文件列表:
QN8027资料汇总整理。
QN8025_27软件硬件开发疑难解答FAQ V0 12.pdf
qn8027_m1.rar
QN8027_SANB Hardware Application Note_V_0 25_102209.pdf
QN8027_SANC_Datasheet_v1.1_041810.pdf
QN8027常见问题解答2011.pdf
正确的QN8027初始化程序20090723.pdf
调频发射接收芯片QN8027的单片机源程序如下:
- #include "qndriver.h"
- extern UINT8 QND_ReadReg(UINT8 adr);
- extern UINT8 QND_WriteReg(UINT8 adr, UINT8 value);
- #define R_TXRX_MASK 0x20
- UINT8 qnd_Crystal = QND_CRYSTAL_DEFAULT;
- UINT8 qnd_PrevMode;
- UINT8 qnd_Country = COUNTRY_CHINA ;
- UINT16 qnd_CH_START = 7600;
- UINT16 qnd_CH_STOP = 10800;
- UINT8 qnd_CH_STEP = 1;
- void QNF_SetRegBit(UINT8 reg, UINT8 bitMask, UINT8 data_val)
- Description: set register specified bit
- Parameters:
- reg: register that will be set
- bitMask: mask specified bit of register
- data_val: data will be set for specified bit
- Return Value:
- None
- UINT8 temp;
- temp = QND_ReadReg(reg);
- temp &= (UINT8)(~bitMask);
- temp |= data_val & bitMask;
- // temp |= data_val;
- QND_WriteReg(reg, temp);
- UINT16 QNF_GetCh()
- Description: get current channel frequency
- Parameters:
- None
- Return Value:
- channel frequency
- UINT8 tCh;
- UINT8 tStep;
- UINT16 ch = 0;
- // set to reg: CH_STEP
- tStep = QND_ReadReg(CH_STEP);
- tStep &= CH_CH;
- ch = tStep ;
- tCh= QND_ReadReg(CH);
- ch = (ch<<8)+tCh;
- return CHREG2FREQ(ch);
- UINT8 QNF_SetCh(UINT16 freq)
- Description: set channel frequency
- Parameters:
- freq: channel frequency to be set
- Return Value:
- 1: success
- // calculate ch parameter used for register setting
- UINT8 tStep;
- UINT8 tCh;
- UINT16 f;
- f = FREQ2CHREG(freq);
- // set to reg: CH
- tCh = (UINT8) f;
- QND_WriteReg(CH, tCh);
- tStep &= ~CH_CH;
- tStep |= ((UINT8) (f >> 8) & CH_CH);
- QND_WriteReg(CH_STEP, tStep);
- return 1;
- void QNF_SetAudioMono(UINT8 modemask, UINT8 mode)
- Description: Set audio output to mono.
- Parameters:
- modemask: mask register specified bit
- mode
- QND_RX_AUDIO_MONO: RX audio to mono
- QND_RX_AUDIO_STEREO: RX audio to stereo
- QND_TX_AUDIO_MONO: TX audio to mono
- QND_TX_AUDIO_STEREO: TX audio to stereo
- Return Value:
- None
- QNF_SetRegBit(SYSTEM2,modemask, mode);
- int QND_Delay()
- Description: Delay for some ms, to be customized according to user
- application platform
- Parameters:
- ms: ms counts
- Return Value:
- None
- void QND_Delay(UINT16 ms)
- UINT16 i,k;
- for(i=0; i<3000;i++)
- for(k=0; k<ms; k++)
- void QN_ChipInitialization()
- Description: chip first step initialization, called only by QND_Init()
- Parameters:
- None
- Return Value:
- None
- // reset
- QND_WriteReg(0x00,0x80);
- QND_Delay(20);
- //to be customized: change the crystal setting, according to HW design
- //recalibration
- QNF_SetRegBit(0x00,0x40,0x40);
- QNF_SetRegBit(0x00,0x40,0x00);
- QND_Delay(20); //delay 20 ms
- QND_WriteReg(0x18,0xe4); //reset
- QND_WriteReg(0x1b,0xf0);
- //Done chip recalibration
- int QND_Init()
- Description: Initialize device to make it ready to have all functionality ready for use.
- Parameters:
- None
- Return Value:
- 1: Device is ready to use.
- 0: Device is not ready to serve function.
- UINT8 QND_Init()
- QN_ChipInitialization();
- // QND_WriteReg(0x00, 0x01); //resume original status of chip /* 2008 06 13 */
- return 1;
- void QND_SetSysMode(UINT16 mode)
- Description: Set device system mode(like: sleep ,wakeup etc)
- Parameters:
- mode: set the system mode , it will be set by some macro define usually:
- SLEEP (added prefix: QND_MODE_, same as below): set chip to sleep mode
- WAKEUP: wake up chip
- TX: set chip work on TX mode
- RX: set chip work on RX mode
- FM: set chip work on FM mode
- AM: set chip work on AM mode
- TX|FM: set chip work on FM,TX mode
- RX|AM; set chip work on AM,RX mode
- RX|FM: set chip work on FM,RX mode
- Return Value:
- None
- UINT8 val;
- switch(mode)
- case QND_MODE_SLEEP: //set sleep mode
- QNF_SetRegBit(SYSTEM1, R_TXRX_MASK, 0);
- break;
- default:
- val = (UINT8)(mode >> 8);
- if (val)
- val = val >> 1;
- if (val & 0x20)
- // set to new mode if it's not same as old
- if((QND_ReadReg(SYSTEM1) & R_TXRX_MASK) != val)
- QNF_SetRegBit(SYSTEM1, R_TXRX_MASK, val);
- // make sure it's working on analog output
- QNF_SetRegBit(SYSTEM1, 0x08, 0x00);
- break;
- void QND_TuneToCH(UINT16 ch)
- Description: Tune to the specific channel. call QND_SetSysMode() before
- call this function
- Parameters:
- ch
- Set the frequency (10kHz) to be tuned,
- eg: 101.30MHz will be set to 10130.
- Return Value:
- None
- QNF_SetCh(ch);
- void QND_SetCountry(UINT8 country)
- Description: Set start, stop, step for RX and TX based on different
- country
- Parameters:
- country:
- Set the chip used in specified country:
- CHINA:
- USA:
- JAPAN:
- Return Value:
- None
- qnd_Country = country;
- switch(country)
- case COUNTRY_CHINA:
- qnd_CH_START = 7600;
- qnd_CH_STOP = 10800;
- qnd_CH_STEP = 1;
- break;
- case COUNTRY_USA:
- qnd_CH_START = 8810;
- qnd_CH_STOP = 10790;
- qnd_CH_STEP = 2;
- break;
- case COUNTRY_JAPAN:
- break;
- UINT8 QND_TXSetPower( UINT8 gain)
- Description: Sets FM transmit power attenuation.
- Parameters:
- gain: The transmission power attenuation value, for example,
- setting the gain = 0x13, TX attenuation will be -6db
- look up table see below
- BIT[5:4]
- 00 0db
- 01 -6db
- 10 -12db
- 11 -18db
- BIT[3:0] unit: db
- 0000 124
- 0001 122.5
- 0010 121
- 0011 119.5
- 0100 118
- 0101 116.5
- 0110 115
- 0111 113.5
- 1000 112
- 1001 110.5
- 1010 109
- 1011 107.5
- 1100 106
- 1101 104.5
- 1110 103
- 1111 101.5
- for example:
- 0x2f, //111111 89.5
- 0x2e, //111110 91
- 0x2d, //111101 92.5
- 0x2c, //111100 94
- 0x1f, //111011 95.5
- 0x1e, //111010 97
- 0x1d, //111001 98.5
- 0x1c, //111000 100
- 0x0f, //001111 101.5
- 0x0e, //001110 103
- 0x0d, //001101 104.5
- 0x0c, //001100 106
- 0x0b, //001011 107.5
- 0x0a, //001010 109
- 0x09, //001001 110.5
- 0x08, //001000 112
- 0x07, //000111 113.5
- 0x06, //000110 115
- 0x05, //000101 116.5
- 0x04, //000100 118
- 0x03, //000011 119.5
- 0x02, //000010 121
- 0x01, //000001 122.5
- 0x00 //000000 124
- void QND_TXSetPower( UINT8 gain)
- UINT8 value = 0;
- value |= 0x40;
8027资料.zip
(1.9 MB, 下载次数: 302)
