查看: 23871|回复: 26
基于stm32的二维码识别源码程序(含详细注释),二维码硬解码,非常详细
ID:283449 发表于 2018-7-29 20:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本设计基于STM32F429单片机配合OV5642 摄像头实现二维码识别的KEIL 程序,现上传分享给大家。非常有工程参考价值。
  1. /**
  2.   * @file    main.c
  3.   * @author  WB R&D Team - openmcu666
  4.   * @version V0.1
  5.   * @date    2016.08.24
  6.   * @brief   Main Program body
  7.   */
  8. #include "stm32f4xx.h"
  9. #include "Gpio.h"
  10. #include "usart.h"
  11. #include "delay.h"
  12. #include "stm32f429i_lcd.h"
  13. #include "ov7670.h"
  14. #include "ov2640.h"
  15. #include "ov5642.h"
  16. #include "mt9d111.h"
  17. #include "CamConfig.h"
  18. #include "sccb_bus.h"
  19. #include "RTC.h"
  20. #include "string.h"
  21. #include "QR_Decoder.h"
  22. //only for OV5642
  23. /*****************************************************************************
  24. **   Main Function  main()
  25. ******************************************************************************/
  26. int main(void)
  27. {
  28.         uint16_t temper;
  29.         char  qr_type_len=0;
  30.   short qr_data_len=0;
  31.   char qr_type_buf[10];
  32.   char qr_data_buf[512];
  33.   int addr=0;
  34.   int i=0,j=0;
  35.   char qr_num=0;
  36.         USART1_Init();
  37.         //LED_Init();
  38.   Key_Init();
  39.         BEEP_Init();
  40.         printf("\r\n");
  41.         printf("Hello Welcome.\r\n");
  42.         printf("Thank You For Choosing Our Products.\r\n");
  43.         printf("Thank You Very Much.\r\n");
  44.         printf("This Example Camera.\r\n");
  45.         printf("\r\n");
  46.         printf("DCMI Initialization...\r\n");
  47.         LCD_Init();
  48.         LCD_LayerInit();
  49.   LTDC_Cmd(ENABLE);
  50.   LCD_SetLayer(LCD_BACKGROUND_LAYER);
  51.         LCD_SetTransparency(0xFF);
  52.         LCD_Clear(BLACK);
  53.         LCD_SetLayer(LCD_FOREGROUND_LAYER); //使用前景层
  54.   LCD_SetTransparency(0xFF);          //设置透明度
  55.   LCD_Clear_ARGB8888(0x40000000);
  56.   LCD_SetTextColor_ARGB8888(0xFFFFFFFF);
  57.   LCD_DrawFullRect_ARGB8888(Frame_Width,Frame_Width);                              //绘制透明框
  58.   LCD_DrawBox_ARGB8888(Frame_Width,Frame_Line_Length,Frame_Line_Size,0xD05CBDE7);  //绘制扫描框
  59.         printf("Ok,Let's Go...\r\n");
  60.         temper = ov7670_check();         //Camera是否为OV7670
  61.         if (temper == 0x7673)
  62.         {
  63.                 printf("Cam ID : [0x%02x]\r\n",temper);
  64.                 if (ov7670_init())
  65.                 {
  66.                         printf("Init OV7670 reg Fail...\r\n");
  67.                   while (1)
  68.                   {
  69.                   }
  70.                 }
  71.                 else
  72.                 {
  73.                         printf("Init OV7670 reg OK...\r\n");
  74.                         printf("Show Camer Data...\r\n");
  75.                 }
  76.         }
  77.         else
  78.         {
  79.     temper=ov2640_check();
  80.                 if(temper==0x2642)                        //OV2640
  81.                 {
  82.                         if (ov2640_init())
  83.                   {
  84.                         printf("Init OV2640 reg Fail...\r\n");
  85.                         while (1)
  86.                         {}
  87.                   }
  88.                   else
  89.                  {
  90.                         printf("Cam ID : [0x%02x]\r\n",temper);
  91.                         printf("Init OV2640 reg OK...\r\n");
  92.                         printf("Show Camer Data...\r\n");
  93.                  }
  94.          }
  95.                 else                                        //ov5642 or mt9d111
  96.     {
  97.                         temper=ov5642_check();
  98.                         printf("Cam ID : [0x%02x]\r\n",temper);
  99.                   if (temper==0x5642)//mt9d111_init
  100.                   {
  101.                           ov5642_init();
  102.                           printf("Init ov5642 reg OK...\r\n");
  103.                           printf("Show Camer Data...\r\n");
  104.                   }
  105.                  else
  106.                  {
  107.                           printf("Init ov5642 reg Fail...\r\n");
  108.                                 while (1){}
  109.                  }
  110.     }
  111.         }
  112. //        if(RTC_Config())                                                           //初始化RTC
  113. //        {
  114. //          printf("\r\nLSE start failed\r\n");
  115. //        }
  116. //        RTC_Set_WakeUp(RTC_WakeUpClock_CK_SPRE_16bits,0);                //配置WAKE UP中断,1秒钟中断一次,用于统计帧率
  117.   systick_delay_ms(100);
  118.         ov5642_auto_focus();
  119.         cam_start();
  120.         while (1)
  121.   {
  122.     qr_num = QR_decoder();
  123.                  if(qr_num)
  124.       {
  125.          GPIO_SetBits(BEEP_GPIO_PORT,BEEP_GPIO_PIN);
  126.                                  systick_delay_ms(100);
  127.                                  GPIO_ResetBits(BEEP_GPIO_PORT,BEEP_GPIO_PIN);
  128.          //解码的数据是按照识别条码的个数封装好的二维数组,这些数据需要
  129.          //根据识别条码的个数,按组解包并通过串口发送到上位机串口终端
  130.          for(i=0;i < qr_num;i++)
  131.          {
  132.            qr_type_len = decoded_buf[i][addr++];//获取解码类型长度
  133.             for(j=0;j < qr_type_len;j++)
  134.                  qr_type_buf[j]=decoded_buf[i][addr++];//解码类型
  135.              qr_data_len  = decoded_buf[i][addr++]<<8; //解码数据的高8位
  136.              qr_data_len |= decoded_buf[i][addr++];    //解码数据的低8位
  137.              for(j=0;j < qr_data_len;j++)
  138.                  qr_data_buf[j]=decoded_buf[i][addr++];//获取解码数据
  139.              USART1_Send_Data((unsigned char *)qr_type_buf, qr_type_len);//串口发送解码类型
  140.              USART1_Send_Data((unsigned char *)":", 1);
  141.              USART1_Send_Data((unsigned char *)qr_data_buf, qr_data_len);//串口发送解码数据
  142.              USART1_Send_Data((unsigned char *)"\r\n", 2);
  143.              addr =0;
  144.           }
  145.        }
  146.   }
  147. }
STM32二维码识别源码资料.rar
1.14 MB, 下载次数: 706, 下载积分: 黑币 -5
基于stm32的二维码解码识别源码
收藏收藏21 分享淘帖 顶2 踩
ID:364328 发表于 2018-7-30 11:14 | 只看该作者
请问一下识别二维码是识别出啥啊,还有F103能做不
ID:166329 发表于 2018-8-21 09:28 | 只看该作者
最近在学习这个
ID:388329 发表于 2018-9-2 22:18 | 只看该作者
有意思的程序
ID:392843 发表于 2018-9-3 10:26 | 只看该作者
实用!正在找这资料。
ID:86450 发表于 2018-9-3 16:36 | 只看该作者
最近在学习这个
ID:377348 发表于 2018-10-16 17:04 | 只看该作者
为啥我打不开
ID:433680 发表于 2018-12-11 12:25 | 只看该作者
这个不错,正在找这资料。感谢楼主分享
ID:515384 发表于 2019-4-20 22:08 | 只看该作者
F103,ov7725可以用吗
ID:373 发表于 2019-5-20 15:49 | 只看该作者
看能不能移植到其他单片机系统中去
ID:565449 发表于 2019-7-1 18:07 | 只看该作者
请问你做出来了吗
ID:481408 发表于 2019-8-27 10:57 | 只看该作者
好东西啊
ID:580667 发表于 2019-9-18 17:04 | 只看该作者
学习一下
ID:166442 发表于 2019-11-1 11:46 | 只看该作者
qrcode是库形式
ID:473410 发表于 2019-11-3 17:08 | 只看该作者
littleboy233 发表于 2019-4-20 22:08
F103,ov7725可以用吗
F103带不动摄像头
F103带不动摄像头
ID:392673 发表于 2019-11-18 16:14 | 只看该作者
有原理图吗
ID:578659 发表于 2019-11-30 10:59 | 只看该作者
学习支持
ID:600674 发表于 2019-12-15 14:40 | 只看该作者
非常棒,非常感谢!
ID:658347 发表于 2019-12-21 21:49 | 只看该作者
真不错,下载下来看看
ID:41233 发表于 2020-2-27 14:21 | 只看该作者
看看库的使用
ID:715359 发表于 2020-3-25 12:31 | 只看该作者
你好,请问可以麻烦再详细解析一下吗?
ID:553985 发表于 2020-5-15 16:07 | 只看该作者
编译都过不去,缺少文件啊
ID:378085 发表于 2020-5-18 18:24 | 只看该作者
感谢楼主分享 研究一下
ID:427723 发表于 2020-11-16 15:59 | 只看该作者
stm32f407+ov2640能否借鉴移植,调用解码库,谢谢
ID:441129 发表于 2021-7-14 09:57 | 只看该作者
ID:992285 发表于 2023-9-21 14:43 | 只看该作者
感谢分享,最近研究这个,准备用是他们2f407,谢谢!
