1;
- else
- switch (Passcou)
- case 0: if (ContNum(num1,num0)) //密码输入正确
- LcdClsFull();
- LcdShowStr(0,0,"Enter the new");
- ClsNum(num1);
- Passcou = 1;
- else //密码输入错误清除输入数
- ClsNum(num1);
- PasErrCou();
- break;
- case 1: LcdClsFull();
- LcdShowStr(0,0,"Enter new too");
- Passcou = 2;
- break;
- case 2: if (ContNum(num1,num2))
- LcdClsFull();
- LcdShowStr(0,0,"Set pass OK ");
- CopyNum(num0,num2);
- E2Write(num0,0x05,sizeof(num0));
- Esc();
- else
- ClsNum(num2);
- default: break;
- clag = 1;
- void KeyAction(uchar kcod)
- if (Paserror < 5)
- if ((kcod >= 0x00) && (kcod <= 0x09))
- if (!On) //密码打开状态禁止输入
- switch(Passcou)
- case 0: InCoumNum(num1,kcod); //输入数字
- break;
- case 1: InCoumNum(num1,kcod);
- break;
- case 2: InCoumNum(num2,kcod);
- break;
- default:
- break;
- else if (kcod == 0x1b)
- if (!On)
- SetPass(); //设置密码
- else if (kcod == 0x0d) //复位
- Esc();
- else if (kcod == 0x27)
- if (!On)
- Enter(); //确认
- ulong tmp;
- tmp = 11059200/12;
- tmp = (tmp*ms)/1000;
- tmp = (65536-tmp);
- T0RH = (uchar)(tmp>>8);
- T0RL = (uchar)tmp;
- TH0 = T0RH;
- TL0 = T0RL;
- TMOD &= 0xf0;
- TMOD |= 0x01;
- TR0 = 1;
- ET0 = 1;
- void InterruptTime0() interrupt 1
- static uint Errortime = 0; //密码错误计时
- TH0 = T0RH;
- TL0 = T0RL;
- KeyScan();
- if (BeedOn)
- Bee = ~Bee;
- else
- Bee = 1;
密码锁.zip
(100.26 KB, 下载次数: 80)
