CM 六轴传感器驱动代码,通过FIFO阈值中断采集三轴加速度数据和三轴陀螺仪数据
- #include <stdbool.h>
- #include <stdint.h>
- #include <string.h>
- #include "nrf_drv_spi.h"
- #include "icm42605.h"
- #include "nrf_drv_gpiote.h"
- #include "nrf_delay.h"
- void icm42605_cs_high()
- nrf_gpio_pin_set(ICM42605_SPI_SS_PIN);
- void icm42605_cs_low()
- nrf_gpio_pin_clear(ICM42605_SPI_SS_PIN);
- uint8_t icm42605_spi_rw(uint8_t reg)
- uint8_t rx_data = 0;
- nrf_gpio_pin_set(ICM42605_SPI_SCK_PIN);
- for(uint8_t i =0;i<8;i++)
- if(reg & 0x80)
- nrf_gpio_pin_set(ICM42605_SPI_MOSI_PIN);
- else
- nrf_gpio_pin_clear(ICM42605_SPI_MOSI_PIN);
- nrf_gpio_pin_clear(ICM42605_SPI_SCK_PIN);
- reg <<= 1;
- rx_data <<= 1;
- if(nrf_gpio_pin_read(ICM42605_SPI_MISO_PIN))
- rx_data |= 0x01;
- return rx_data;
- uint8_t icm42605_read_reg(uint8_t reg)
- uint8_t temp;
- icm42605_cs_low();
- icm42605_spi_rw((reg | 0x80));
- temp = icm42605_spi_rw(0);
- icm42605_cs_high();
- return temp;
- uint8_t icm42605_write_reg(uint8_t reg,uint8_t value)
- icm42605_spi_rw((reg & 0x7f));
- icm42605_spi_rw(value);
- return 0;
- uint8_t icm42605_read_regs(uint8_t reg,uint8_t *buf,uint16_t len)
- uint16_t i = 0;
- while(i < len){
- buf[i] = icm42605_spi_rw(0);
- i++;
- return 0;
- uint8_t icm42605_init(void)
- uint8_t reg_val;
- icm42605_write_reg(reg_bank_sel,0x00);//Set to bank 0
- icm42605_write_reg(device_config_reg,bit_soft_reset_chip_config);//chip soft reset
- nrf_delay_ms(100);
- reg_val = icm42605_read_reg(who_am_i);//who_am_i
- if(reg_val==0x42)
- icm42605_write_reg(reg_bank_sel,0x01);//Change to bank 1
- icm42605_write_reg(intf_config4,0x02);//4 wire spi mode
- icm42605_write_reg(fifo_config_reg,0x40);//Stream-to-FIFO Mode
- reg_val = icm42605_read_reg(int_source0_reg);
- icm42605_write_reg(int_source0_reg,0x00);
- icm42605_write_reg(fifo_config2_reg,0x00);// watermark
- icm42605_write_reg(fifo_config3_reg,0x02);// watermark
- icm42605_write_reg(int_source0_reg, reg_val);
- icm42605_write_reg(fifo_config1_reg,0x63);// Enable the accel and gyro to the FIFO
- icm42605_write_reg(int_config_reg,0x36);
- icm42605_write_reg(reg_bank_sel, 0x00);
- reg_val = (icm42605_read_reg(int_source0_reg)|bit_int_fifo_ths_int1_en);
- reg_val = ((icm42605_read_reg(accel_config0_reg)&0x1F)|(bit_accel_ui_fs_sel_8g));//8g
- icm42605_write_reg(accel_config0_reg, reg_val);
- reg_val = ((icm42605_read_reg(accel_config0_reg)&0xF0)|bit_accel_odr_50hz);
- reg_val = ((icm42605_read_reg(gyro_config0_reg)&0x1F)|(bit_gyro_ui_fs_sel_1000dps));
- icm42605_write_reg(gyro_config0_reg,reg_val);
- reg_val = ((icm42605_read_reg(gyro_config0_reg)&0xF0)|bit_gyro_odr_50hz);
- icm42605_write_reg(gyro_config0_reg, reg_val);
- reg_val = icm42605_read_reg(pwr_mgmt0_reg)|(bit_accel_mode_ln); // Accel on in LNM
- icm42605_write_reg(pwr_mgmt0_reg, reg_val);
- nrf_delay_us(400);
- reg_val = icm42605_read_reg(pwr_mgmt0_reg)|(bit_gyro_mode_ln); // Gyro on in LNM
- printf("ok");
- return 1;
- }else return 0;
- uint8_t fifocount_l, fifocount_h;
- uint16_t fifocount;
- void icm42605_read_fifo(Sample_data_type_t *data,uint16_t len)
- uint8_t reg_val;
- uint8_t tempbuff[512]={0};
- fifocount_h = icm42605_read_reg(fifo_byte_count_h_res); // Read the FIFO size
- fifocount_l = icm42605_read_reg(fifo_byte_count_l_res);
- fifocount = (fifocount_h<<8)|fifocount_l;
- icm42605_read_regs(fifo_data_port,tempbuff,len);
- if(fifocount>=fifo_packet_size) // If we have a complete packet in the FIFO
- for(uint8_t i=0;i<32;i++)
- if((tempbuff[i*16]&fifo_accel_en)&&(tempbuff[i*16]&fifo_gyro_en))
- data->Sample_accdata[0+i*3] = ((int16_t)((tempbuff[1+i*16] << 8) | tempbuff[2+i*16]))*acc_ssl;
- data->Sample_accdata[1+i*3] = ((int16_t)((tempbuff[3+i*16] << 8) | tempbuff[4+i*16]))*acc_ssl;
- data->Sample_accdata[2+i*3] = ((int16_t)((tempbuff[5+i*16] << 8) | tempbuff[6+i*16]))*acc_ssl;
- data->Sample_gyrdata[0+i*3] = ((int16_t)((tempbuff[7+i*16] << 8) | tempbuff[8+i*16]))/gyr_ssl;
- data->Sample_gyrdata[1+i*3] = ((int16_t)((tempbuff[9+i*16] << 8) | tempbuff[10+i*16]))/gyr_ssl;
- data->Sample_gyrdata[2+i*3] = ((int16_t)((tempbuff[11+i*16]<< 8) | tempbuff[12+i*16]))/gyr_ssl;
ICM42605_DRIVER.zip
(3.13 KB, 下载次数: 165)
