查看: 4146|回复: 2
GP2Y0E03红外测距传感器模块的pdf资料手册下载
ID:371537 发表于 2018-7-14 16:02 | 显示全部楼层 |阅读模式
■Description
GP2Y0E03 is a distance measuring sensor unit,
composed of an integrated combination of CMOS
image sensor and IR-LED.
The variety of the reflectivity of the object, the
environmental temperature and the operating duration
are not influenced easily to the distance detection
because of adopting the triangulation method.
This device outputs the voltage corresponding to the
detection distance and digital(I  C) data.
So this sensor can also be used as a proximity sensor.
gp2y0e03_e.pdf
747.25 KB, 下载次数: 54, 下载积分: 黑币 -5
ID:377418 发表于 2018-8-2 14:31 | 显示全部楼层
你好楼楼  这个可以用于51单片机麽
ID:378475 发表于 2018-8-2 16:37 | 显示全部楼层
想问一下,这个传感器怎么接线,小白一只,看不太懂英语文件
