查看: 2251|回复: 1
三路循迹小车程序
ID:406145 发表于 2018-10-7 15:31 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint unsigned int
sbit IN1 = P1^0;         //P20与电机驱动IN1相连
sbit IN2 = P1^1;         //P21与电机驱动IN2相连
sbit IN3 = P1^2;         //P22与电机驱动IN3相连
sbit IN4 = P1^3;         //P23与电机驱动IN4相连
       //P00左边模块
sbit D1 = P0^0;       //P01中间模块
sbit D3 = P0^3;      //P02右边模块
sbit D6 = P0^6;
uint temp;
void left_zheng(void);
void left_fan(void);
void right_zheng(void);
void right_fan(void);
void ting(void);
void go(void);
void back(void);
void delayms(uint z);
void main(void)
// temp = P0&0xff;
if(D1 == 0 && D3 == 0 && D6 == 0)
  ting();
if(D1 == 0 && D3 == 0 && D6 == 1)
   left_zheng();
if(D1 == 0 && D3 == 1 && D6 == 0)
   go();
if(D1 == 0 && D3 == 1 && D6 == 1)
    left_zheng();
if(D1 == 1 && D3 == 0 && D6 == 0)
    right_zheng();
if(D1 == 1 && D3 == 0 && D6 == 1)
   go();
if(D1 == 1 && D3 == 1 && D6 == 0)
   right_zheng();
if(D1 == 1 && D3 == 1 && D6 == 1)
   ting();
/* switch(temp)
   case 0x00: ting();   break;
   case 0x01: right_zheng();  break;
   case 0x02: go();            break;
   case 0x03:  go();           break;
   case 0x04:  left_zheng();   break;
   case 0x05:  go();           break;
   case 0x06:  go();           break;
   case 0x07:  ting();        break;
   default:  break;
void left_zheng(void)     //IN1 = 1, IN2 = 0;反转
{             //IN1 = 0, IN2 = 1;正转
IN1 = 0;       //IN3 = 1, IN4 = 0;反转
IN2 = 0;       //IN3 = 0, IN4 = 1;正转
IN3 = 0;
IN4 = 1;
delayms(100);
void left_fan(void)
IN1 = 0;
IN2 = 0;
IN3 = 1;
IN4 = 0;
delayms(50);
IN1 = 0;
IN2 = 1;
IN3 = 0;        //IN1 = 0, IN2 = 0;制动
IN4 = 0;
delayms(100);       //IN1 = 1, IN2 = 1;制动
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 0;
delayms(50);
void go(void)
IN1 = 0;
IN2 = 1;
IN3 = 0;
IN4 = 1;
delayms(30);
void back(void)
IN1 = 1;
IN2 = 0;
IN3 = 1;
IN4 = 0;
delayms(50);
void ting(void)
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
delayms(50);
uint i,j;
for(i = 0; i < z; i++)
  for(j = 0; j < 110; j++);
ID:1 发表于 2018-10-7 17:03 | 显示全部楼层
补全原理图或者详细说明一下电路连接即可获得100+黑币
