查看: 1181|回复: 0
串口发送X,在LCD上显示“I RECEIVE X”程序怎么做
ID:353444 发表于 2018-7-6 14:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
20黑币
#include "reg52.h"                         //此文件中定义了单片机的一些特殊功能寄存器
#include "lcd.h"
typedef unsigned int u16;          //对数据类型进行声明定义
typedef unsigned char u8;
unsigned char i = 0;
unsigned char str[16];
u8 Temp;
void delayms(uint ms)
        while(ms--)
                for(i=0;i<120;i++);
void UsartInit()
        SCON=0X50;                        //设置为工作方式1
        TMOD=0X20;                        //设置计数器工作方式2
        PCON=0X80;                        //波特率加倍
        TH1=0XF3;                                //计数器初始值设置,注意波特率是4800的
        TL1=0XF3;
        ES=1;                                                //打开接收中断
        EA=1;                                                //打开总中断
        TR1=1;                                        //打开计数器
void uart_send_byte(unsigned char byte)
    SBUF = byte;
    //TI位自动置1,手动清0
    while(!TI);//while(TI != 1);
    TI = 0;
void uart_send_string(unsigned char *string)
            while(*string)
                   uart_send_byte(*string);
                string++;
void uart_rcv_str()
    u8 temp,bitnum = 0;
                   if(RI)
                           RI = 0;
                        temp = SBUF;
                        if(temp == ';')
                                   str[bitnum] = '\0';
                                break;
                                  str[bitnum] = temp;
                                  bitnum++;
void LCD_Write_String(uchar x,uchar y,uchar *str)
        u8 n=0;
        u8 *temp;
        temp=str;
        while(*str++!='\0') n++;
        if(y==0)
                LcdWriteCom(0x80|x);
        if(y==1)
                LcdWriteCom(0xc0|x);
        for(i=0;i<n;i++)
                LcdWriteCom(temp[i]);
void Usart() interrupt 4
   if(RI)                        //判断是接收中断产生
              RI=0;                      //标志位清零
              Temp=SBUF;                 //读入缓冲区的值
              P1=Temp;
              if(i < 10)
                str[i] = Temp;
                i++;
              if(i == 9)
                 str[i] = '\0';
                 LCD_Write_String(1,0,str);
              }                   //把值输出到P1口,用于观察
              SBUF=Temp;                 //把接收到的值再发回电脑端
           if(TI)                        //如果是发送标志位,清零
            TI=0;
void main(void)
        UsartInit();
        LcdInit();
        uart_send_string("I received is:");
                uart_send_string("I rcvd is:");
                uart_rcv_str();
                uart_send_string(str);
                uart_send_string("\n");
                LCD_Write_String(0,0,"I received is:");
                LCD_Write_String(1,1,str);
                if(RI)
                        while(SBUF)
                                uart_send_byte(SBUF);
                                SBUF++;
                        uart_send_byte('\n');
                        delayms(5);
                        RI = 0;
                LCD_Write_String(2,1,str);
或者帮我看看?????????
