查看: 2433|回复: 1
按键不工作
ID:358998 发表于 2018-7-3 10:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "BS87D20A-3.h"
//#define seg                _pb
#define com1    _pc1
#define com2        _pc0
#define com3        _pc2
#define com4        _pc3
#define key1    _pd2
#define key2        _pd3
#define key3        _pa1
#define key4    _pa4
//#define ledc        _pbc
const unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char strtab[3];//缓冲区
//unsigned char cnt=0; //计数变量
unsigned char sec=0,min=0,hour=0;
unsigned char temp;
unsigned char key1_trg;
unsigned char key1_cont;
unsigned long s;  //秒级
unsigned long mms; //毫秒级
unsigned long MS;//毫秒
//unsigned char station; //界面切换标志位
unsigned char readdata;
unsigned char value_present;
unsigned char value_last=0;
void init()
    _ctm0c0=0x20;  // fh/16   2us
        _ctm0c1=0xc1; // 定时/计数器模式 比较器a
        _ctm0al=0xf4; // 1ms
    _ctm0ah=0x01;
        _pbc=0; //输出
        _pcc0=0;
        _pcc1=0;
        _pcc2=0;
        _pcc3=0;
        _pac1=1;
        _pac4=1;
        _pdc2=1;
        _pdc3=1;
        s=1000;
        mms=20;
        MS=5;
        temp=0;
        _pcpu0=1;
        _pcpu1=1;
        _pcpu2=1;
        _pcpu3=1;
//        station=0;
        _mfe=1; //开多功能中断
    _ctm0ae=1; //CTM a中断使能
        _emi=1;        //开总中断
        _ct0on=1; //开定时器
void displaypro()
        strtab[0]=tab[sec%10];
        strtab[1]=tab[sec/10];
        strtab[2]=tab[min%10];
        strtab[3]=tab[min/10];
        init();
                GCC_CLRWDT();//清除开门狗
                displaypro();
        if(key1_trg)
                sec++;if(sec==60);sec=0;
                displaypro();
void __attribute__((interrupt(0x14))) ISR_CTMO(void)
        _ctm0af=0;
        s--;
    MS--;
        mms--;
    if(! MS)
    {   MS=5;//5MS 视觉暂留
                displaypro();
                        com1=1;com2=1;com3=1;com4=1;
                    switch(temp)
                        case 0:com4=0;
                         _pb=strtab[temp]; break;
                        case 1:com3=0;
                        case 2:com2=0;
                        case 3:com1=0;
                        default:break;
                temp++;
                if(temp==4)
                        temp=0;
        if(! s)
           s=1000;//1s电子钟计数
       sec++;
       if(sec==60)
               sec=0;
               min++;
               if(min==60)
                min=0;
                 hour++;
                 if(hour==24)
                  hour=0;
                if(!key1)
                {if(!mms)
                        _ctm0ae=0;//关中断
                        mms=20;//20ms按键消抖
                                value_present=key1;
                        if(value_present&value_last)
                                readdata=key1^0xff;
                                key1_trg = readdata & (readdata^cont);
                                key1_cont=readdata;
                                value_last=key1;
                                _ctm0ae=1;//开中断
                                _ctm0af=0;
ID:364111 发表于 2018-7-3 16:27 | 只看该作者
会不会是硬件问题
