这是花了几天时间做的课程设计,里面包含原理图,
代码,
仿真图,
程序,
大家请多多指教。
- #include<reg52.h>//包含52单片机头文件
- #define uchar unsigned char
- #define uint unsigned int
- sbit rs=P2^0; //定义1602液晶RS端
- sbit lcden=P2^2;//定义1602液晶LCDEN端
- sbit rd=P2^1; //定义1602液晶rd端
- sbit s1=P3^0; //定义按键--功能键
- sbit s2=P3^1; //定义按键--增加键
- sbit s3=P3^2; //定义按键--减小键
- sbit beep=P2^3; //定义蜂鸣器端
- uchar count,s1num;
- char miao,shi,fen,nian,yue,ri,zhou,num,tian;
- char yizhou[8][4]={"MON","TUE","WEN","THU","FRI","SAT","SUN"};
- int pingnian[13]={0,31,28,31,30,31,30,31,31,30,31,30,31};
- int ruinian[13]={0,31,29,31,30,31,30,31,31,30,31,30,31};
- void delay(uint z) //延时函数
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void di()
- uchar i;
- for(i=0;i<100;i++)
- beep = ~beep;
- delay(1);
- beep = 0;
- void write_com(uchar com)//液晶写命令函数
- rs=0;
- lcden=0;
- P0=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_date(uchar date)//液晶写数据函数
- rs=1;
- lcden=0;
- P0=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_sfm(uchar add,uchar date)//写时分秒函数
- uchar shi,ge;
- shi=date/10;//分解一个2位数的十位和个位
- ge=date%10;
- write_com(0x80+0x40+add);//设置显示位置
- write_date(0x30+shi);//送去液晶显示十位
- write_date(0x30+ge); //送去液晶显示个位
- void write_nyr(uchar add,uchar date)//写年月日函数
- uchar shi,ge;
- ge=date%10;
- write_com(0x80+add);//设置显示位置
- void init()//初始化函数
- num=0;
- rd=0;
- lcden=0;
- fen=0; //初始化分变量值
- miao=0;
- shi=0;
- nian=1;
- yue=1;
- ri=1;
- zhou=0;
- count=0;
- s1num=0;
- write_com(0x38);//初始化1602液晶
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- write_com(0x80+1);//设置显示初始坐标
- write_date('2');
- write_com(0x80+2 );
- write_date('0');
- write_com(0x80+0x40+6);//写出时间显示部分的两个冒号
- write_date(':');
- delay(5);
- write_com(0x80+0x40+9);
- write_date(':');
- delay(5);
- write_com(0x80+5);//写出时间显示部分的两个-
- write_date('-');
- delay(5);
- write_com(0x80+8);
- write_date('-');
- delay(5);
- write_com(0x80+12);
- for(num=0;num<3;num++)
- write_date(yizhou[zhou][num]);
- delay(5);
- write_nyr(3,nian);
- write_nyr(6,yue);
- write_nyr(9,ri);
- write_sfm(10,miao);
- write_sfm(7,fen);
- write_sfm(4,shi);
- TMOD=0x01;//设置定时器0工作模式1
- TH0=(65536-50000)/256;//定时器装初值
- TL0=(65536-50000)%256;
- EA=1; //开总中断
- ET0=1; //开定时器0中断
- TR0=1; //启动定时器0
- void keyscan()//按键扫描函数
- if(s1==0)
- delay(5);
- if(s1==0)//确认功能键被按下
- { s1num++;//功能键按下次数记录
- while(!s1);//释放确认
- di();//每当有按键释放蜂鸣器发出滴声
- if(s1num==1)//第一次被按下时
- TR0=0; //关闭定时器
- write_com(0x80+0x40+11);//光标定位到秒位置
- write_com(0x0f); //光标开始闪烁
- if(s1num==2)//第二次按下光标闪烁定位到分钟位置
- write_com(0x80+0x40+8);
- if(s1num==3)//第三次按下光标闪烁定位到小时位置
- write_com(0x80+0x40+5);
- if(s1num==4)//第四次按下光标闪烁定位到周位置
- write_com(0x80+14);
- if(s1num==5)//第五次按下光标闪烁定位到日位置
- write_com(0x80+10);
- if(s1num==6)//第六次按下光标闪烁定位到月位置
- write_com(0x80+7);
- if(s1num==7)//第七次按下光标闪烁定位到年位置
- write_com(0x80+4);
- if(s1num==8)//第八次按下
- s1num=0;//记录按键数清零
- write_com(0x0c);//取消光标闪烁
- TR0=1; //启动定时器使时钟开始走
- if(s1num!=0)//只有功能键被按下后,增加和减小键才有效
- if(s2==0)
- delay(5);
- if(s2==0)//增加键确认被按下
- while(!s2);//按键释放
- if(s1num==1)//若功能键第一次按下
- miao++; //则调整秒加1
- if(miao>=60)//若满60后将清零
- miao=0;
- write_sfm(10,miao);//每调节一次送液晶显示一下
- write_com(0x80+0x40+11);//显示位置重新回到调节处
- if(s1num==2)//若功能键第二次按下
- fen++;//则调整分钟加1
- if(fen>=60)//若满60后将清零
- fen=0;
- write_sfm(7,fen);//每调节一次送液晶显示一下
- write_com(0x80+0x40+8);//显示位置重新回到调节处
- if(s1num==3)//若功能键第三次按下
- shi++;//则调整小时加1
- if(shi>=24)//若满24后将清零
- shi=0;
- write_sfm(4,shi);;//每调节一次送液晶显示一下
- write_com(0x80+0x40+5);//显示位置重新回到调节处
- if(s1num==4)//若功能键第四次按下
- zhou++;
- if(zhou>=7)//若满7后将清零
- zhou=0;
- write_com(0x80+12);//设置显示初始坐标
- delay(5);
- if(s1num==5)//若功能键第二次按下
- ri++;//则调整日加1
- if((2000+nian)%400==0||(2000+nian)%4==0&&(2000+nian)%100!=0)
- tian=ruinian[yue];
- else nian=pingnian[yue];
- if(ri>tian)
- ri=1;
- write_nyr(9,ri);//每调节一次送液晶显示一下
- write_com(0x80+10);//显示位置重新回到调节处
- if(s1num==6)//若功能键第二次按下
- yue++;//则调整月加1
- if(yue>12)//若满12后将清零
- yue=1;
- write_nyr(6,yue);//每调节一次送液晶显示一下
- write_com(0x80+7);//显示位置重新回到调节处
- if(s1num==7)//若功能键第二次按下
- nian++;//则调整nian加1
- if(nian>50)//若满50后将清零
- nian=0;
- write_nyr(3,nian);//每调节一次送液晶显示一下
- write_com(0x80+4);//显示位置重新回到调节处
- if(s3==0)
- delay(5);
- if(s3==0)//确认减小键被按下
- while(!s3);//按键释放
- miao--; //则调整秒加1
- if(miao<0)//若满60后将清零
- miao=59;
- fen--;//则调整分钟加1
- if(fen<0)//若满60后将清零
- fen=59;
- shi--;//则调整小时加1
- if(shi<0)//若满24后将清零
- shi=23;
- zhou--;
- if(zhou<0)//若满7后将清零
- zhou=6;
- delay(5);
- ri--;//则调整日加1
- if(ri<1)
- ri=tian;
- yue--;//则调整月加1
- if(yue<1)//若满12后将清零
- yue=12;
- nian--;//则调整nian加1
- if(nian<0)//若满50后将清零
- nian=50;
- void main()//主函数
- init();//首先初始化各数据
- while(1)//进入主程序大循环
- keyscan();//不停的检测按键是否被按下
- void timer0() interrupt 1//定时器0中断服务程序
- TH0=(65536-50000)/256;//再次装定时器初值
- count++; //中断次数累加
- if(count==20) //20次50毫秒为1秒
- count=0;
- miao++;
- if(miao>=60)//秒加到60则进位分钟
- miao=0;//同时秒数清零
- fen++;
- if(fen>=60)//分钟加到60则进位小时
- fen=0;//同时分钟数清零
- shi++;
- if(shi>=24)//小时加到24则小时清零
- shi=0;
- ri++;
- zhou++;
- if(zhou>6)//若满7后将清零
- zhou=0;
- delay(5);
DZZ.zip
(81.76 KB, 下载次数: 228)
