查看: 2697|回复: 0
DSP仿真出现ACU_SEL Register write failed
ID:283156 发表于 2018-11-1 14:17 | 显示全部楼层 |阅读模式
之前板子一直好着呢,今天再插上后编译仿真出现ACU_SEL Register write failed,不知道怎么回事,而且电流好像很低,LED灯就不怎么亮,之前偶尔出现过这样情况,但是转动一下电源插口就好了,这次怎么就不行了,哪里出错了,请大神指教?谢谢仿真后出现如下
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1
         at (ST1&~(0x0100)) [f28335.gel:322]
         at C28x_Mode() [f28335.gel:38]
         at OnReset(1)
C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Breakpoint Manager: Error enabling this function: ACU_SEL Register write failed
