查看: 6704|回复: 3
error C267: 'SectorErase': requires ANSI-style prototype编译错误
ID:420280 发表于 2018-11-3 22:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大佬知道这个是什么意思吗
K.C(65): error C267: 'SectorErase': requires ANSI-style prototype
ID:420280 发表于 2018-11-3 22:20 | 只看该作者
#include <REG52.h>
#include<intrins.h>
#include "main.h"
#include<rc522.c>
#include<eeprom52.h>
#define LCM_Data  P0
#define uint  unsigned int
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7;
sbit ALAM = P2^1;                //报警
sbit KEY = P3^6;                //开锁
bit  operation=0;                //操作标志位
bit  pass=0;                        //密码正确标志
bit  ReInputEn=0;                //重置输入充许标志
bit  s3_keydown=0;                //3秒按键标志位
bit  key_disable=0;                //锁定键盘标志
bit  chushihua=0;       //可以注册卡标志位
unsigned char countt0,second;        //t0中断计数器,秒计数器
//解码变量
unsigned char Im[4]={0x00,0x00,0x00,0x00};
//全局变量
uchar f,a_a;
unsigned long m,Tc;
unsigned char   IrOK;
unsigned char xdata CardRevBuf[16] = { 0 };
//void Delay5Ms(void);
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};        //控盘扫描控制表
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = {"===Coded Lock==="};        //显示名称
unsigned char code Correct[]         = {"     correct    "};        //输入正确
unsigned char code Error1[]           = {"      error     "};        //输入错误
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};        //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};        //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //输入密码暂存区
unsigned char CurrentPassword[6]={1,3,1,4,2,0};        //当前密码值
unsigned char TempPassword[6];
unsigned char N=0;                                //密码输入位数记数
unsigned char ErrorCont;                        //错误次数计数
unsigned char CorrectCont;                        //正确输入计数
unsigned char ReInputCont;                         //重新输入计数
unsigned char code initpassword[6]={0,0,0,0,0,0};
unsigned char current_id;
char xdata DisplayBuf[10];  //当前读出卡的ID
char xdata DisplayBuf_c[10];  //当前单片机里存的卡ID
void write_eeprom()
        SectorErase(0x200a);                   //清空
    byte_write(0x2000,TempPassword[0]);
         byte_write(0x2001,TempPassword[1]);
         byte_write(0x2002,TempPassword[2]);
         byte_write(0x2003,TempPassword[3]);
         byte_write(0x2004,TempPassword[4]);
         byte_write(0x2005,TempPassword[5]);
        byte_write(0x2060,0x02);
void write_eeprom_j(unsigned char j)                  //将对应的ID写入到单片机
        SectorErase(0x2200+j*0x0200);                   //清空
        byte_write(0x2200+j*0x0200,DisplayBuf[0]);
        byte_write(0x2201+j*0x0200,DisplayBuf[1]);
        byte_write(0x2202+j*0x0200,DisplayBuf[2]);
        byte_write(0x2203+j*0x0200,DisplayBuf[3]);
        byte_write(0x2204+j*0x0200,DisplayBuf[4]);
        byte_write(0x2205+j*0x0200,DisplayBuf[5]);
        byte_write(0x2206+j*0x0200,DisplayBuf[6]);
        byte_write(0x2207+j*0x0200,DisplayBuf[7]);
void write_eeprom_jj(unsigned char j)         //将对应的ID清空
        byte_write(0x2200+j*0x0200,' ');
        byte_write(0x2201+j*0x0200,' ');
        byte_write(0x2202+j*0x0200,' ');
        byte_write(0x2203+j*0x0200,' ');
        byte_write(0x2204+j*0x0210,' ');
        byte_write(0x2205+j*0x0200,' ');
        byte_write(0x2206+j*0x0200,' ');
        byte_write(0x2207+j*0x0200,' ');
void read_eeprom_j(uchar j)
  DisplayBuf_c[0]= byte_read(0x2200+j*0x0200);
  DisplayBuf_c[1]= byte_read(0x2201+j*0x0200);
  DisplayBuf_c[2]= byte_read(0x2202+j*0x0210);
  DisplayBuf_c[3]= byte_read(0x2203+j*0x0200);
  DisplayBuf_c[4]= byte_read(0x2204+j*0x0200);
  DisplayBuf_c[5]= byte_read(0x2205+j*0x0200);
  DisplayBuf_c[6]= byte_read(0x2206+j*0x0200);
  DisplayBuf_c[7]= byte_read(0x2207+j*0x0200);
/******************把数据从单片机内部eeprom中读出来*****************/
void read_eeprom()
    CurrentPassword[0]= byte_read(0x2000);
        CurrentPassword[1]= byte_read(0x2011);
        CurrentPassword[2]= byte_read(0x2002);
        CurrentPassword[3]= byte_read(0x2003);
        CurrentPassword[4]= byte_read(0x2004);
    CurrentPassword[5]= byte_read(0x2005);
        a_a = byte_read(0x2060);
/**************开机自检eeprom初始化*****************/
void init_eeprom()
    uchar i,j;
        if(a_a != 1)                //新的单片机初始单片机内问eeprom
                a_a = 1;
                for(i=0;i<6;i++)
                  SectorErase(0x2200+i*0x0200);
                  for(j=0;j<8;j++)
                  byte_write(0x2200+i*0x0200+j,'0');
            write_eeprom();           //保存数据
//=====================5ms延时==============================
void Delay5Ms()
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延时==============================
void Delay400Ms()
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
#define er 0x80+40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
//----------------延时函数,后面经常调用----------------------
void delay(uint xms)//延时函数,有参函数
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
//--------------------------写指令---------------------------
void write_1602com(uchar com)//****液晶写入指令函数****
        lcd1602_rs=0;//数据/指令选择置为指令
        lcd1602_rw=0; //读写选择置为写
        P0=com;//送入数据
        delay(1);
        lcd1602_en=0;//拉高使能端,为制造有效的下降沿做准备
        delay(1);
        lcd1602_en=1;//en由高变低,产生下降沿,液晶执行命令
//-------------------------写数据-----------------------------
void write_1602dat(uchar dat)//***液晶写入数据函数****
        lcd1602_rs=1;//数据/指令选择置为数据
        lcd1602_rw=1; //读写选择置为写
        P0=dat;//送入数据
        delay(1);
        lcd1602_en=0; //en置高电平,为制造下降沿做准备
        delay(1);
        lcd1602_en=1; //en由高变低,产生下降沿,液晶执行命令
//-------------------------初始化-------------------------
void lcd_init()
        write_1602com(0x01);//清显示
        write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
        write_1602com(0x0c);//开显示不显示光标
        write_1602com(0x06);//整屏不移动,光标自动右移
//==============将按键值编码为数值=========================
unsigned char coding(unsigned char m1,unsigned char hh)
        unsigned char k;
        if(IrOK==1)
                IrOK=0;
                switch(m1)
                        case (0x0c): k=1;break;
                        case (0x18): k=2;break;
                        case (0x5e): k=3;break;
//                        case (0xff): k='A';break;         //
                        case (0x08): k=4;break;
                        case (0x1c): k=5;break;
                        case (0x50): k=6;break;
//                        case (0x82): k='B';break;           //
                        case (0x42): k=7;break;
                        case (0x52): k=8;break;
                        case (0x4a): k=9;break;
//                        case (0x84): k='C';break;        //
                        case (0x43): k='*';break;          //撤销
                        case (0x16): k=0;break;
                        case (0x15): k='#';break;           //确认键
                        case (0x0d): k='D';break;           //重设密码
                        case (0x4e): k='B';break;         //
                        case (0x47): k='C';break;         //
                        case (0x44): k='A';break;         //
                        case (0x40): k='A';break;         //
                        case (0x07): k='A';break;         //
                        case (0x09): k='A';break;         //
                        case (0x19): k='A';break;         //
//                        default:;
                switch(hh)
                        case (0x11): k=1;break;
                        case (0x21): k=2;break;
                        case (0x41): k=3;break;
                        case (0x81): k='A';break;
                        case (0x12): k=4;break;
                        case (0x2a): k=5;break;
                        case (0x42): k=6;break;
                        case (0x14): k=7;break;
                        case (0x24): k=8;break;
                        case (0x4b): k=9;break;
                        case (0x18): k='*';break;
                        case (0x28): k=0;break;
                        case (0x48): k='#';break;
                        case (0x88): k='D';break;
//                        default:;
        return(k);
//=====================按键检测并返回按键值===============================
unsigned char keynum()
        unsigned char row,col,i;
        P1=0xf0;
        if((P1&0xf0)!=0xf0)
                   Delay5Ms();
        Delay5Ms();
                   if((P1&0xf0)!=0xf0)
                    row=P1^0xf0;          //确定行线
                        i=0;
                        P1=a[i];                  //精确定位
                        while(i<4)
                                 if((P1&0xf0)!=0xf0)
                                           col=~(P1&0xff);          //确定列线
                                           break;            //已定位后提前退出
                                           i++;
                                           P1=a[i];
                        return 0;
                while((P1&0xf0)!=0xf0);
                return (row|col);                         //行线与列线组合后返回
        else return 0;                                 //无键按下时返回0
//=======================一声提示音,表示有效输入========================
void OneAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================二声提示音,表示操作成功========================
void TwoAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================三声提示音,表示错误========================
void ThreeAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//=====================显示输入的N个数字,用H代替以便隐藏============================
void DisplayOne()
//        DisplayOneChar(9+N,1,'*');
        write_1602com(yi+5+N);
        write_1602dat('*');
//=======================显示提示输入=========================
void DisplayChar()
        unsigned char i;
        if(pass==1)
                //DisplayListChar(0,1,LockOpen);
                write_1602com(er);
                for(i=0;i<16;i++)
                        write_1602dat(LockOpen[i]);
                if(N==0)
                        //DisplayListChar(0,1,Error);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(Error1[i]);
                        //DisplayListChar(0,1,start_line);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(start_line[i]);
void DisplayInput()
        unsigned char i;
        if(CorrectCont==1)
                //DisplayListChar(0,0,Input);
                write_1602com(er);
                for(i=0;i<16;i++)
                        write_1602dat(Input[i]);
//========================重置密码==================================================
void ResetPassword()
        unsigned char i;
        unsigned char j;
        if(pass==0)
                pass=0;
                DisplayChar();
                ThreeAlam();
            if(ReInputEn==1)
                        if(N==6)
                                ReInputCont++;
                                if(ReInputCont==2)
                                        for(i=0;i<6;)
                                                if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
                                                        i++;
                                                        write_1602com(er);
                                                        for(j=0;j<16;j++)
        write_1602dat(Error1[j]);
                                                        ThreeAlam();                        //错误提示
                                                        pass=0;
                                                        ReInputEn=0;                        //关闭重置功能,
                                                        ReInputCont=0;
                                                        DisplayChar();
                                                        break;
                                        if(i==6)
                                                //DisplayListChar(0,1,ResetOK);
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(ResetOK[j]);
                                                TwoAlam();                                //操作成功提示
                        write_eeprom();
                                                ReInputEn=0;
                                        ReInputCont=0;
                                        CorrectCont=0;
                                        OneAlam();
                                        //DisplayListChar(0, 1, again);                 //显示再次输入一次
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(again[j]);
                                        for(i=0;i<6;i++)
                                                TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
                        N=0;                                                //输入数据位数计数器清零
//=======================输入密码错误超过三过,报警并锁死键盘======================
void Alam_KeyUnable()
        P1=0x00;
                ALAM=~ALAM;
                Delay5Ms();
//=======================取消所有操作============================================
void Cancel()
        unsigned char i;
        unsigned char j;
        //DisplayListChar(0, 1, start_line);
        write_1602com(er);
        for(j=0;j<16;j++)
                write_1602dat(start_line[j]);
        TwoAlam();                                //提示音
        for(i=0;i<6;i++)
                InputData[i]=0;
        KEY=1;                                        //关闭锁
        ALAM=1;                                        //报警关
        operation=0;                        //操作标志位清零
        pass=0;                                        //密码正确标志清零
        ReInputEn=0;                        //重置输入充许标志清零
//        ErrorCont=0;                        //密码错误输入次数清零
        CorrectCont=0;                        //密码正确输入次数清零
        ReInputCont=0;                        //重置密码输入次数清零
        s3_keydown=0;
        key_disable=0;
        N=0;                                        //输入位数计数器清零
//==========================确认键,并通过相应标志位执行相应功能===============================
void Ensure()
        unsigned char i,j;
//        RdFromROM(CurrentPassword,0,6);                                         //从24C02里读出存储密码
    read_eeprom();
    if(N==6)
            if(ReInputEn==0)                                                        //重置密码功能未开启
                        for(i=0;i<6;)
                                if(CurrentPassword[i]==InputData[i])
                                        i++;
                                        i=7;
                                        ErrorCont++;
                                        if(ErrorCont>=3&&KEY==1)                        //错误输入计数达三次时,报警并锁定键盘
                                                write_1602com(er);
                                                for(i=0;i<16;i++)
                                                Alam_KeyUnable();
                                                TR0=0;                                //开启定时
                                                key_disable=1;                        //锁定键盘
                                                pass=0;
                                                break;
                        if(i==6)
                                CorrectCont++;
                                if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁,
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(LockOpen[j]);
                                        TwoAlam();                        //操作成功提示音
                                        ErrorCont=0;
                                        KEY=0;        //开锁
                                        pass=1;        //置正确标志位
                                        TR1=1;        //开启定时
                                        for(j=0;j<6;j++)        //将输入清除
                                                InputData[i]=0;
                                else        //当两次正确输入时,开启重置密码功能
                                        //DisplayListChar(0,1,SetNew);
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(SetNew[j]);
                                        TwoAlam();        //操作成功提示
                                        ReInputEn=1;        //允许重置密码输入
                                        CorrectCont=0;        //正确计数器清零
                        else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
                                if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
//                                        WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
                                        //DisplayListChar(0,1,initword);                        //显示初始化密码
                                        TwoAlam();
                                        Delay400Ms();
                                        TwoAlam();
                                        N=0;
                                        chushihua=1;
                                else if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==1))
                     TempPassword[0]=0;
                                         TempPassword[1]=0;
                                         TempPassword[2]=0;
                                         TempPassword[3]=0;
                                         TempPassword[4]=0;
                                         TempPassword[5]=0;
                     write_eeprom();
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(initword[j]);
                                        TwoAlam();
                                        Delay400Ms();
                                        TwoAlam();
                                        N=0;
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        ThreeAlam();        //错误提示音
                                        pass=0;
                else        //当已经开启重置密码功能时,而按下开锁键,
                        //DisplayListChar(0,1,Er_try);
                        write_1602com(er);
                        for(j=0;j<16;j++)
                                write_1602dat(Er_try[j]);
                        ThreeAlam();
                write_1602com(er);
                for(j=0;j<16;j++)
                pass=0;
        N=0;        //将输入数据计数器清零,为下一次输入作准备
        operation=1;
void display_id( unsigned char xdata * SrcBuf )
        char xdata *pDisplayChar;
        unsigned char xdata Tmp, i;
        pDisplayChar = DisplayBuf;
        for( i = 0; i < 4; i++ )
                Tmp = ( ( *SrcBuf ) << 4 ) & 0x0F;
                if( ( Tmp >=0 ) && ( Tmp <= 9 )        )
                        *pDisplayChar ++ = '0' + Tmp;
                        *pDisplayChar ++ = 'A' + Tmp - 10;
                Tmp = ( *SrcBuf ) & 0x0F;
                SrcBuf ++;
        *pDisplayChar ++ = '\0';
//        DisplayListChar( 0, 4, DisplayBuf );
        if(chushihua==1)
    write_1602com(0xc0);
        write_1602dat('I');
        write_1602dat('D');
        write_1602dat(current_id+0x30);
        write_1602dat(':');
        write_1602dat(DisplayBuf[0]);
        write_1602dat(DisplayBuf[1]);
        write_1602dat(DisplayBuf[2]);
        write_1602dat(DisplayBuf[3]);
        write_1602dat(DisplayBuf[4]);
        write_1602dat(DisplayBuf[5]);
        write_1602dat(DisplayBuf[6]);
        write_1602dat(DisplayBuf[7]);
        write_1602dat(' ');
        write_1602dat(' ');write_1602dat(' ');write_1602dat(' ');write_1602dat(' ');
void display_no_id()
          write_1602dat('I');
        write_1602dat('D');
        write_1602dat(':');
        write_1602dat(DisplayBuf_c[0]);
        write_1602dat(DisplayBuf_c[1]);
        write_1602dat(DisplayBuf_c[2]);
        write_1602dat(DisplayBuf_c[3]);
        write_1602dat(DisplayBuf_c[4]);
        write_1602dat(DisplayBuf_c[5]);
        write_1602dat(DisplayBuf_c[6]);
        write_1602dat(DisplayBuf_c[7]);
                write_1602dat(' ');
void ctrl( void )
    uchar j,i;
        if( PcdRequest( PICC_REQIDL, &CardRevBuf[0] ) != MI_OK )//寻天线区内未进入休眠状态的卡,返回卡片类型 2字节
                 if(chushihua==1)
                 read_eeprom_j(current_id);
                 display_no_id();
                        return;
        if( PcdAnticoll( &CardRevBuf[2] ) != MI_OK ) //防冲撞,返回卡的序列号 4字节
        if(chushihua==1)
        display_no_id();
                return;
        if( PcdSelect( &CardRevBuf[2] ) != MI_OK )//选卡
        if(chushihua==1)
          display_no_id();
                return;
        display_id( &CardRevBuf[2] );
        if(CorrectCont==0&&pass==0)
          for(j=0;j<6;j++)
          read_eeprom_j(j);
           if(DisplayBuf[0]==DisplayBuf_c[0]&&DisplayBuf[1]==DisplayBuf_c[1]&&DisplayBuf[2]==DisplayBuf_c[2]&&DisplayBuf[3]==DisplayBuf_c[3]&&DisplayBuf[4]==DisplayBuf_c[4]&&DisplayBuf[5]==DisplayBuf_c[5])
                  CorrectCont=1;
                  write_1602com(er);
                        for(j=0;j<16;j++)
                        ErrorCont=0;
                        KEY=0;        //开锁
                        pass=1;        //置正确标志位
                        TR0=1;        //开启定时
                                InputData[i]=0;
                return;
//==============================主函数===============================
        unsigned char KEY,NUM;
        unsigned char i,j;
        P1=0xFF;
        EA=1;
        TMOD=0x01;
        IT1=1;//下降沿有效
        EX1=1;//外部中断1开
        TH0=0;//T0赋初值
        TL0=0;
        TR0=1;//t0开始计时
        TL1=0x3c;
        TH1=0xb0;
        ET1=1;
        TR1=0;
        Delay400Ms();         //启动等待,等LCM讲入工作状态
        lcd_init();         //LCD初始化
        write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
        init_rc522();
        init_eeprom();
        read_eeprom();
        for(i=0;i<16;i++)
                write_1602dat(name[i]);//向液晶屏写日历显示的固定符号部分
        write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示
        for(i=0;i<16;i++)
                write_1602dat(start_line[i]);//写显示时间固定符号,两个冒号
        write_1602com(er+9);        //设置光标位置
        write_1602com(0x0f);        //设置光标为闪烁
        Delay5Ms(); //延时片刻(可不要)
        N=0;        //初始化数据输入位数
                ctrl();
                if(key_disable==1)
                        Alam_KeyUnable();
                        ALAM=1;        //关报警
                KEY=keynum();
                if(KEY!=0||IrOK==1)
                        if(key_disable==1)
                                second=0;
                                NUM=coding(Im[2],KEY);
                                        switch(NUM)
                                                case ('A'): if(chushihua==1)
                                                             current_id++;
                                                            if(current_id>5)
        current_id=0;
        }                                        break;
                                                case ('B'):        if(chushihua==1)
                                                             write_eeprom_jj(current_id)        ;                                             break;
                                                case ('C'): if(chushihua==1)
                                                             write_eeprom_j(current_id)        ;                                         break;
                                                case ('D'): chushihua=0;ResetPassword();                break;      //重新设置密码
                                                case ('*'): chushihua=0;Cancel();                                break;      //取消当前输入
                                                case ('#'): chushihua=0; Ensure();                                 break;           //确认键,
                                                default:
                                                    chushihua=0;
                                                        //DisplayListChar(0,1,Input);
                                                        write_1602com(er);
                                                        for(i=0;i<16;i++)
                                                    operation=0;
                                                        if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
        OneAlam();        //按键提示音
        //DisplayOneChar(6+N,1,'*');
        for(j=0;j<=N;j++)
        write_1602com(er+6+j);
        write_1602dat('*');
        InputData[N]=NUM;
        N++;
                                                        else        //输入数据位数大于6后,忽略输入
        N=6;
        break;
//*********************************中断服务函数**************************************
void  time1_int() interrupt 3
        TL1=0x3c;
        TH1=0xb0;
        countt0++;
          if(countt0==20)
                countt0=0;
                second++;
                if(pass==1)
                        if(second==1)
                                TR1=0;                                //关定时器
                                TL1=0xB0;
                                TH1=0x3C;
                                second=0;
                        if(second==3)
                                TR1=0;
                                second=0;
                                key_disable=0;
                                s3_keydown=0;
                                TL1=0xB0;
                                TH1=0x3C;
                            TR1=1;
ID:505850 发表于 2019-4-15 21:18 | 只看该作者
楼主找到解决方法了吗?
ID:782510 发表于 2020-12-9 10:41 | 只看该作者
楼主,这个怎么解决?
