主机#define KEY P1
//unsigned char code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x7f};
unsigned char code num[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //共yang数码管
unsigned char KeyValue;
int i;
void Delay10ms(unsigned int c); //延时10ms
void KeyDown(); //检测按键函数
void main(void)
unsigned char temp=0;
KeyDown();
TMOD=0x20;
TH1=0xfd;
TL1=0xfd;
SCON=0x40;
PCON=0x00;
TR1=1;
i=KeyValue;
if(i<=9)
shuchu0 = num[0];
shuchu2 = num[KeyValue];
i=i-10;
shuchu0 = num[1];
shuchu2 = num[i];
while(1){
temp=KeyValue;
SBUF=temp;
while(TI==0);
TI=0;
break;
* 函 数 名 : KeyDown
* 函数功能 : 检测有按键按下并读取键值
* 输 入 : 无
* 输 出 : 无
void KeyDown(void)
char a = 0;
KEY=0x0f;
if(KEY!=0x0f)//读取按键是否按下
Delay10ms(1);//延时10ms进行消抖
if(KEY!=0x0f)//再次检测键盘是否按下
//测试列
KEY=0X0F;
switch(KEY)
case(0X07): KeyValue=0;break;
case(0X0b): KeyValue=4;break;
case(0X0d): KeyValue=8;break;
case(0X0e): KeyValue=12;break;
//测试行
KEY=0XF0;
switch(KEY)
case(0X70): KeyValue=KeyValue+3;break;
case(0Xb0): KeyValue=KeyValue+2;break;
case(0Xd0): KeyValue=KeyValue+1;break;
case(0Xe0): KeyValue=KeyValue;break;
while((a<50) && (KEY!=0xf0)) //检测按键松手检测
Delay10ms(1);
a++;
unsigned char a, b;
for (;c>0;c--)
for (b=38;b>0;b--)
for (a=130;a>0;a--);
从机#include<reg51.h>
unsigned char i;
#define shuchu0 P0
#define shuchu2 P2
void main(void)
while(1){
TMOD=0x20;
TH1=0xfd;
TL1=0xfd;
SCON=0x50;
PCON=0x00;
TR1=1;
while(RI==0);
RI=0;
temp=SBUF;
i=temp;
if(i<=9)
shuchu0 = num[0];
shuchu2 = num[i];
i=i-10;
shuchu0 = num[1];
shuchu2 = num[i];
