查看: 3233|回复: 0
51单片机pwm测试源程序
ID:378322 发表于 2018-7-24 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg52.h"
#include "main.h"
#include "distance_measure.h"
#define TIMER_DELAY                (500) //定时器定时500us=0.5ms
uint counter = 0;                   //计数
uchar PWM[4]={8,8,8,8};
uchar motor_max=5;                  //pwm最大值
//四路马达
//    1   3
//          2          4
sbit ENA = P1^5;
sbit motor1 = P1^4;
sbit motor2 = P1^3;
sbit motor3 = P1^2;
sbit motor4 = P1^1;
sbit ENB = P1^0;
//STC89系列单片机延时1ms
void delay_ms(unsigned int x)
        char j=0;
        while(x--)
                for(j=0;j<125;j++)
//定时器初始化
void timer_init()
    //AUXR &= 0x7F;                //定时器时钟12T模式
    TMOD &= 0xF0;                //设置定时器模式:定时器0方式1
        TMOD |= 0x01;                //设置定时器模式:定时器0方式1
        EA=1;                                   //开总中断
        TH0=(65535-TIMER_DELAY)/256;   //设置初值
        TL0=(65535-TIMER_DELAY)%256;
        ET0=1;                                   //启用定时器中断
        TR0=1;                                   //开启
//T0中断服务子程序
void timer0_isr() interrupt 1
        TH0=(65535-TIMER_DELAY)/256;                //重新赋值
        counter ++;
        //计数累加1ms清零
        if(counter == 20)
                counter = 0;
        //比较输出PWM
        motor1 = PWM[0] > counter;
        motor2 = PWM[1] > counter;
        motor3 = PWM[2] > counter;
        motor4 = PWM[3] > counter;
void motor_up()                                 //前进
        PWM[0]=motor_max;
        PWM[1]=0;
        PWM[2]=motor_max;
        PWM[3]=0;
void motor_stop()                   //后退
        PWM[0]=0;
        PWM[1]=motor_max;
        PWM[2]=0;
        PWM[3]=motor_max;
void motor_left()                   //左转
        PWM[0]=motor_max;
        PWM[1]=0;
        PWM[2]=0;
        PWM[3]=0;
void motor_right()                  //右转
        PWM[0]=0;
        PWM[1]=0;
        PWM[2]=motor_max;
        PWM[3]=0;
        timer_init();         //定时器初始化
        ENA=1;
        ENB=1;
        motor_up();
                if(get_distance() <= 50)                 //判断是否有障碍物
                        delay_ms(10);                                //消抖
                        if(get_distance() <= 50)   //确实有障碍物
                                motor_left();
                                delay_ms(500);
                        motor_up();
