查看: 3765|回复: 5
STM32和HMI人机通信程序源码
分享一个好玩的小东西
STM32的程序和HMI的程序都有,有时间的可以自己下载下来玩一玩.
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f1xx_hal.h"
  3. #include "dma.h"
  4. #include "usart.h"
  5. #include "gpio.h"
  6. /* USER CODE BEGIN Includes */
  7. /* USER CODE END Includes */
  8. /* Private variables ---------------------------------------------------------*/
  9. /* USER CODE BEGIN PV */
  10. /* Private variables ---------------------------------------------------------*/
  11. /* USER CODE END PV */
  12. /* Private function prototypes -----------------------------------------------*/
  13. void SystemClock_Config(void);
  14. void Error_Handler(void);
  15. /* USER CODE BEGIN PFP */
  16. /* Private function prototypes -----------------------------------------------*/
  17. /* USER CODE END PFP */
  18. /* USER CODE BEGIN 0 */
  19. /* USER CODE END 0 */
  20. int main(void)
  21. {
  22.   /* USER CODE BEGIN 1 */
  23.   /* USER CODE END 1 */
  24.   /* MCU Configuration----------------------------------------------------------*/
  25.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  26.   HAL_Init();
  27.   /* Configure the system clock */
  28.   SystemClock_Config();
  29.   /* Initialize all configured peripherals */
  30.   MX_GPIO_Init();
  31.   MX_DMA_Init();
  32.   MX_USART1_UART_Init();
  33.   /* USER CODE BEGIN 2 */
  34.         HAL_UART_Receive_DMA(&huart1, UsartType.RX_pData, RX_LEN);
  35.         __HAL_UART_ENABLE_IT(&huart1, UART_IT_IDLE);
  36.   /* USER CODE END 2 */
  37.   /* Infinite loop */
  38.   /* USER CODE BEGIN WHILE */
  39.   while (1)
  40.   {
  41.   /* USER CODE END WHILE */
  42.   /* USER CODE BEGIN 3 */
  43.                         if(UsartType.RX_flag)            // Receive flag
  44.                         {
  45.                                         UsartType.RX_flag=0;        // clean flag
  46.                                         HAL_UART_Transmit(&huart1, "123", 3, 0xFFFF);
  47.                         }
  48.   }
  49.   /* USER CODE END 3 */
  50. }
  51. /** System Clock Configuration
  52. */
  53. void SystemClock_Config(void)
  54. {
  55.   RCC_OscInitTypeDef RCC_OscInitStruct;
  56.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  57.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  58.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  59.   RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5;
  60.   RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2;
  61.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  62.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  63.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  64.   RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL2_ON;
  65.   RCC_OscInitStruct.PLL2.PLL2MUL = RCC_PLL2_MUL8;
  66.   RCC_OscInitStruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV5;
  67.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  68.   {
  69.     Error_Handler();
  70.   }
  71.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  72.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  73.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  74.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  75.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  76.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  77.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  78.   {
  79.     Error_Handler();
  80.   }
  81.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  82.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  83.   __HAL_RCC_PLLI2S_ENABLE();
  84.   /* SysTick_IRQn interrupt configuration */
  85.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  86. }
  87. /* USER CODE BEGIN 4 */
  88. /* USER CODE END 4 */
  89. /**
  90.   * @brief  This function is executed in case of error occurrence.
  91.   * @param  None
  92.   * @retval None
  93.   */
  94. void Error_Handler(void)
  95. {
  96.   /* USER CODE BEGIN Error_Handler */
  97.   /* User can add his own implementation to report the HAL error return state */
  98.   while(1)
  99.   {
  100.   }
  101.   /* USER CODE END Error_Handler */
  102. }
  103. #ifdef USE_FULL_ASSERT
  104. /**
  105.    * @brief Reports the name of the source file and the source line number
  106.    * where the assert_param error has occurred.
  107.    * @param file: pointer to the source file name
  108.    * @param line: assert_param error line source number
  109.    * @retval None
  110.    */
  111. void assert_failed(uint8_t* file, uint32_t line)
  112. {
  113.   /* USER CODE BEGIN 6 */
  114.   /* User can add his own implementation to report the file name and line number,
  115.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  116.   /* USER CODE END 6 */
  117. }
  118. #endif
  119. /**
  120.   * @}
  121.   */
  122. /**
  123.   * @}
  124. */
  125. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
收发.rar (3.36 MB, 下载次数: 119)
收藏收藏1 分享淘帖 顶 踩
ID:1 发表于 2018-11-2 02:43 | 只看该作者
好资料,51黑有你更精彩!!!
好资料,51黑有你更精彩!!!
ID:596488 发表于 2019-8-7 17:23 | 只看该作者
感谢楼主的无私分享
ID:620291 发表于 2020-1-1 20:04 | 只看该作者
感谢楼主的无私分享
ID:680133 发表于 2020-1-3 00:21 | 只看该作者
最好五寸以上屏使用,就可以装在机械上了。
