通过AT89C51和DAC0832实现的波形发生器 函源文件和仿真图
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- //#define Fosc 24000000/12000000 //12分频后的频率
- #define DAdata P0 //DA数据端口
- sbit DA_S1= P2^0; // 控制DAC0832的8位输入寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
- sbit DA_S2= P2^1; // 控制DAC0832的8位DAC寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
- sbit key= P3^2;
- uchar wavecount; //'抽点'计数
- uchar THtemp,TLtemp;//传递频率的中间变量
- //uint T_temp;
- uchar judge=1; //在方波输出函数中用于简单判别作用
- uchar waveform; //当其为0、1、2时,分别代表三种波
- uchar code freq_unit[3]={10,50,200}; //三种波的频率单位
- uchar idata wavefreq[3]={1,1,1}; //给每种波定义一个数组单元,用于存放单位频率的个数
- uchar code lcd_hang1[]={"Sine Wave " "Triangle Wave " "Square Wave " "Select Wave: " "press No.1 key! "};
- uchar idata lcd_hang2[16]={"f= Hz "};
- /*uchar code wave_freq_adjust[]={ //频率调整中间值
- 0xff,0xb8,0x76,0x56,0x43,0x37,0x2e,0x26,0x20,0x1c, //正弦波频率调整中间值
- 0xff,0x8e,0x5a,0x41,0x32,0x28,0x20,0x1b,0x17,0x0e, //三角波频率调整中间值
- 0xff,0x8e,0x5a,0x41,0x32,0x28,0x20,0x1b,0x17,0x0e};
- uint code wave_freq_adjust[]={ //频率调整中间值
- 380,184,118,86,67,55,46,28,38,32,
- 295,142, 90,65,50,40,32,27,23,14,
- 295,142, 90,65,50,40,32,27,23,14}; */
- /*uchar code waveTH[]={
- 0xfc,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
- uchar code waveTL[]={
- 0xf2,0x78,0xfb,0x3c,0x63,0x7d,0x8f,0x9d,0xa8,0xb1,
- 0x17,0x0b,0xb2,0x05,0x37,0x58,0x70,0x82,0x90,0x9b,
- 0x4d,0xa7,0xc4,0xd3,0xdc,0xe2,0xe6,0xea,0xec,0xee};*/
- /***********这两组数组很重要,需要根据波形来调试,选择合适的值,使输出波形达到频率要求************/
- uchar code waveTH[]={
- 0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
- 0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波频率调整中间值
- 0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde, //三角波频率调整中间值
- 0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c};
- uchar code triangle_tab[]={ //每隔数字8,采取一次
- 0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
- 0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
- 0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
- 0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
- uchar code sine_tab[256]={
- //输出电压从0到最大值(正弦波1/4部分)
- 0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
- 0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
- 0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
- //输出电压从最大值到0(正弦波1/4部分)
- 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
- 0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
- 0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
- //输出电压从0到最小值(正弦波1/4部分)
- 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
- 0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
- 0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
- //输出电压从最小值到0(正弦波1/4部分)
- 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
- 0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
- 0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
- void delay(uchar z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void triangle_out() //三角波输出
- DAdata=triangle_tab[wavecount++];
- if(wavecount>64) wavecount=0;
- DA_S1=0; //打开8位输入寄存器
- DA_S1=1; //关闭8位输入寄存器
- void sine_out() //正弦波输出
- DAdata=sine_tab[wavecount++];
- void square_out() //方波输出
- judge=~judge;
- if(judge==1) DAdata=0xff;
- else DAdata=0x00;
- /************1602液晶的相关函数*************/
- #define lcd_ports P1
- sbit rs=P2^2;
- sbit rw=P2^3;
- sbit lcden=P2^4;
- void write_com(uchar com)
- rs=0; //置零,表示写指令
- lcden=0;
- lcd_ports=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_date(uchar date)
- rs=1; //置1,表示写数据(在指令所指的地方写数据)
- lcden=0;
- lcd_ports=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void disp_lcd(uchar addr,uchar *temp1)
- uchar num;
- write_com(addr);
- delay(1); //延时一会儿???
- for(num=0;num<16;num++)
- write_date(temp1[num]);//或者这样写write_date(*(temp1+num));
- delay(1);
- void init_lcd()
- //uchar num;
- lcden=0; //可有可无???
- rw=0; //初始化一定要设置为零,表示写数据
- write_com(0x38); //使液晶显示点阵,为下面做准备
- write_com(0x0c); //初始设置
- write_com(0x06); //初始设置
- write_com(0x01); //清零
- write_com(0x80); //使指针指向第一行第一格
- disp_lcd(0x80,&lcd_hang1[3*16]); //在第一行显示
- disp_lcd(0xc0,&lcd_hang1[4*16]); //在第二行显示
- /*for(num=0;num<16;num++)
- write_date(table[num]);
- delay(5);
- write_com(0x80+0x40); //给指针重新赋值,使之指向第二行第一格
- write_date(table1[num]);
- delay(5);
- /*TMOD=0x01; //选用定时方式1
- TH0=(65536-50000)/256; //赋初值
- TL0=(65536-50000)%256; //
- EA=1; //开总中断
- ET0=1; //开定时器中断
- TR0=1; //启动定时器*/
- /********************1602液晶函数声明结束*********************/
- void main()
- uchar i=0;
- DA_S2=0; //使DAC寄存器处于直通状态
- DAdata=0;
- init_lcd();
- waveform=0;
- TMOD=0x01; //设置定时器0为16位工作方式
- IT0=1; //设置外部中断0为下降沿触发
- ET0=1; //开定时器中断
- EX0=1;
- EA=1;
- while(1)
- //DAout(0xff); //可输出TTL波形
- //DAout(0x80);
- //T_temp=32;
- void timer0() interrupt 1
- TH0=THtemp;
- TL0=TLtemp;
- if(waveform==0) sine_out();
- else if(waveform==1) triangle_out();
- else if(waveform==2) square_out();
- void key_int0() interrupt 0
- uchar keytemp;
- uint total_freq; //总频率
- EA=0; TR0=0; //关总中断与定时器
- delay(5); //延时够吗???
- if(key==0) //确实有按键按下而引发中断
- keytemp=P3&0xf0; //获取P3口高四位的值
- switch(keytemp)
- case 0xe0: //选择波形
- waveform++;
- if(waveform>2) waveform=0;
- break;
- case 0xd0: //频率按规定单位依次增加
- wavefreq[waveform]++;
- if(wavefreq[waveform]>10) wavefreq[waveform]=1; // /*这边要用“>10”,因为它比“=11”可靠
- break; // 性更高,使加数有个上限,不会一直加下去*/
- case 0xb0: //频率按规定单位依次衰减
- wavefreq[waveform]--;
- if(wavefreq[waveform]<1) wavefreq[waveform]=10; //这边要用“<1”,因为它比“=0”可靠性更高
- break;
- case 0x70: //TTL输出
- DA_S2=1; //使DAC寄存器关闭
- break;
- THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括号中选取第几个数后,并把该值赋给T_temp
- TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
- total_freq= wavefreq[waveform] * freq_unit[waveform]; //求输出频率(个数*单位)
- lcd_hang2[5]=total_freq%10+0x30; //在液晶中显示个位,(0x30 在液晶显示中表示数字0)
- total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中显示时十位
- total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中显示时百位
- total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中显示时千位
- disp_lcd(0x80,&lcd_hang1[waveform*16]); //在第一行显示
- disp_lcd(0xc0,lcd_hang2); //在第二行显示
- wavecount=0; //'抽点'计数清零
- while(!key);
- EA=1; TR0=1; //开启总中断与定时器
波形发生器.rar
(65.23 KB, 下载次数: 118)
