最近跟老师一起准备省电子设计竞赛了,老师要求先准备好基础的调试环境,当然选择usart的调试接收方法啦,由于没确定这个项目后期会加进来什么功能,不好确定每个包的大小,于是先写好串口的不定长接收包,想到的方式自然是IDLE+RXNE的查询
1->
在IDLE里头通过systick检测接收空闲的时间,如果空闲时间>10ms就给标记,停止IDLE中断而去处理这个数据包
//USART1 IRQ handler
- void USART1_IRQHandler(void)
- #if defined (USART_RECIEVE_BY_DMA)
- //handle by DMA + IDLE inquiry
- uint16_t dmaCounter = DMA_GetCurrDataCounter(DMA1_Channel5);
- if ( USART_GetITStatus( USART1 , USART_IT_IDLE ) != RESET ) {
- printf("DMA counter:%d\r\n",dmaCounter);
- //has dealt rx buffer
- // if (dmaCounter != USART_BUFF_SIZE) {
- usartRx.isDeal = false;
- DMA_Cmd(DMA1_Channel5,DISABLE);
- DMA_ClearFlag(DMA1_FLAG_GL3);
- usartRx.buffHead = USART_BUFF_SIZE - dmaCounter;
- DMA_SetCurrDataCounter( DMA1_Channel5 , USART_BUFF_SIZE );
- //reset the counter register
- USART_ClearITPendingBit(USART1,USART_IT_IDLE);
- USART_ITConfig(USART1,USART_IT_IDLE,DISABLE);
- //close usart IDLE interrupt
- #else
- //IRQ handle by SYSTICK + IDLE inquiry
- static uint32_t thisRcvTime = 0;
- if ( USART_GetITStatus( USART1 , USART_IT_RXNE ) != RESET ) {
- usartRx.endTime = thisRcvTime;
- thisRcvTime = millis();
- //update lastTime recieved a byte
- usartRx.buff[usartRx.buffHead] = USART1->DR;
- //interval > 10ms
- if(thisRcvTime - usartRx.endTime > 10){
- usartRx.frameHead = usartRx.buffHead;
- }else{
- // usartRx.isDeal = true;
- usartRx.frameEnd = usartRx.buffHead;
- //if interval < 10ms ,stream belong to same frame
- USART_ITConfig(USART1,USART_IT_IDLE,ENABLE);
- //start idle time detect
- usartRx.buffHead = (usartRx.buffHead + 1)%USART_BUFF_SIZE;
- USART_ClearITPendingBit(USART1,USART_IT_RXNE);
- //detect IDLE time
- if(millis() - thisRcvTime > 10 ){
- //close idle interrupt for save CPU
- #endif
复制代码 2->
然后再处理函数里头实现一个简单的回显
- #if defined(USART_RECIEVE_BY_SYSTICK)
- //USART1 recieve frame by systick + RXNE
- void usart_recieve_systick_handler(void)
- uint16_t i;
- if(usartRx.isDeal == false){
- USART_ITConfig(USART1,USART_IT_IDLE|USART_IT_RXNE,DISABLE);
- if(usartRx.frameHead < usartRx.frameEnd){
- // printf("%d < %d\r\n",usartRx.frameHead,usartRx.frameEnd);
- for(i=usartRx.frameHead; i<=usartRx.frameEnd; i++){
- while((USART1->SR & 0X40)==0);
- USART1->DR = usartRx.buff[i];
- }else{
- // printf("%d > %d\r\n",usartRx.frameHead,usartRx.frameEnd);
- for(i=usartRx.frameHead; i<USART_BUFF_SIZE; i++){
- for(i=0; i<usartRx.frameEnd; i++){
- USART_ITConfig(USART1,USART_IT_IDLE|USART_IT_RXNE,ENABLE);
- usartRx.isDeal = true;
- #endif
全部资料51hei下载地址:
ST.rar
(264.57 KB, 下载次数: 11)
