查看: 1614|回复: 1
自己写的计算器程序,有点bug
ID:291220 发表于 2018-4-25 22:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define uint unsigned int
sbit rw=P2^5;
sbit rs=P2^6;
sbit e=P2^7;
sbit led=P3^7;
sbit beep=P3^2;
uint key,num,k;
uint fuhao;flag,a,b,c,d,biao;
uint dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//±£′???ê?μ?êy?Y
uchar code table[]="WE LOVE EE!";
uchar code table1[]="ZZJ SZX WK!";
void delay(uint i)
        uint x,y;
        for(x=i;x>0;x--)
                for(y=1;y>0;y--);
void write_com(uchar com)
        rs=0;
        e=0;
        rw=0;
        P0=com;
        delay(500);
        e=1;
        delay(500);
        e=0;
void write_date(uchar date)
        rs=1;
        rw=0;
        e=0;
        P0=date;
        delay(500);
        e=1;
        delay(500);
        e=0;
        rs=0;
void init()
        write_com(0x38);
        write_com(0x08);
        write_com(0x01);
        write_com(0x06);
        write_com(0x0c);
                beep=~beep;
        for (num=0;num<11;num++)
        { write_date(table[num]);
          delay(10000);
        write_com(0x80+0x40);
        { write_date(table1[num]);
          delay(10000);
        beep=0;
        delay(10000);
        write_com(0x01);
        key=0;
        num=0;
        key=0;
        num=0;
        flag=0;
        fuhao=0;
        a=0;
        b=0;
        c=0;
        d=0;
        biao=0;
        led=0;
void keyscan()
        P1=0xfe;
        if(P1!=0xfe)
                delay(1000);
                if(P1!=0xfe)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=0;
                                        break;
                                case 0xd0: num=1;
                                        break;
                                case 0xb0: num=2;
                                        break;
                                case 0x70: num=3;
                                        break;
                while(P1!=0xfe);
                if(num==0||num==1||num==2)
                        if(flag==0)
                                a=a*10+dat1[num];
                                b=b*10+dat1[num];
                if(num==3)
                        flag=1;
                        fuhao=1;
                write_date(0x30+dat1[num]);
        P1=0xfd;
        if(P1!=0xfd)
                delay(1000);
                if(P1!=0xfd)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=4;
                                        break;
                                case 0xd0: num=5;
                                        break;
                                case 0xb0: num=6;
                                        break;
                                case 0x70: num=7;
                                        break;
                while(P1!=0xfd);
                if(num==4||num==5||num==6)
                        if(flag==0)         //??óD°′??·?o??ü
                                //led=1;
                                a=a*10+dat1[num];
                                //led=1;
                                b=b*10+dat1[num];
                        flag=1;
                        fuhao=2;//′?±í??o?
        P1=0xfb;
        if(P1!=0xfb)
                delay(1000);
                if(P1!=0xfb)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=8;
                                        break;
                                case 0xd0: num=9;
                                        break;
                                case 0xb0: num=10;
                                        break;
                                case 0x70: num=11;
                                        break;
                while(P1!=0xfb);
                if(num==8||num==9||num==10)
                                //led=1;
                                a=a*10+dat1[num];
                                //led=1;
                                b=b*10+dat1[num];
                        flag=1;
                        fuhao=3;//′?±í3?o?*
        P1=0xf7;
        if(P1!=0xf7)
                delay(1000);
                if(P1!=0xf7)
                        key=P1&0xf0;
                        switch(key)
                                case 0xe0: num=12;
                                        break;
                                case 0xd0: num=13;
                                        break;
                                case 0xb0: num=14;
                                        break;
                                case 0x70: num=15;
                                        break;
                while(P1!=0xf7);
        switch(num)
                case 12:
                                                //led=1;
                                                a=a*10+dat1[num];
                                                write_date(0x30);
                                                //led=1;
                                                b=b*10+dat1[num];
                                                write_date(0x30);
                                        break;
                        case 13:
                                        write_com(0x01);
                                        a=0;
                                        b=0;
                                        flag=0;
                                        fuhao=0;
                                        break;
                        case 15:
                                        flag=1;
                                        fuhao=4;
                                        write_date(0x2f);//3yo?/
                                        break;
                        case 14:
                                        if(fuhao==1)//?ó
                                                write_com(0x4f+0x80);
                                                write_com(0x04);//éè??1a±ê×óò?£??á??2?ò??ˉ
                                                c=a+b;
                                                while(c!=0)         //ò???ò?????ê?
                                                        write_date(0x30+c%10);//??ê??á1?μ?×?oóò????ú0x4fμ?????
                                                        c=c/10;//è??°??μ??á1?êy?Y
                                                write_date(0x3d); //??ê?μèóúo?=
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;//è?2???3y?a0
                                        if(fuhao==2)   //??
                                                if(a>b)
                                                        c=a-b;
                                                        c=b-a;
                                                if(a<b)        write_date(0x2d); //??ê?-o?
                                                a=0;
                                                b=0;
                                                flag=0;
                                        if(fuhao==3)//3?·¨
                                                c=a*b;
                                                a=0;
                                                b=0;
                                                flag=0;
                                        if(fuhao==3)//3?·¨
                                                c=a*b;
                                                a=0;
                                                b=0;
                                                flag=0;
                                        if(fuhao==4)
                                                k=0;
                                                c=(long)(((float)a/b)*1000);//????×a???along?£
                                                        k++;
                                                        if(k==3)
        write_date(0x2e);
        k=0;
                                                if(a/b<0)          //è?1?a±èbD?μ??°???′3yμ??á1?×?????ê?0
                                                        write_date(0x30);
                                                write_date(0x3d); //??ê?μèo?
                                                a=0;
                                                b=0;
                                                flag=0;
        init();
                keyscan();
ID:316877 发表于 2018-4-26 11:40 | 只看该作者
复制了代码试试看
