查看: 1586|回复: 1
关于红外遥控控制问题
ID:356940 发表于 2018-7-27 09:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5黑币
我想实现按一下遥控器,在16×16点阵上显示一个字,但是我得按很久才按出字来,按出字后一切正常(按一下显示一个字)。
代码如下:
#include<reg51.h>
#include<intrins.h>
sbit SIGNAL=P3^2;                                           //控制遥控接收数据信号
sbit SRCLK=P3^6;                                           //74HC595模拟SRCLK管脚
sbit RCLK=P3^5;                                                   //74HC595模拟RCK管脚
sbit SER=P3^4;                                                   //74HC595模拟SER管脚
#define uint unsigned int
#define A 3000
uchar p=0;                                                           //先把p赋值为0
uchar value[6];                                                   //用以红外接收用户码数据码数组
uchar time;                                                           //时间变量用以红外接收
void delay10us(void)   // 10us
    unsigned char a,b;
    for(b=1;b>0;b--)
        for(a=2;a>0;a--);
void delay100us(void)   // 100us
    unsigned char a,b;
    for(b=1;b>0;b--)
        for(a=47;a>0;a--);
void delay7ms(void)   // 7ms
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=26;b>0;b--)
            for(a=133;a>0;a--);
void delay(uchar i)
        while(i--);
uchar code tablewei[]=                                  //16×16点阵位选
  0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80
uchar code tableduan1[]={                          //16×16点阵段选
/*--  文字:  祝  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x08,0x08,0x89,0xEE,0x98,0x00,0x7E,0x42,0xC2,0x42,0x42,0xC2,0x42,0x7E,0x00,0x00,
0x02,0x01,0x00,0xFF,0x80,0x43,0x20,0x18,0x07,0x00,0x00,0x3F,0x40,0x40,0x78,0x00,
uchar code tableduan2[]={
/*--  文字:  你  --*/
0x00,0x80,0x60,0xF8,0x07,0x40,0x20,0x18,0x0F,0x08,0xC8,0x08,0x08,0x28,0x18,0x00,
0x01,0x00,0x00,0xFF,0x00,0x10,0x0C,0x03,0x40,0x80,0x7F,0x00,0x01,0x06,0x18,0x00,
uchar code tableduan3[]={
/*--  文字:  生  --*/
0x80,0x40,0x30,0x1E,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0x10,0x10,0x00,0x00,
0x40,0x40,0x42,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x42,0x42,0x40,0x40,0x00,
uchar code tableduan4[]={
/*--  文字:  日  --*/
0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x00,0x00,0x00,0x00,
uchar code tableduan5[]={
/*--  文字:  快  --*/
0x00,0xE0,0x00,0xFF,0x10,0x20,0x08,0x08,0x08,0xFF,0x08,0x08,0xF8,0x00,0x00,0x00,
0x01,0x00,0x00,0xFF,0x00,0x81,0x41,0x31,0x0D,0x03,0x0D,0x31,0x41,0x81,0x81,0x00,
uchar code tableduan6[]={
/*--  文字:  乐  --*/
0x00,0x00,0xE0,0x9C,0x84,0x84,0x84,0xF4,0x82,0x82,0x83,0x82,0x80,0x80,0x00,0x00,
0x00,0x20,0x10,0x08,0x06,0x40,0x80,0x7F,0x00,0x00,0x02,0x04,0x08,0x30,0x00,0x00,
void Hc595SendByte(uchar dat1,uchar dat2,uchar dat3,uchar dat4)                        //74HC595芯片扩展显示汉字函数
        uchar a;
        SRCLK = 1;
        RCLK = 1;
        for(a=0;a<8;a++)                 //发送8位数
                SER = dat1 >> 7;                 //从最高位开始发送
                dat1 <<= 1;
                SRCLK = 0;                         //发送时序
                _nop_();
                _nop_();
                SRCLK = 1;
                SER = dat2 >> 7;                 //从最高位开始发送
                dat2 <<= 1;
                SRCLK = 0;                         //发送时序
                _nop_();
                _nop_();
                SRCLK = 1;
                SER = dat3 >> 7;                 //从最高位开始发送
                dat3 <<= 1;
                SRCLK = 0;                         //发送时序
                _nop_();
                _nop_();
                SRCLK = 1;
                SER = dat4 >> 7;                 //从最高位开始发送
                dat4 <<= 1;
                SRCLK = 0;                         //发送时序
                _nop_();
                _nop_();
                SRCLK = 1;
        RCLK = 0;
        _nop_();
        _nop_();
        RCLK = 1;
void init()                         //为红外遥控初始化
  IT0=1;
  EX0=1;
  EA=1;
  SIGNAL=1;
  uchar i;                        //动态显示16×16点阵显示汉字
  init();
  while(p==5)                //按下遥控按钮触发p+=5
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan1[16+i],tableduan1[i]);                   //显示'祝'
   delay(10);
  while(p==10)
   delay(A);
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan2[16+i],tableduan2[i]);
   delay(10);
  while(p==15)
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan3[16+i],tableduan3[i]);
   delay(10);
  while(p==20)
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan4[16+i],tableduan4[i]);
   delay(10);
  while(p==25)
   delay(A);
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan5[16+i],tableduan5[i]);
   delay(10);
  while(p==30)
   for(i=0;i<16;i++)
   Hc595SendByte(~tablewei[i+16],~tablewei[i],tableduan6[16+i],tableduan6[i]);
   delay(10);
void Read_Signal() interrupt 0                  //外部中断函数用以接收遥控数据
  uchar i,j;
  uint count;
  time=0;
  delay7ms();
  if(SIGNAL==0)
    count =1000;
    while((SIGNAL==0)&&(count>0))         //>9ms
          delay10us();
          count--;
        if(SIGNAL==1)
        count=500;
        while((SIGNAL==1)&&(count>0))          //>4.5ms
          delay10us();
          count--;
                  for(j=0;j<4;j++)
             for(i=0;i<8;i++)
                   count=60;
                     delay10us();
                         count--;
                   count=500;
                   delay100us();
                   time++;
                   count--;
                   if(time>30)
                     return;
                   value[j]>>=1;
                   if(time>=8)
                   value[j]|=0x80;
                   time=0;
        if(value[2]!=~value[3])
         return;
        delay(A);
        p=p+5;        /*按一下遥控触发p+5*/
ID:356940 发表于 2018-7-27 09:55 | 只看该作者
A是用来消抖的,我试过将A设置成(800~3000)都无法解决问题,不知道问题出在哪,求助~!
