查看: 4163|回复: 0
单片机键盘与按键中断仿真实验
ID:300927 发表于 2018-10-18 19:06 | 显示全部楼层 |阅读模式
4X4键盘(中断方式),当K1键按下后,首先使蜂鸣器响一声,然后使LED1-LED8完成3种闪亮的花样(自己定义),每一种花样循环3次,然后周而复始。
  1. #include <reg51.h>
  2. sbit P3_7=P3^7;
  3. sbit P3_3=P3^3;
  4. char key=0;
  5. char sign=0;
  6. void delay(long time)
  7. {
  8.         char i=0;
  9.         while(time--)
  10.         for(i=0;i<125;i++);
  11. }
  12. void delay1(long time)
  13. {
  14.         char i=0;
  15.         while(time--)
  16.         for(i=0;i<125;i++);
  17. }
  18. void onbuz()
  19. {
  20.         P3_7=1;
  21.         delay(100);
  22.         P3_7=0;
  23. }
  24. void kind1()
  25. {
  26.         char i=0;
  27.         char data1[2]={0x0f,0xf0};
  28.         for(i=0;i<2;i++)
  29.         {
  30.                 P0=data1[i];
  31.                 delay(200);
  32.         }
  33.         P0=0xff;
  34. }
  35. void kind2()
  36. {
  37.         char i=0;
  38.         char data2[4]={0x03,0x0c,0x30,0xc0};
  39.         for(i=0;i<4;i++)
  40.         {
  41.                 P0=data2[i];
  42.                 delay(200);
  43.         }
  44.         P0=0xff;
  45. }
  46. void kind3()
  47. {
  48.         char i=0;
  49.         char data3[4]={0x81,0x42,0x24,0x18};
  50.         for(i=0;i<2;i++)
  51.         {
  52.                 P0=data3[i];
  53.                 delay(200);
  54.         }
  55.         P0=0xff;
  56. }
  57. void run()
  58. {
  59.         char i;
  60.         while(sign==0)
  61.         {
  62.                 onbuz();
  63.                 for(i=0;i<3;i++)
  64.                 {
  65.                         kind1();
  66.                 }
  67.                 for(i=0;i<3;i++)
  68.                 {
  69.                         kind2();
  70.                 }
  71.                 for(i=0;i<3;i++)
  72.                 {
  73.                         kind3();
  74.                 }
  75.         }
  76. }
  77. void run1()
  78. {
  79.         char i;
  80.         while(sign==0)
  81.         {
  82.                 onbuz();
  83.                 for(i=0;i<3;i++)
  84.                 {
  85.                         kind1();
  86.                 }
  87.         }
  88. }
  89. void keyon() interrupt 0
  90. {
  91.         char num_l,num_h,num;
  92.         if(P1!=0xf0)
  93.         {
  94.                 delay1(100);
  95.                 if(P1!=0xf0)
  96.                 {
  97.                         P1=0xf0;
  98.                         num_h=P1^0xf0;
  99.                         P1=0x0f;
  100.                         num_l=P1^0x0f;
  101.                         num=num_h+num_l;
  102.                 }
  103.         }
  104.         P1=0xf0;
  105.         switch(num)
  106.                 {
  107.                         case 0x11:break;
  108.                         case 0x12:break;
  109.                         case 0x14:break;
  110.                         case 0x18:break;
  111.                         case 0x21:
  112.                                 key=num;
  113.                                 break;
  114.                         case 0x22:
  115.                                 key=num;
  116.                                 break;
  117.                         case 0x24:break;
  118.                         case 0x28:break;
  119.                         case 0x41:break;
  120.                         case 0x42:break;
  121.                         case 0x44:break;
  122.                         case 0x48:break;
  123.                         case 0x81:break;
  124.                         case 0x82:break;
  125.                         case 0x84:break;
  126.                         case 0x88:break;
  127.                 }
  128.         sign=0;
  129. }
  130. void keyoff() interrupt 2
  131. {
  132.         P0=0xff;
  133.         P1=0xf0;
  134.         sign=1;
  135. }
  136. void main()
  137. {
  138.         P3_7=0;
  139.         P1=0xf0;
  140.         EA=1;
  141.         EX0=1;
  142.         EX1=1;
  143.         TCON=0x05;
  144.         while(1)
  145.         {
  146.                 P1=0xf0;
  147.                 if(key==0x21)
  148.                 {
  149.                         run();
  150.                 }
  151.                 if(key==0x22)
  152.                 {
  153.                         run1();
  154.                 }
  155.         }
  156. }
实 验 三.rar (61.47 KB, 下载次数: 22)
参与人数 1黑币 +10 收起 理由
wyhnb + 10
