查看: 2881|回复: 0
NodMCU的例子程序,端口接LED闪烁
ID:137736 发表于 2018-10-14 09:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  NodMCU的例子程序,测试输出口,接LED可闪烁。
ESP8266核心
// the setup function runs once when you press reset or power the board
void setup() {
  // initialize digital pin 13 as an output.
  pinMode(D0, OUTPUT);  //USER
  pinMode(D1, OUTPUT);
  pinMode(D2, OUTPUT);
  pinMode(D3, OUTPUT);  //FLASH
  pinMode(D4, OUTPUT);  //TXD1,BlueLED
  pinMode(D5, OUTPUT);
  pinMode(D6, OUTPUT);
  pinMode(D7, OUTPUT);  //RXD2
  pinMode(D8, OUTPUT);  //TXD2
  pinMode(D9, OUTPUT);  //RXD0
  pinMode(D10, OUTPUT); //TXD0
// the loop function runs over and over again forever
void loop() {
  digitalWrite(D0, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);              // wait for a second
  digitalWrite(D0, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D1, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D1, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D2, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D2, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D3, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D3, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D4, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D4, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D5, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D5, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D6, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D6, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D7, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D7, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D8, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D8, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D9, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D9, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D10, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D10, LOW);    // turn the LED off by making the voltage LOW
