查看: 1630|回复: 1
在数码管显示的时候问什么没有指定的数码管会跟着各位或者十位数字变化显示,
ID:399373 发表于 2018-9-18 09:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define Data_Outport P0
sbit Lotch_Duan=P2^2;
sbit Lotch_Wei=P2^3;
sbit KEY_ADD=P3^3;
sbit KEY_DEC=P3^4;
void delay1(unsigned int t);
void delay2(unsigned int t);
void disply(unsigned char FirstBit,unsigned char Num);
unsigned char code Wei_Ma[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code Duan_Ma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char Huan_Chun[8];
void Shi_Jian(void);
{         unsigned char num=0;
    Shi_Jian();
                    if(KEY_ADD==0)
                    delay2(10);
                        if(KEY_ADD==0)
                           while(!KEY_ADD);
                                    if(num<99)
                                  num++;
                 if(KEY_DEC==0)
                    delay2(10);
                        if(KEY_DEC==0)
                           while(!KEY_DEC);
                                    if(num>0)
                                  num--;
                 Huan_Chun[0]=Duan_Ma[num/10];
                 Huan_Chun[1]=Duan_Ma[num%10];
   while(--t);
    while(t--)
     //大致延时1mS
     delay1(245);
         delay1(245);
static unsigned char i=0;
    Data_Outport=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        Data_Outport=Huan_Chun[i];
        Lotch_Duan=1;
        Lotch_Duan=0;
        Data_Outport=Wei_Ma[i+FirstBit];
        Lotch_Wei=1;
        Lotch_Wei=0;
        i++;
        if(i==Num)
            i=0;
void Shi_Jian(void)
   TMOD |=0x01;
   TH0=(65536-2000)/256;
   TL0=(65536-2000)%256;
   EA=1;
   ET0=1;
   TR0=1;
void Ding_Shi(void)interrupt 1
        disply(0,8);
ID:387733 发表于 2018-9-18 18:59 | 只看该作者
        Data_Outport=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        Lotch_Wei=1;
        Lotch_Wei=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        i++;
        if(i==Num)
            i=0;
次序换一下,先关闭段码,再设置位码,然后打开段码。否则位还没换,就打开段码,显示就错位了
参与人数 1黑币 +40 收起 理由
admin + 40 回帖助人的奖励!
