查看: 1677|回复: 0
篮球计分器
ID:291220 发表于 2018-7-14 19:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define uint unsigned int
uchar code table[]=".. Play ball! ....";
uchar code table1[]="Welcome to here!" ;
sbit key_ST=P1^5;                 //功能键(开始/暂停)
sbit key_A1=P1^0;                 //功能键(A队分数加1)
sbit key_A2=P1^3;                 //功能键(A队分数加2)
sbit key_1A=P1^6;                 //功能键(A队分数减1)
sbit key_B1=P1^1;                 //功能键(B队分数加1)
sbit key_B2=P1^4;                 //功能键(B队分数加2)
sbit key_1B=P1^7;                 //功能键(B队分数减1)
sbit key_EX=P1^2;                 //功能键(交换场地,A/B两队分数交换)
sbit key_JS=P3^0;                 //功能键(比赛节数加1)
sbit FMQ=P3^3;                         //蜂鸣器
sbit lcdrs=P3^5;                 //LCD显示的数据/命令选择端
sbit lcden=P3^4;                 //LCD显示的使能信号
uchar flag,ms,mg,ss,sg,ags,agg,bgs,bgg,num,num1,num2,js=1,C,D,t,min=11,time_fmq;
int sec=59;
void delayms(uint xms)                        //定义延时函数
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void write_data(uchar date)                                        //定义为数据模式
        lcdrs=1;
        P0=date;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void write_com(uchar com)                                           //定义为命令模式
        lcdrs=0;
        P0=com;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void lcd_init()        //LCD显示屏的初始化
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void init()        //LCD显示屏的初始化2(即输出“T-”、“Q-”、“A:”、“B:”)
        lcden=0;
        write_com(0x82);
        write_data('T');
        write_data('-');
        write_com(0x8a);
        write_data('Q');
        write_data('-');
        write_com(0x80+0x43);
        write_data('A');
        write_data(':');
        write_com(0x80+0x49);
        write_data('B');
        write_data(':');
void init_start()        //LCD显示屏的初始化2(即输出“T-”、“Q-”、“A:”、“B:”)
        lcden=0;
/*        write_com(0x80+0x10);
        for(num2=0;num2<16;num2++)
                write_data(table1[num2]);
                delayms(5);
        write_com(0x80+0x50);
        for(num2=0;num2<17;num2++)
                write_data(table[num2]);
                delayms(5);
                write_com(0x18);
                delayms(400);
void display(uchar min,int sec,uchar C,uchar D,uchar js)                   //显示函数
        ss=sec/10;
        sg=sec%10;
        ms=min/10;
        mg=min%10;
        ags=C/10;
        agg=C%10;
        bgs=D/10;
        bgg=D%10;
        write_com(0x84);
        write_data(0x30+ms);
        write_data(0x30+mg);
        write_data(':');
        write_data(0x30+ss);
        write_data(0x30+sg);
        write_com(0x8d-1);
        write_data(0x30+js);
        write_com(0x80+0x45);
        write_data(0x30+ags);
        write_data(0x30+agg);
        write_com(0x80+0x4b);
        write_data(0x30+bgs);
        write_data(0x30+bgg);
        TMOD=0x11;        //定义定时器0的工作方式为0001
        TH0=(65536-45872)/256;                                        //装初值
        TL0=(65536-45872)%256;
        TH1=(65536-45872)/256;                                        //装初值
        TL1=(65536-45872)%256;
        EA=1;        //打开总中断
        ET0=1;        //打开定时器0的中断
        TR0=0;
        ET1=1;
        TR1=0;
        lcd_init();
        init_start();
                TR1=0;
                if(key_ST==0)
                        delayms(5);
                        if(key_ST==0)
                                FMQ=0;
                                if(flag==0)
                                        lcd_init();
                                        init();
                                flag=1;
                                TR0=~TR0;
                        while(!key_ST)
                                display(min,sec,C,D,js);
                        FMQ=1;
                if(key_A1==0)
                        delayms(5);
                        if(key_A1==0)
                                FMQ=0;
                                C++;
                        while(!key_A1)
                        FMQ=1;
                if(key_A2==0)
                        delayms(5);
                        if(key_A2==0)
                                FMQ=0;
                                C+=2;
                        while(!key_A2)
                        FMQ=1;
                if(key_1A==0)
                        delayms(5);
                        if(key_1A==0)
                                FMQ=0;
                                C--;
                        while(!key_1A)
                        FMQ=1;
                if(key_B1==0)
                        delayms(5);
                        if(key_B1==0)
                                FMQ=0;
                                D++;
                        while(!key_B1)
                        FMQ=1;
                if(key_B2==0)
                        delayms(5);
                        if(key_B2==0)
                                FMQ=0;
                                D+=2;
                        while(!key_B2)
                        FMQ=1;
                if(key_1B==0)
                        delayms(5);
                        if(key_1B==0)
                                FMQ=0;
                                D--;
                        while(!key_1B)
                        FMQ=1;
        /*        while(min==0&&sec==0)
                        TR0=0;
                        TR1=1;
                        if(key_ST==0)
                                delayms(5);
                                if(key_ST==0)
                                        FMQ=0;
                                        min=11;
                                        sec=60;
                                        TR0=~TR0;
                                while(!key_ST)
                                FMQ=1;
                        if((key_EX==0)&&(js==2))
                                delayms(10);
                                if((key_EX==0)&&(js=2))
                                        FMQ=0;
                                        write_data('B');
                                        write_data('A');
                                        D=C;
                                        t=D;
                                        C=t;
                                    /*t=C;
                                        C=D;
                                        D=t;  */
                                while(!key_EX)
                                FMQ=1;
                        if(key_JS==0)
                                delayms(10);
                                if(key_JS==0)
                                        FMQ=0;
                                        js++;
                                while(!key_JS)
                                        display(min,sec,C,D,2);
                                FMQ=1;
void T0_time()interrupt 1                //中断0控制晶码管显示时间
        TH0=(65536-45872)/256;                // 重装初值
        num++;
        if(num==20)
                num=0;
                sec--;
                if(sec<0)
                        sec=59;
                        min--;
void T1_time()interrupt 3                //中断0控制晶码管显示时间
        TH1=(65536-45872)/256;                // 重装初值
        num1++;
        if(num1==20)
                num1=0;
                time_fmq++;
                if(time_fmq>=4)
                        FMQ=1;
                        FMQ=0;
