查看: 15065|回复: 5
STM32F103使用U8G2库
U8G2软件库在OLED、lcd等模块中使用非常的方便,支持的型号也比较多,不用自己每次写自己的显示屏驱动程序,下面介绍下载stm32上使用U8G2库进行一些图形和文字的显示。
首先要下载好U8G2的库,此处在附件中就可以下载到(库和完整工程代码请到零知原贴中下载)。下载到附件后,我们主要在u8g_arm.c中根据模板写出跟我们硬件相关的接口即可,下面以SSD1306,使用4线方式的OLED接口为例。
我们把下载的库放到我们的工程目录下,然后在keil中添加到工程,然后我们在u8g_arm.c文件中编写如下代码:
  1. uint8_t u8g2_gpio_and_delay_stm32(U8X8_UNUSED u8x8_t *u8x8, U8X8_UNUSED uint8_t msg, U8X8_UNUSED uint8_t arg_int, U8X8_UNUSED void *arg_ptr)
  2. {
  3.                 uint8_t delay_cnt;
  4.
  5.         switch(msg){
  6.
  7.         //Function which implements a delay, arg_int contains the amount of ms
  8.         case U8X8_MSG_GPIO_AND_DELAY_INIT:
  9.
  10.         //oled_gpio_init();
  11.                 oled_io_config();
  12.
  13.         break;
  14.         //Function which implements a delay, arg_int contains the amount of ms
  15.         case U8X8_MSG_DELAY_MILLI:
  16.         delay_ms(arg_int);
  17.         break;
  18.         //Function which delays 10us
  19.         case U8X8_MSG_DELAY_10MICRO:
  20.         delay_us(10);
  21.         break;
  22.         //Function which delays 100ns
  23.         case U8X8_MSG_DELAY_100NANO:
  24.         //__NOP();
  25.                 {
  26.                         delay_cnt = 0;
  27.                         while(delay_cnt++<10);
  28.                 }
  29.
  30.         break;
  31.         //Function to define the logic level of the clockline
  32.         case U8X8_MSG_GPIO_SPI_CLOCK:
  33.             if (arg_int) OLED_SCL = 1;
  34.             else OLED_SCL = 0;
  35.
  36.         break;
  37.         //Function to define the logic level of the data line to the display
  38.         case U8X8_MSG_GPIO_SPI_DATA:
  39.             if (arg_int) OLED_SDA = 1;
  40.             else OLED_SDA = 0;
  41.
  42.         break;
  43.
  44.         // Function to define the logic level of the CS line
  45.         case U8X8_MSG_GPIO_CS1:
  46.
  47.         break;
  48.         //Function to define the logic level of the Data/ Command line
  49.         case U8X8_MSG_GPIO_DC:
  50.                         if(arg_int) OLED_DC = 1;
  51.                         else OLED_DC = 0;
  52.
  53.         break;
  54.         //Function to define the logic level of the RESET line
  55.         case U8X8_MSG_GPIO_RESET:
  56.             if (arg_int) OLED_RS = 1;
  57.             else OLED_RS = 0;
  58.
  59.         break;
  60.
  61.         default:
  62.             return 0; //A message was received which is not implemented, return 0 to indicate an error
  63.     }
  64.
  65.     return 1; // command processed successfully.
  66. }
这个就是定义好硬件上连接gpio和延时的操作接口 。此处我们使用的是模拟spi方式,没有使用硬件SPI接口,因此使用自带的操作接口u8x8_byte_4wire_sw_spi就可以了,不用自己实现。然后我们在main中就可以调用跟我们相关的型号就可以操作OLED了,我这里调用u8g2_Setup_ssd1306_128x64_noname_f这个接口,实际情况要根据我们的显示屏的型号来选择了。我们就可以看到如下的显示效果,非常的方便:
收藏收藏2 分享淘帖 顶 踩
ID:349555 发表于 2018-8-2 00:28 | 只看该作者
下一步准备移植到我们零知平台上
ID:164108 发表于 2019-1-27 16:39 | 只看该作者
你好,请问内存不够你是怎么解决的?
ID:388109 发表于 2019-3-9 23:54 | 只看该作者
好,试下
ID:443931 发表于 2019-10-23 16:41 | 只看该作者
请问有12864的吗
ID:29751 发表于 2020-7-18 17:36 | 只看该作者
请问附件在哪里下载,谢谢
