水温控制系统设计
- 项目名称:水温控制系统设计;
- 功 能:通过STC89C52单片机控制可控硅驱动加过零检测电路作为
- 功率控制电路来控制加热过程,通过键盘扫描来设定水温,
- DS18B20实时测量水的温度,将实际水温与设定水温比较
- 通过PID控制算法调节,是实际水温与设定水温接近。从而
- 达到控制水温的目的。
- 作 者:0903
- #include<reg52.h>
- #include<stdio.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit s1=P2^0;
- sbit s2=P2^1;
- sbit s3=P2^2;
- sbit s4=P2^3;
- sbit s5=P2^4;
- sbit ds=P2^5;
- sbit beep=P2^6;
- sbit rd=P1^0;
- sbit rs=P1^1;
- sbit wr=P1^2;
- sbit lcden=P1^3;
- sbit PWM=P1^6;
- sbit led1=P1^4;
- sbit led2=P1^5;
- uchar set_temp,keytemp;
- uint temp;
- uchar c;
- bit flag,flag1,flag2;
- float f_temp,t;
- int timecount,z;
- float KP,KI,KD;
- float e1,e2,e3;
- float uk,duk;
- uchar HighL,HighH,PWMH;
- float k;
- uchar code table[]={"设定温度:"};
- uchar code table1[]={"实测温度:"};
- uchar code table2[]={"加热"};
- uchar code table3[]={"保温"};
- uchar code table4[]={"作者:0903锋仔@"};
- uchar code table5[]={"系统初始化"};
- uchar code table6[]={"measured Temperature"};
- uchar code table7[]={"水温控制系统设计"};
- uchar code table8[]={" "};
- void delay(uint z)//延时函数,延时5ms
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- 键盘扫描函数
- 通过S5,S4,S3,S2,S1键来分别实现温度设定值的
- 粗加,粗减,精加,精减,和确定功能。
- void keyscan()
- if(set_temp>=100)//将设定温度限定在0-100度之间
- set_temp=100;
- if(set_temp<=0)
- set_temp=0;
- if(s5==0)//此键按下设定温度加5
- delay(10);
- if(s5==0)
- flag1=0;
- set_temp+=5;
- if(set_temp>=100)
- set_temp=100;
- beep=0;
- delay(1000);
- beep=1;
- }while(s5==0);
- if(s4==0)//此键按下设定温度减5
- delay(10);
- if(s4==0)
- flag1=0;
- set_temp-=5;
- if(set_temp<=0)
- set_temp=0;
- beep=0;
- delay(1000);
- beep=1;
- }while(s4==0);
- if(s3==0)//此键按下设定温度加1
- delay(10);
- if(s3==0)
- flag1=0;
- set_temp++;
- if(set_temp==100)
- set_temp=100;
- beep=0;
- delay(1000);
- beep=1;
- }while(s3==0);
- if(s2==0)//此键按下设定温度减1
- delay(10);
- if(s2==0)
- flag1=0;
- set_temp--;
- if(set_temp==0)
- set_temp=0;
- beep=0;
- delay(1000);
- beep=1;
- }while(s2==0);
- if(s1==0)//确定加热状态(加热与不加热)
- delay(10);
- if(s1==0)
- flag1=1;
- while(s1==0);
- DS18B20温度采集模块程序设计
- 通过DS18B20实时采集水温,反映给单片机系统
- void dsreset()//DS18B20复位函数
- uint i;
- ds=0;
- i=103;
- while(i>0)i--;
- ds=1;
- i=4;
- while(i>0)i--;
- bit tempreadbit()//从DS18B20 RAM读一位数据
- uint i;
- bit dat;
- ds=0;i++;
- ds=1;i++;i++;
- dat=ds;
- i=8;while(i>0)i--;
- return(dat);
- uchar tempread()//从DS18B20 RAM读一字节数据
- uchar i,j,dat;
- dat=0;
- for(i=1;i<=8;i++)
- j=tempreadbit();
- dat=(j<<7)|(dat>>1);
- return(dat);
- void tempwritebyte(uchar dat)//向DS18B20写以字节的数据
- uint i,j;
- bit testb;
- for(j=1;j<=8;j++)
- testb=dat&0x01;
- dat=dat>>1;
- if(testb)//写1
- ds=0;
- i++;i++;
- ds=1;
- else//写0
- ds=0;
- ds=1;
- i++;i++;
- /*void readrom()
- dsreset();
- delay(1);
- tempwritebyte(0x33);
- tempwritebyte(0xbe);
- readrom=tempread();
- void matchrom()
- dsreset();
- delay(1);
- tempwritebyte(0x55);
- void tempchange()//启动温度转换
- dsreset();
- delay(1);
- tempwritebyte(0xcc);
- tempwritebyte(0x44);
- float get_temp()//温度值读取与处理函数
- uchar a,b;
- dsreset();
- delay(1);
- a=tempread();
- b=tempread();
- temp=b;
- temp<<=8;
- temp=temp|a;
- f_temp=(float)(temp*0.0625);
- f_temp=f_temp*10;
- return(f_temp);
- 12864显示模块
- 显示实际温度制和设定温度值
- void write_com(uchar com)//向12864写指令
- rs=0;
- wr=0;
- delay(1);
- P0=com;
- lcden=1;
- delay(1);
- lcden=0;
- delay(1);
- void write_date(uchar date)//向12864写数据
- rs=1;
- wr=0;
- delay(1);
- P0=date;
- lcden=1;
- delay(1);
- lcden=0;
- delay(1);
- void display(float m,uchar n)//显示设定温度、实测温度、加热状态
- uint i,j;
- float b;
- float p;
- uchar a1,a2,a3;
- uchar b1,b2,b3,b4;
- if(n<100)
- a1=0;
- a2=n/10;
- a3=n%10;
- else
- a1=1;
- a2=0;
- a3=0;
- p=m;
- j=(uint)(p*10);
- b1=(uchar)(j/1000);
- b2=(uchar)(j%1000/100);
- b3=(uchar)(j%100/10);
- b4=(uchar)(j%10);
- write_com(0x90+5);//显示设定温度
- write_date(0x30+a1);
- write_date(0x30+a2);
- write_date(0x30+a3);
- write_com(0x88+5);//显示实测温度
- write_date(0x30+b1);
- write_date(0x30+b2);
- write_date(0x2e);
- write_date(0x30+b3);
- write_date(0x30+b4);
- b=((float)(b1*100+b2*10+b3))/10.0;
- i=0;
- if((b+0.2)<n)
- led1=0;
- write_com(0x98+1);
- while(table2[i]!='\0')
- write_date(table2[i]);
- i++;
- flag2=1;
- else
- led1=1;
- i=0;
- while(table8[i]!='\0')
- write_date(table8[i]);
- i++;
- i=0;
- if((b=n)||((b>n)&&((b-0.2)<=n))||((b<n)&&((b+0.2)>=n)))
- led2=0;
- write_com(0x98+4);
- while(table3[i]!='\0')
- write_date(table3[i]);
- i++;
- if(flag2==1)
- flag2=0;
- led2=1;
- i=0;
- i++;
- PID控制算法程序设计
- 通过PID控制算法可以使实际水温在设定水温周围呈很小范围的
- 波动,从而使实际水温值接近设定水温值
- void conversion()//定时器2初值处理函数
- uint temp2;
- temp2=65536-PWMH*10;
- HighH=temp2/256;
- HighL=temp2%256;
- void senddate(float y)
- // uint i;
- if(flag==1)
- ES=0;
- flag=0;
- c=0;
- TI=1;
- printf("The measured temp:%f",y);
- // SBUF=1;
- while(!TI);
- TI=0;
- ES=1;
- void init()//初始化函数
- uint i,j;
- TMOD=0x21;
- TH1=0xfd;
- TL1=0xfd;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- PWMH=0;
- conversion();
- TH2=(65536-50000)/256;
- TL2=(65536-50000)%256;
- rd=1;
- lcden=0;
- write_com(0x30);
- write_com(0x0c);
- write_com(0x01);
- write_com(0x90);
- while(table5[i]!='\0')//系统初始化
- write_date(table5[i]);
- i++;
- delay(20);
- for(j=0;j<=1;j++)//6个点的三次循环
- write_com(0x88+4);
- for(i=0;i<=5;i++)
- write_date(0x2e);
- delay(200);
- delay(100);
- for(i=0;i<=5;i++)
- write_date(0x20);
- delay(100);
- i=0;
- write_com(0x80);//显示 水温控制系统设计标题
- while(table7[i]!='\0')
- write_date(table7[i]);
- i++;
- i=0;
- write_com(0x90);//显示 设定温度
- while(table[i]!='\0')
- write_date(table[i]);
- i++;
- i=0;
- write_com(0x88);//显示 实测温度
- while(table1[i]!='\0')
- write_date(table1[i]);
- i++;
- // tempwritebyte(0x4e);//设定DS18B20的分辨率为11位
- // tempwritebyte(0x5f);
- PWM=0;
- e1=0;
- e2=0;
- e3=0;
- duk=0;
- uk=0;
- KP=20;//PID控制算法参数
- KI=0.061;
- KD=30;
- REN=1;//串口通信设置
- SM0=0;
- SM1=1;
- ET0=1;
- ET2=1;
- TR0=1;
- TR1=1;
- TR2=1;//启动定时器2
- EA=1;
- ES=1;
- void main()
- init();
- while(1)
- keyscan();//调用键盘扫描函数
- tempchange();//启动温度转换
- t=get_temp();//提取实测温度
- display(t,set_temp);//显示设定温度和实测温度
- senddate(t);//向上位机发送数据函数
- if((flag1==1))
- if(timecount>=375)
- timecount=0;
- e1=set_temp-t;
- duk=(KP*(e1-e2)+KI*e1+KD*(e1-2*e2+e3));//PID控制算法式
- uk=uk+duk;
- if(e1>=75)
- z=4;
- else if(e1>=50)
- z=3;
- else if(e1>=10)
- z=2;
- else
- z=1;
- if(uk>=2500)uk=2500;
- if(uk<=0)uk=0;
- if(uk<=0)
- ET0=0;
http://www.51hei.com/bbs/dpj-124587-1.html
