TI的FDC2214电容传感器最近参加电赛的同学都在用,分享一些资料给大家
(包括原理图,pcb,硬件统计等等)
fdc-on-serialplot-signal
fdc-on-serialplot-noise
封装库:
基于Arduino程序(测试通过)
- // FDC2x1x hardware configuration:
- // Component value as in default circuit form datasheet. (18uH inductor and 33pF cap)
- // SD and ADDR pins tied to GND
- // INTB pin not used
- // ARDUINO <--> FDC
- // A4 <-------> SDA
- // A5 <-------> SCL
- // !!!!!! Arduinos are mostly 5V. FDC chips are 3.3V, so either use 3.3V version of Arduino, like pro mini, or use level shifter on I2C bus.
- // ### FDC
- #include <Wire.h>
- #include "FDC2214.h"
- FDC2214 capsense(FDC2214_I2C_ADDR_0); // Use FDC2214_I2C_ADDR_1
- void setup() {
- // ### Start I2C
- Wire.begin();
- // Wire.setClock(400000L);
- // ### Start serial
- Serial.begin(115200);
- Serial.println("\nFDC2x1x test");
- // ### Start FDC
- // Start FDC2212 with 2 channels init
- bool capOk = capsense.begin(0x3, 0x4, 0x5); //setup first two channels, autoscan with 2 channels, deglitch at 10MHz
- // Start FDC2214 with 4 channels init
- //bool capOk = capsense.begin(0xF, 0x4, 0x5); //setup all four channels, autoscan with 2 channels, deglitch at 10MHz
- if (capOk) Serial.println("Sensor OK");
- else Serial.println("Sensor Fail");
- // ### Tell aplication how many chanels will be smapled in main loop
- #define CHAN_COUNT 2
- void loop() {
- unsigned long capa[CHAN_COUNT]; // variable to store data from FDC
- for (int i = 0; i < CHAN_COUNT; i++){ // for each channel
- // ### read 28bit data
- capa[i]= capsense.getReading28(i);//
- // ### Transmit data to serial in simple format readable by SerialPlot application.
- Serial.print(capa[i]);
- if (i < CHAN_COUNT-1) Serial.print(", ");
- else Serial.println("");
- // No point in sleeping
- //delay(100);
全部资料51hei下载地址:
6.封装库.zip
(624.1 KB, 下载次数: 143)
1.基于Arduino程序(测试通过).zip
(84.43 KB, 下载次数: 129)
snor022.zip
(4.04 MB, 下载次数: 135)
