查看: 2244|回复: 1
蓝牙小车,可控制机械臂可控制车方向的程序(手机程序或者上位机程序自己编写)
ID:336427 发表于 2018-10-19 02:40 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
//          HAL_UART_Transmit_DMA(&huart1, "start\r\n",7);
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
                  if(UsartType.RX_flag)            // Receive flag
                        UsartType.RX_flag=0;        // clean flag
                        HAL_UART_Transmit(&huart2, UsartType.RX_pData, UsartType.RX_Size, 0xFFFF);
                //用led控制爪子也就是6号舵机的开关
                //用蜂鸣器控制形态的切换
                switch(UsartType.RX_pData[0])
                        //进入控制舵机的指令
                        case 0x21:
                                yunxing_flag = 0;
                                che_flag = 0;
                                break;
                        //进入车的运行指令
                        case 0x20:
                                yunxing_flag = 1;
                                break;
                        case 0x30:
//                                yunxing_flag = 1;
                                che_flag = 1;
                                break;
                        case 0x3f:
                                che_flag = 2;
                                break;
                        case 0x31:
                                che_flag = 3;
                                break;
                        case 0x32:
                                che_flag = 4;
                                break;
                        //爪子开
                        case 0x11:
                                che_flag = 5;
                                break;
                        //爪子关
                        case 0x10:
                                che_flag = 6;
                                break;
                        case 0xff:
                                che_flag = 0;
                                break;
//车运行程序
                if(yunxing_flag==1&&che_flag==1)
                        PWM_Change_Duty(80,0,80,0);
                if(yunxing_flag==1&&che_flag==2)
                        PWM_Change_Duty(0,80,0,80);
                if(yunxing_flag==1&&che_flag ==3)
                        PWM_Change_Duty(70,0,0,70);
                if(yunxing_flag==1&&che_flag == 4)
                        PWM_Change_Duty(0,70,70,0);
                if(che_flag==0||yunxing_flag == 0)
                        PWM_Change_Duty(0,0,0,0);
//                HAL_Delay(100);
//舵机运行函数
#if 1
                if(yunxing_flag==0&&che_flag==1)
                        UsartType.RX_pData[0] = '\0';
                        if(j>10)
                                j --;
                                j++;
                        HAL_UART_Transmit_IT(&huart1,&ErHao[j][18],strlen(&ErHao[j][18]));
                        HAL_Delay(100);
                if(yunxing_flag==0&&che_flag==2)
                        if(j<72)
                                j ++;
                                j--;
                        HAL_Delay(100);
                //四号舵机动作的左和右
                if(yunxing_flag==0&&che_flag ==3)
                        if(l<35)
                                l++;
                                l--;
                        HAL_UART_Transmit_IT(&huart1,&SiHao[l][18],strlen(&SiHao[l][18]));
                        HAL_Delay(100);
                if(yunxing_flag==0&&che_flag == 4)
                        if(l>5)
                                l --;
                                l++;
                        HAL_Delay(100);
                //爪子开与关
                if(yunxing_flag==0&&che_flag == 5)
                        if(k>35)
                                k = k-17;
                        HAL_UART_Transmit_IT(&huart1,&SanHao[k][18],strlen(&SanHao[k][18]));
                        HAL_Delay(100);
                if(yunxing_flag==0&&che_flag == 6)
                        if(k<35)
                                k = k+17;
                        HAL_Delay(100);
lanyacar.rar
5.15 MB, 下载次数: 36, 下载积分: 黑币 -5
