测量555定时器脉冲。
用蓝桥杯板子写的程序,大家自行下载,看一下
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sfr AUXR=0x8e;
- uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff};
- void smg_xianshi(uchar yi,er,san,si,wu,liu,qi,ba);
- uchar yi,er,san,si,wu,liu,qi,ba;
- void delay(uint x);
- void close ();
- void Timer0Init(void);
- void zd_t1();
- void Timer1Init(void);
- uint time,fre;
- void main()
- Timer1Init();
- Timer0Init();
- EA=1;
- ET1=1;
- while(1)
- yi=11;er=11;san=11;
- si=fre/10000;
- wu=(fre%10000)/1000;
- liu=(fre%1000)/100;
- qi=(fre%100)/10;
- ba=(fre%100)%10;
- smg_xianshi(yi,er,san,si,wu,liu,qi,ba);
- void zd_t1() interrupt 3
- time++;
- if(time==1000)
- TR0=0;
- time=0;
- fre=TH0*256+TL0;
- TH0=0;
- TL0=0;
- TR0=1;
- void Timer1Init(void) //1毫秒@11.0592MHz
- AUXR &= 0xBF; //定时器时钟12T模式
- TMOD &= 0x0F; //设置定时器为定时模式
- TL1 = 0x66; //设置定时初值
- TH1 = 0xFC; //设置定时初值
- TF1 = 0; //清除TF1标志
- TR1 = 1 ; //定时器1开始计时
- AUXR &= 0x7F; //定时器时钟12T模式
- TMOD |= 0x05; //设置定时器为计数模式
- TL0 = 0x00; //设置定时初值
- TH0 = 0x00; //设置定时初值
- TF0 = 0; //清除TF0标志
- TR0 = 1; //定时器0开始计时
- uchar i;
- while(x--)
- for(i=0;i<120;i++);
- void close ()
- P2=0x80;
- P0=0xff;
- P2=0x1f;
- P2=0xa0;
- P0=0x00;
- P2=0x1f;
- P2=0xc0;
- P0=0x01;
- P2=0xe0;
- P0=tab[yi];
- delay(5);
- P2=0xc0;
- P0=0x02;
- P2=0xe0;
- P0=tab[er];
- delay(5);
- P2=0xc0;
- P0=0x04;
- P2=0xe0;
- P0=tab[san];
- delay(5);
- P2=0xc0;
- P0=0x08;
- P2=0xe0;
- P0=tab[si];
- delay(5);
- P2=0xc0;
- P0=0x10;
- P2=0xe0;
- P0=tab[wu];
- delay(5);
- P2=0xc0;
- P0=0x20;
- P2=0xe0;
- P0=tab[liu];
- delay(5);
- P2=0xc0;
- P0=0x40;
- P2=0xe0;
- P0=tab[qi];
- delay(5);
- P2=0xc0;
- P0=0x80;
- P2=0xe0;
- P0=tab[ba];
- delay(5);
555.zip
(197 Bytes, 下载次数: 45)
