查看: 3090|回复: 1
Arduino蓝牙小车制作代码资料
ID:277207 发表于 2018-4-29 13:48 | 显示全部楼层 |阅读模式
我们实训学习制作的资料,分享给大家看看
小车
小车
Arduino板
Arduino板
蓝牙模块
蓝牙模块
L298N
L298N
  1. void go()
  2. {
  3. digitalWrite(5,HIGH);
  4. digitalWrite(6,LOW);
  5. digitalWrite(9,HIGH);
  6. digitalWrite(10,LOW);
  7. }
  8. void left()
  9. {
  10.   digitalWrite(5,LOW);
  11.     digitalWrite(6,LOW);
  12.    digitalWrite(9,HIGH);
  13.    digitalWrite(10,LOW);
  14. }
  15. void right()
  16. {
  17.   digitalWrite(5,HIGH);
  18.     digitalWrite(6,LOW);
  19.    digitalWrite(9,LOW);
  20.    digitalWrite(10,LOW);
  21. }
  22. void back()
  23. {
  24.   digitalWrite(5,LOW);
  25.     digitalWrite(6,HIGH);
  26.    digitalWrite(9,LOW);
  27.    digitalWrite(10,HIGH);
  28. }
  29. void add()
  30. {
  31.     int i;
  32.     for(i=0;i<255;i+=5)
  33.     {
  34.      analogWrite(5,i);
  35.      analogWrite(9,i);
  36.      delay(100);   }
  37.      digitalWrite(6,LOW);
  38.    digitalWrite(10,LOW);
  39. }
  40. void ting()
  41. {
  42.   digitalWrite(5,LOW);
  43.     digitalWrite(6,LOW);
  44.    digitalWrite(9,LOW);
  45.    digitalWrite(10,LOW);
  46. }
  47. void voice()
  48. {
  49. int i;
  50. for(i=0;i<100;i++)
  51. {
  52. if(i%2==0)
  53.    {
  54. digitalWrite(7,HIGH);
  55.   delay(500);
  56.    }
  57.   else
  58.    {
  59.   digitalWrite(7,LOW);
  60.   delay(500);
  61.   int x=Serial.read();
  62.      if(x > 0)
  63.     {
  64.       digitalWrite(7,HIGH);
  65.       break;
  66.     }
  67.    }
  68. }
  69. }
  70.
  71. void setup() {
  72.   // put your setup code here, to run once:
  73. pinMode (5,OUTPUT);
  74.   pinMode(6,OUTPUT);
  75.   pinMode(9,OUTPUT);
  76.   pinMode(10,OUTPUT);
  77.   pinMode(7,OUTPUT);
  78.   pinMode(13,OUTPUT);
  79.   pinMode(12,OUTPUT);
  80.   pinMode(11,OUTPUT);
  81.   digitalWrite(7,HIGH);
  82. Serial.begin(9600);
  83. Serial.println("serial is ok");
  84. }
  85. void loop() {
  86.   // put your main code here, to run repeatedly:
  87. char ch;
  88. ch=Serial.read();
  89. Serial.println(ch);
  90. if(ch=='w')
  91. {go();}
  92. else if(ch=='a')
  93. {left();
  94. digitalWrite(12,HIGH);}
  95. else if(ch=='d')
  96. {right();
  97.   digitalWrite(11,HIGH);}
  98. else if(ch=='s')
  99. {back();
  100. voice();
  101. digitalWrite(13,HIGH);}
  102. else if(ch=='t')
  103. {ting();}
  104. else if(ch=='q')
  105. {add();}
  106. }
全部资料51hei下载地址:
代码资料.zip (256.42 KB, 下载次数: 33)
ID:277207 发表于 2018-4-29 13:50 | 显示全部楼层
第一次发帖,图片好像上传太大,打开有点慢,望谅解
