查看: 7602|回复: 2
51单片机 1602LCD简单时钟显示实验
ID:318620 发表于 2018-7-30 17:28 | 显示全部楼层 |阅读模式
#include "reg52.h"
sbit RW=P2^1;
sbit RS=P2^0;
sbit E=P2^2;
bit at=0;
uchar code shen[]={"CLOCK!"};
uchar code word[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x20};
uchar dispbuf[8],h,m,s,counter;
void delay()
  uchar i;
for(i=0;i<255;i++);
/*******写命令**********/
void lcd_wmc(uchar i)
  P0=i;
  RS=0;
  RW=0;
  E=0;
  delay();
  E=1;
/*******写数据***********/
void lcd_wmd(uchar i)
  P0=i;
  RS=1;
  RW=0;
  E=0;
  delay();
  E=1;
/*******初始化液晶*******/
void lcd_init()
  uchar i;
  lcd_wmc(0x01);
  lcd_wmc(0x38);
  lcd_wmc(0x0c);
  lcd_wmc(0x06);
  lcd_wmc(0xc9);
  for(i=0;i<6;i++)
  lcd_wmd(shen[i]);
  lcd_wmc(0xc0);
/*******更新缓冲区子程序*******/
void newbuf()
dispbuf[0]=s%10;
dispbuf[1]=s/10;
dispbuf[3]=m%10;
dispbuf[4]=m/10;
dispbuf[6]=h%10;
dispbuf[7]=h/10;
/*******显示子程序**********/
void disp(uchar dispadd)
   uchar tmp;
   lcd_wmc(dispadd);
   tmp=dispbuf[7];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[6];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[5];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[4];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[3];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[2];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[1];
   tmp=word[tmp];
   lcd_wmd(tmp);
   tmp=dispbuf[0];
   tmp=word[tmp];
   lcd_wmd(tmp);
/*********************键盘子程序***********************/
uchar keypro(void)
  uchar scanl,scanh;
  P1=0x0f;//先将所有行线拉低
  if((P1&0x0f)!=0x0f) //如果列线有变化
    delay();//延迟一段时间。
    if((P1&0x0f)!=0x0f)//如果此时此刻列线还有变化,说明确实有按键按下
      scanl=0xfe;
      while((scanl&0x10)!=0)
        P1=scanl; //给P1口赋扫描码,每次只拉低一行
        if((P1&0xf0)!=0xf0) //如果判断为真,则说明找到了按键按下的行
          scanh=(P1&0xf0)|0x0f; //计算识别码
          return (~scanh)+(~scanl);
        else scanl=(scanl<<1)|0x01; //否则依次将第二,第三,第四行拉低
  return 0;//没有按键  按下 返回0
/********************时间调整子程序********************/
void adjustime()
  uchar k;
  static uchar add;
  k=keypro();
  switch(k)
   case 0x88: if(!at){add=0xc1;EA=0;lcd_wmc(0xc1);lcd_wmc(0x0f);at=1;}
               else {lcd_wmc(0xc0);lcd_wmc(0x0c);at=0;EA=1;} break;
   case 0x48:  if(at)
       if(add==0xc1){add=0xc7; lcd_wmc(add);}
                 else {add=add-3;lcd_wmc(add);}
         break;
  case 0x28:  if(at)
               if(add==0xc7) {add=0xc1;lcd_wmc(add);}
                 else {add=add+3;lcd_wmc(add);}
       break;
   case 0x18: if(at)
              if(add==0xc1) h++;
                if(h==24)
          h=0;
                if(add==0xc4) m++;
         if(m==60)
           m=0;
                if(add==0xc7) s++;
          if(s==60)
           s=0;
           newbuf();
      disp(0xc0);
      lcd_wmc(add);
               break;
  default: break;
  if(k!=0)
  while((P1&0xf0)!=0xf0)
  P1=0xf0;
/*********************初始化子程序**********************/
void init()
  TMOD=0x01;
  TH0=0x4c;
  TL0=0x00;
  EA=1;
  ET0=1;
  TR0=1;
  counter=0;
  h=12;m=0;s=0;
  dispbuf[2]=10;
  dispbuf[5]=10;
/***************************主程序************************/
void main(void)
  init();
  lcd_init();
   adjustime();
   if(!at)
     //闪烁
      if(counter<10)
       dispbuf[2]=10;
       dispbuf[5]=10;
       dispbuf[2]=11;
       dispbuf[5]=11;
      //更新显示缓冲区及调用显示程序
      if(counter==0)
       newbuf();
       disp(0xc0);
      else if(counter==10)
      disp(0xc0);
/*************************定时器0的中断**********************/
void Time0() interrupt 1 using 2    //再次强调中断子程序执行时间越短越好
  TH0=(65536-46075)/256;
  TL0=(65536-46075)%256;
  counter++;
  if(counter==20)
    s++;
  counter=0;
  if(s==60)
    m++;
    s=0;
      if(m==60)
      h++;
    m=0;
    if(h==24)
     h=0;
1602LCD简单时钟显示实验.rar
19.38 KB, 下载次数: 39, 下载积分: 黑币 -5
ID:587108 发表于 2019-11-10 12:43 | 显示全部楼层
帮助很大
ID:766704 发表于 2020-6-3 09:58 | 显示全部楼层
多谢多谢
