三个步进电机同步运行 直接可用
- #include <REGX51.H>
- #define motor1 1
- #define motor2 2
- #define motor3 3
- #define motor1_up 0
- #define motor1_down 1
- #define motor2_up 0
- #define motor2_down 1
- #define motor3_up 0
- #define motor3_down 1
- #define sub 16
- sbit pwm1 = P0^0;
- sbit pwm2 = P0^1;
- sbit pwm3 = P0^2;
- sbit dir1 = P0^3;
- sbit dir2 = P0^4;
- sbit dir3 = P0^5;
- sbit exti1 = P1^0;
- sbit exti2 = P1^1;
- sbit exti3 = P1^2;
- int motor1_pulse = 0;
- int motor2_pulse = 0;
- int motor3_pulse = 0;
- char motor1_cons = 0;
- char motor2_cons = 0;
- char motor3_cons = 0;
- void delay_ms(int i)
- unsigned char a,b;
- for(;i>0;i--)
- for(b=102;b>0;b--)
- for(a=3;a>0;a--);
- void InitTimer0(void)
- TMOD = 0x01;
- TH0 = 0x0FF;
- TL0 = 0x48;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- void motor_control(char motor,char dir,int pulse)
- if(motor == motor1)
- if(dir == motor1_up)
- dir1 = motor1_up;
- else
- dir1 = motor1_down;
- motor1_cons = 0;
- motor1_pulse += (pulse * sub *2);
- if(motor ==motor2)
- if(dir == motor2_up)
- dir2 = motor2_up;
- else
- dir2 = motor2_down;
- motor2_cons = 0;
- motor2_pulse += (pulse * sub * 2);
- if(motor ==motor3)
- if(dir == motor3_up)
- dir3 = motor3_up;
- else
- dir3 = motor3_down;
- motor3_cons = 0;
- motor3_pulse += (pulse * sub *2);
- void motor_init(void)
- while((!exti1) | (!exti2)| (!exti3))
- if(!exti1)
- motor_control(motor1,motor1_down,5);
- if(!exti2)
- motor_control(motor2,motor2_down,5);
- if(!exti3)
- motor_control(motor3,motor3_down,5);
- while((!motor1_cons) | (!motor2_cons)| (!motor3_cons));
- void main(void)
- InitTimer0();
- motor_init();
- motor_control(motor1,motor1_up,200);
- motor_control(motor2,motor2_up,200);
- motor_control(motor3,motor3_up,200);
- delay_ms(1000);
- while(1);
- void Timer1_isr(void) interrupt 1 using 1
- if(motor1_pulse > 0)
- motor1_pulse--;
- pwm1 = !pwm1;
- else
- motor1_cons = 1;
- if(motor2_pulse > 0)
程序.rar
(5.33 MB, 下载次数: 74)
