LM75A驱动,已测试可以直接运行
模拟I2C控制,LM75A
从上往下一次为
VCC--3.3V---红色箭头
SDA--单片机PB7口
SCL-PB6
OS--悬空
GND--地
模块来自翔宝,引脚上拉电阻已上拉,具体电路自行百度,仅程序。
程序有两个版本,一个是来自百度搜索移植,GPIO配置为开漏,一个移植原子的模拟I2C,gpio为推挽
LM75A引脚图与资料下载:
- #include "stm32f10x.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- //#include "myiic.h"
- #include "i2c_ee.h"
- u8 addr=0x90;
- u8 addr1=0x91;
- u8 buff[2]={0};
- float data;
- int main(void)
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- IIC_Init();
- while(1){
- printf("%d \r\n",I2C_LM75_Read());
- data=0.125*(I2C_LM75_Read());
- printf("%.3f ℃\r\n",data);
- delay_ms(1000);
复制代码- #ifndef __I2C_EE_C
- #define __I2C_EE_C
- #endif
- * 使用I2C1读写AT24C256,LM75
- //u16 test=0x00e7;
- void I2C_delay(void)
- u8 i=50; //这里可以优化速度,经测试最低到5还能写入
- while(i--);
- u16 I2C_Start(void)
- SDA_H;
- SCL_H;
- I2C_delay();
- if(!SDA_read)return(I2C_TM_ERR); //SDA线为低电平则总线忙,退出
- SDA_L;
- I2C_delay();
- if(SDA_read) return(I2C_TM_ERR); //SDA线为高电平则总线出错,退出
- SCL_L;
- I2C_delay();
- return (I2C_TM_OK);
- void I2C_Stop(void)
- SCL_L;
- I2C_delay();
- SDA_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SDA_H;
- I2C_delay();
- SCL_L;
- I2C_delay();
- void I2C_Ack(void)
- SCL_L;
- I2C_delay();
- SDA_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- I2C_delay();
- void I2C_NoAck(void)
- SCL_L;
- I2C_delay();
- SDA_H;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- I2C_delay();
- u16 I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
- SCL_L;
- I2C_delay();
- SDA_H;
- I2C_delay();
- SCL_H;
- I2C_delay();
- if(SDA_read)
- SCL_L;
- return(I2C_TM_ERR);
- SCL_L;
- return(I2C_TM_OK);
- void I2C_SendByte(u8 SendByte) //数据从高位到低位//
- u8 i=8;
- while(i--)
- SCL_L;
- I2C_delay();
- if(SendByte&0x80)SDA_H;
- else SDA_L;
- SendByte<<=1;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- u8 I2C_ReceiveByte(void) //数据从高位到低位//
- u8 i=8;
- u8 ReceiveByte=0;
- SDA_H;
- while(i--)
- ReceiveByte<<=1;
- SCL_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- if(SDA_read)
- ReceiveByte|=0x01;
- SCL_L;
- return ReceiveByte;
- * Function Name : I2C_EE_ByteWrite
- * Description : Writes one byte to the I2C EEPROM.
- * Input : - pBuffer : pointer to the buffer containing the data to be
- * written to the EEPROM.
- * - WriteAddr : EEPROM's internal address to write to.
- * Output : None
- * Return : None
- u16 I2C_EE_ByteWrite(u8* pBuffer, u16 WriteAddr)
- if(I2C_Start()==I2C_TM_ERR)return(I2C_TM_ERR);
- I2C_SendByte(EEPROM_ADDRESS); //设置器件地址
- if(I2C_WaitAck()==I2C_TM_ERR){I2C_Stop(); return(I2C_TM_ERR);}
- I2C_SendByte((WriteAddr>>8) & 0x00FF); //设置高起始地址
- I2C_SendByte((u8)(WriteAddr & 0x00FF)); //设置低起始地址
- I2C_SendByte(*pBuffer);
- I2C_Stop();
- //注意:因为这里要等待EEPROM写完,可以采用查询或延时方式(10ms)
- if(I2C_EE_WaitEepromStandbyState()==I2C_TM_ERR) return(I2C_TM_ERR);
- * Function Name : I2C_EE_PageWrite
- * Description : Writes more than one byte to the EEPROM with a single WRITE
- * cycle. The number of byte can't exceed the EEPROM page size.
- * - NumByteToWrite : number of bytes to write to the EEPROM.
- * Output : None
- * Return : None
- u16 I2C_EE_PageWrite(u8* pBuffer, u16 WriteAddr, u16 NumByteToWrite)
- if(I2C_Start()==I2C_TM_ERR)return I2C_TM_ERR;
- while(NumByteToWrite--)
- I2C_SendByte(* pBuffer);
- pBuffer++;
- I2C_Stop();
- //Systick_Delay_1ms(10);
- * Function Name : I2C_EE_BufferWrite
- * Description : Writes buffer of data to the I2C EEPROM.
- * Output : None
- * Return : None
- u16 I2C_EE_BufferWrite(u8* pBuffer, u16 WriteAddr, u16 NumByteToWrite)
- u16 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
- Addr = WriteAddr % I2C_PageSize;
- count = I2C_PageSize - Addr;
- NumOfPage = NumByteToWrite / I2C_PageSize;
- NumOfSingle = NumByteToWrite % I2C_PageSize;
- /* If WriteAddr is I2C_PageSize aligned */
- if(Addr == 0)
- /* If NumByteToWrite < I2C_PageSize */
- if(NumOfPage == 0)
- if(I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle)==I2C_TM_ERR) return(I2C_TM_ERR);
- /* If NumByteToWrite > I2C_PageSize */
- else
- while(NumOfPage--)
- if(I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize)==I2C_TM_ERR) return(I2C_TM_ERR);
- WriteAddr += I2C_PageSize;
- pBuffer += I2C_PageSize;
- if(NumOfSingle!=0)
- /* If WriteAddr is not I2C_PageSize aligned */
- else
- if(NumOfPage== 0)
- else
- NumByteToWrite -= count;
- if(count != 0)
- if(I2C_EE_PageWrite(pBuffer, WriteAddr, count)==I2C_TM_ERR) return(I2C_TM_ERR);
- WriteAddr += count;
- pBuffer += count;
- if(NumOfSingle != 0)
- * Function Name : I2C_EE_BufferRead
- * Description : Reads a block of data from the EEPROM.
- * Input : - pBuffer : pointer to the buffer that receives the data read
- * from the EEPROM.
- * - ReadAddr : EEPROM's internal address to read from.
- * - NumByteToRead : number of bytes to read from the EEPROM.
- * Output : None
- * Return : None
- u16 I2C_EE_BufferRead(u8* pBuffer, u16 ReadAddr, u16 NumByteToRead)
- I2C_SendByte((ReadAddr>>8) & 0x00FF); //设置高起始地址
- I2C_SendByte((u8)(ReadAddr & 0x00FF)); //设置低起始地址
- I2C_SendByte(EEPROM_ADDRESS | 0x0001);
- while(NumByteToRead)
- *pBuffer = I2C_ReceiveByte();
- if(NumByteToRead == 1)I2C_NoAck();
- else I2C_Ack();
- pBuffer++;
- NumByteToRead--;
- I2C_Stop();
- * Function Name : I2C_EE_WaitEepromStandbyState
- * Description : Wait for EEPROM Standby state
- * Input : None
- * Output : None
- * Return : None
- u16 I2C_EE_WaitEepromStandbyState(void)
- u32 tmout=I2C_TIMEOUT;
- do
- if(I2C_WaitAck()==I2C_TM_OK){I2C_Stop(); return(I2C_TM_OK);}
- tmout--;
- }while(tmout>0);
- //停止位
- I2C_Stop();
- * Function Name : I2C_LM75_Read
- * Description : Reads Temperature data from the LM75.
- * Input : None
- * Output : 0xFFFF -- Error
- * 0x0000 ~ 0x01FF -- Valid data
- * Temp Binary Hex
- * +125 0111 1101 0xxx xxxx 0FAh
- * +25 0001 1001 0xxx xxxx 032h
- * +0.5 0000 0000 1xxx xxxx 001h
- * 0 0000 0000 0xxx xxxx 000h
- * -0.5 1111 1111 1xxx xxxx 1FFh
- * -25 1110 0111 0xxx xxxx 1CEh
- * -55 1100 1001 0xxx xxxx 192h
- * Return : None
- u16 I2C_LM75_Read(void)
- vu16 TempH,TempL;
- I2C_SendByte(LM75_ADDRESS); //设置器件地址
- I2C_SendByte(0x00); //设置温度寄存器地址
- I2C_SendByte(LM75_ADDRESS | 0x01); //设置器件地址
- TempH = I2C_ReceiveByte();
- I2C_Ack();
- TempL = I2C_ReceiveByte();
- I2C_NoAck();
- I2C_Stop();
- // if(TempH==0xFF && TempL==0xFF) return I2C_TM_ERR;
- // TempH = (TempH<<8) | (TempL&0x80);
- // TempH = test;
- return(TempH);
LM75A温度驱动.rar
(2.03 MB, 下载次数: 135)
