我给你来个程序试试
- #include <REG52.H>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar display[8][8];
- /*rank:A,1,2,3,4,I,心,U*/
- uchar code table_cha[8][8]= {0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
- /*the "ideasoft"*/
- uchar code table_id[40]= {0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
- /*railway*/
- uchar code dat[128]= {0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
- /*railway 2*/
- uchar code dat2[28]= {0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
- /*railway 3*/
- uchar code dat3[24]= {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
- /*3p char*/
- uchar code table_3p[3][8]= {0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
- /*initializtion
- That is to initialize the program .
- It is write to set the timer in c52 mcu.
- So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
- void sinter()
- IE=0x82;
- TCON=0x01;
- TH0=0xc0;
- TL0=0;
- TR0=1;
- void delay5us(void) //误差 -0.026765046296us STC 1T 22.1184Mhz
- unsigned char a,b;
- for(b=7; b>0; b--)
- for(a=2; a>0; a--);
- void delay(uint i)
- while (i--) {
- delay5us();
- }//12t的mcu 注释这个延时即可
- /*To judge the num bit*/
- uchar judgebit(uchar num,uchar b)
- char n;
- num=num&(1<<b);
- if (num)
- n=1;
- else
- n=0;
- return n;
- /*To figure out the round number*/
- uchar abs(uchar a)
- uchar b;
- b=a/10;
- a=a-b*10;
- if (a>=5)
- b++;
- return b;
- /*To figure out the absolute value*/
- uchar abss(char a)
- if (a<0)
- a=-a;
- return a;
- /*The function can comparat the character.
- And remove the big one to the back.*/
- void max(uchar *a,uchar *b)
- uchar t;
- if ((*a)>(*b)) {
- t=(*a);
- (*a)=(*b);
- (*b)=t;
- /*The function is to figure out the max number and return it.*/
- uchar maxt(uchar a,uchar b,uchar c)
- if (a<b)
- a=b;
- if (a<c)
- a=c;
- return a;
- void clear(char le)
- uchar i,j;
- for (j=0; j<8; j++) {
- for (i=0; i<8; i++)
- display[j][i]=le;
- void trailler(uint speed)
- char i,j;
- for (i=6; i>=-3; i--) {
- if (i>=0) {
- display[j][i]=display[j][i+1];
- if (i<4) {
- display[j][i+4]=0;
- delay(speed);
- void point(uchar x,uchar y,uchar z,uchar le)
- uchar ch1,ch0;
- ch1=1<<x;
- ch0=~ch1;
- if (le)
- display[z][y]=display[z][y]|ch1;
- else
- display[z][y]=display[z][y]&ch0;
- void type(uchar cha,uchar y)
- uchar xx;
- for (xx=0; xx<8; xx++) {
- display[xx][y]=table_cha[cha][xx];
- /*The first variable is the distance from the midpoint.
- The second is the layer.
- the third is the flash speed of the time between each two point.
- The forth is the enable io,it controls weather draw or claen.*/
- void cirp(char cpp,uchar dir,uchar le)
- uchar a,b,c,cp;
- if ((cpp<128)&(cpp>=0)) {
- if (dir)
- cp=127-cpp;
- else
- cp=cpp;
- a=(dat[cp]>>5)&0x07;
- b=(dat[cp]>>2)&0x07;
- c=dat[cp]&0x03;
- if (cpp>63)
- c=7-c;
- point (a,b,c,le);
- void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
- char t,a,b,c,a1,b1,c1,i;
- a1=x2-x1;
- b1=y2-y1;
- c1=z2-z1;
- t=maxt(abss(a1),abss(b1),abss(c1));
- a=x1*10;
- b=y1*10;
- c=z1*10;
- a1=a1*10/t;
- b1=b1*10/t;
- c1=c1*10/t;
- for (i=0; i<t; i++) {
- point(abs(a),abs(b),abs(c),le);
- a+=a1;
- b+=b1;
- c+=c1;
- point(x2,y2,z2,le);
- void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
- uchar i,j,t=0;
- max(&x1,&x2);
- max(&y1,&y2);
- max(&z1,&z2);
- for (i=x1; i<=x2; i++)
- t|=1<<i;
- if (!le)
- t=~t;
- if (fill) {
- if (le) {
- for (i=z1; i<=z2; i++) {
- for (j=y1; j<=y2; j++)
- display[j][i]|=t;
- } else {
- display[j][i]&=t;
- } else {
- if (le) {
- display[y1][z1]|=t;
- display[y2][z1]|=t;
- display[y1][z2]|=t;
- display[y2][z2]|=t;
- } else {
- display[y1][z1]&=t;
- display[y2][z1]&=t;
- display[y1][z2]&=t;
- display[y2][z2]&=t;
- t=(0x01<<x1)|(0x01<<x2);
- if (!le)
- t=~t;
- if (le) {
- for (j=z1; j<=z2; j+=(z2-z1)) {
- for (i=y1; i<=y2; i++)
- display[i][j]|=t;
- for (j=y1; j<=y2; j+=(y2-y1)) {
- display[j][i]|=t;
- } else {
- for (i=y1; i<=y2; i++) {
- display[i][j]&=t;
- display[j][i]&=t;
- void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
- uchar i;
- max(&z1,&z2);
- if (fill) {
- line (x1,y1,i,x2,y2,i,le);
- } else {
- line (x1,y1,z1,x2,y2,z1,le);
- line (x1,y1,z2,x2,y2,z2,le);
- line (x2,y2,z1,x2,y2,z2,le);
- line (x1,y1,z1,x1,y1,z2,le);
- void poke(uchar n,uchar x,uchar y)
- uchar i;
- for (i=0; i<8; i++) {
- point(x,y,i,judgebit(n,i));
- void boxtola(char i,uchar n)
- if ((i>=0)&(i<8)) {
- poke(n,0,7-i);
- if ((i>=8)&(i<16)) {
- poke(n,i-8,0);
- if ((i>=16)&(i<24)) {
- poke(n,7,i-16);
- void rolldisplay(uint speed)
- uchar j;
- char i,a;
- for (i=23; i>-40; i--) {
- for (j=0; j<40; j++) {
- a=i+j;
- if ((a>=0)&(a<24))
- boxtola(a,table_id[j]);
- delay(speed);
- void roll_apeak_yz(uchar n,uint speed)
- uchar i;
- switch(n) {
- case 1:
- for (i=0; i<7; i++) {
- display[i][7]=0;
- display[7][6-i]=255;
- delay(speed);
- break;
- case 2:
- display[7][7-i]=0;
- display[6-i][0]=255;
- delay(speed);
- break;
- case 3:
- display[7-i][0]=0;
- display[0][i+1]=255;
- delay(speed);
- break;
- case 0:
- display[0][i]=0;
- display[i+1][7]=255;
- delay(speed);
- void roll_apeak_xy(uchar n,uint speed)
- uchar i;
- switch(n) {
- case 1:
- line(0,i,0,0,i,7,0);
- line(i+1,7,0,i+1,7,7,1);
- delay(speed);
- break;
- case 2:
- line(i,7,0,i,7,7,0);
- line(7,6-i,0,7,6-i,7,1);
- delay(speed);
- break;
- case 3:
- line(7,7-i,0,7,7-i,7,0);
- line(6-i,0,0,6-i,0,7,1);
- delay(speed);
- break;
- case 0:
- line(7-i,0,0,7-i,0,7,0);
- line(0,i+1,0,0,i+1,7,1);
- delay(speed);
- void roll_3_xy(uchar n,uint speed)
- uchar i;
- switch(n) {
- case 1:
- box_apeak_xy (0,i,0,7,7-i,7,1,1);
- delay(speed);
- if (i<7)
- box_apeak_xy (3,3,0,0,i,7,1,0);
- break;
- case 2:
- box_apeak_xy (7-i,0,0,i,7,7,1,1);
- delay(speed);
- if (i<7)
- box_apeak_xy (3,4,0,i,7,7,1,0);
- break;
- case 3:
- delay(speed);
- if (i<7)
- box_apeak_xy (4,4,0,7,7-i,7,1,0);
- break;
- case 0:
- delay(speed);
- if (i<7)
- box_apeak_xy (4,3,0,7-i,0,7,1,0);
- void trans(uchar z,uint speed)
- uchar i,j;
- display[z][i]>>=1;
- delay(speed);
- void tranoutchar(uchar c,uint speed)
- uchar i,j,k,a,i2=0;
- if (i<7)
- box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
- box_apeak_xy (i2,0,0,i2,7,7,1,0);
- a=0;
- i2=i+1;
- for (j=0; j<=i; j++) {
- a=a|(1<<j);
- for (k=0; k<8; k++) {
- display[k][3]|=table_cha[c][k]&a;
- display[k][4]|=table_cha[c][k]&a;
- delay(speed);
- void transss()
- uchar i,j;
- display[i][j]<<=1;
- /*From now on,the function below is to display the flash.*/
- void flash_1()
- clear(0);
- type(1,0);
- delay(60000);
- type(2,0);
- delay(60000);
- type(3,0);
- delay(60000);
- type(4,0);
- delay(60000);
- delay(60000);
- clear(0);
- rolldisplay(30000);
- type(0,7);
- delay(60000);
- trailler(6000);
- delay(60000);
- void flash_2()
- uchar i;
- for (i=129; i>0; i--) {
- cirp(i-2,0,1);
- delay(8000);
- cirp(i-1,0,0);
- delay(8000);
- for (i=0; i<136; i++) {
- cirp(i,1,1);
- delay(8000);
- cirp(i-8,1,0);
- delay(8000);
- cirp(i-2,0,1);
- delay(8000);
- delay(8000);
- for (i=0; i<128; i++) {
- cirp(i-8,1,0);
- delay(8000);
- delay(60000);
- void flash_3()
- char i;
- box_apeak_xy(0,i,0,7,i,7,1,1);
- delay(20000);
- if (i<7)
- box_apeak_xy(0,i,0,7,i,7,1,0);
- for (i=7; i>=0; i--) {
- delay(20000);
- if (i>0)
- delay(20000);
- if (i<7)
- void flash_4()
- char i,j,an[8];
- for (j=7; j<15; j++)
- an[j-7]=j;
- for (i=0; i<=16; i++) {
- if ((an[j]<8)&(an[j]>=0))
- line(0,an[j],j,7,an[j],j,1);
- if (((an[j]+1)<8)&(an[j]>=0))
- line(0,an[j]+1,j,7,an[j]+1,j,0);
- if (an[j]>0)
- an[j]--;
- delay(15000);
- an[j]=1-j;
- if (((an[j]-1)<7)&(an[j]>0))
- line(0,an[j]-1,j,7,an[j]-1,j,0);
- if (an[j]<7)
- an[j]++;
- delay(15000);
- void flash_5()
- uint a=15000;//a=delay
- char i=8,j,an[4];
- //1
- for (j=7; j<11; j++)
- an[j-7]=j;
- while(i--) {
- for (j=0; j<4; j++) {
- if (an[j]<8)
- box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
- if (an[j]<7)
- box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
- if (an[j]>3)
- an[j]--;
- delay(a);
- //2
- i=3;
- an[j]=5-j;
- while(i--) {
- for (j=1; j<4; j++) {
- if (an[j]<4)
- if (an[j]<3)
- if (an[j]>0)
- an[j]--;
- delay(a);
- //3
- i=3;
- an[j]=4-j;
- while(i--) {
- if (an[j]>=0)
- if (an[j]>0)
- box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
- if (an[j]<3)
- an[j]++;
- delay(a);
- //4
- i=3;
- an[j]=j+1;
- while(i--) {
- if (an[j]>3)
- if (an[j]>3)
- an[j]++;
- delay(a);
- //5
- i=3;
- for (j=3; j<6; j++)
- an[j-2]=j;
- while(i--) {
- if (an[j]>3)
- an[j]--;
- delay(a);
- //6
- i=3;
- an[j]=5-j;
- while(i--) {
- if (an[j]<4)
- if (an[j]<3)
- if (an[j]>0)
- an[j]--;
- delay(a);
- //7
- i=3;
- an[j]=3-j;
- an[0]=2;
- while(i--) {
- for (j=0; j<3; j++) {
- if (an[j]>=0)
- if (an[j]>=0)
- if (j<5-i)
- an[j]--;
- delay(a);
- //8
- i=10;
- an[j]=j-2;
- while(i--) {
- if (an[j]>=0)
- if (an[j]>=0)
- if (an[j]<7)
- an[j]++;
- delay(a);
- void flash_6()
- uchar i,j,k,z;
- roll_apeak_yz(1,10000);
- roll_apeak_yz(2,10000);
- roll_apeak_yz(3,10000);
- roll_apeak_yz(0,10000);
- for (i=0; i<3; i++) {
- if ((table_3p[i][j]>>k)&1) {
- for (z=1; z<8; z++) {
- point (j,7-k,z,1);
- if (z-1)
- point (j,7-k,z-1,0);
- delay(5000);
- trans(7,15000);
- void flash_7()
- uchar i;
- uint a=3000;
- roll_apeak_xy(0,10000);
- roll_apeak_xy(1,10000);
- roll_apeak_xy(2,10000);
- roll_apeak_xy(3,10000);
- box_apeak_xy (0,i,0,7-i,i,7,1,1);
- delay(a);
- delay(30000);
- roll_3_xy(0,a);
- delay(30000);
- roll_3_xy(1,a);
- delay(30000);
- roll_3_xy(2,a);
- delay(30000);
- roll_3_xy(3,a);
- delay(30000);
- roll_3_xy(0,a);
- delay(30000);
- roll_3_xy(1,a);
- delay(30000);
- roll_3_xy(2,a);
- delay(30000);
- roll_3_xy(3,a);
- for (i=7; i>0; i--) {
- box_apeak_xy(i,0,0,i,7,7,1,0);
- delay(a);
- void flash_8()
- uchar i;
- for (i=5; i<8; i++) {
- tranoutchar(i,10000);
- delay(60000);
- delay(60000);
- void flash_9()
- char i;
- uchar j,an[8],x,y,t,x1,y1;
- box_apeak_xy (i,0,0,i,7,7,1,1);
- if (i)
- box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
- delay(10000);
- line(6-i,6-i,0,6-i,6-i,7,1);
- delay(10000);
- an[i]=14;
- for (i=0; i<85; i++) {
- clear(0);
- t=an[j]%28;
- x=dat2[t]>>5;
- y=(dat2[t]>>2)&0x07;
- t=(an[j]-14)%28;
- x1=dat2[t]>>5;
- y1=(dat2[t]>>2)&0x07;
- line(x,y,j,x1,y1,j,1);
- if ((i>j)&(j>i-71))
- an[j]++;
- delay(5000);
- clear(0);
- t=an[j]%28;
- x=dat2[t]>>5;
- t=(an[j]-14)%28;
- x1=dat2[t]>>5;
- an[j]--;
- delay(5000);
- for (i=0; i<29; i++) {
- clear(0);
- t=an[0]%28;
- x=dat2[t]>>5;
- t=(an[0]-14)%28;
- x1=dat2[t]>>5;
- box_apeak_xy(x,y,0,x1,y1,7,0,1);
- box_apeak_xy(x,y,1,x1,y1,6,0,1);
- an[0]++;
- delay(5000);
- for (i=0; i<16; i++) {
- clear(0);
- t=an[0]%28;
- x=dat2[t]>>5;
- t=(an[0]-14)%28;
- x1=dat2[t]>>5;
- box_apeak_xy(x,y,0,x1,y1,7,1,1);
- an[0]--;
- delay(5000);
- line(i,i,0,0,0,i,0);
- delay(5000);
- for (i=1; i<7; i++) {
- line(i,i,7,7,7,i,0);
- delay(5000);
- for (i=1; i<8; i++) {
- clear(0);
- box(7,7,7,7-i,7-i,7-i,0,1);
- delay(10000);
- clear(0);
- box(0,0,0,7-i,7-i,7-i,0,1);
- delay(10000);
- clear(0);
- box(0,0,0,i,i,i,0,1);
- delay(10000);
- clear(0);
- box(7,0,0,i,7-i,7-i,0,1);
- delay(10000);
- box(7,0,0,7-i,i,i,1,1);
- delay(10000);
- clear(0);
- box(0,7,7,7-i,i,i,1,1);
- delay(10000);
- void flash_10()
- uchar i,j,an[4],x,y,t;
- clear(0);
- box(0,6,6,1,7,7,1,1);
- box(i,6,6-i,i+1,7,7-i,1,1);
- box(i,6,6,i+1,7,7,1,1);
- box(0,6,6-i,1,7,7-i,1,1);
- box(0,6-i,6,1,7-i,7,1,1);
- box(i,6-i,6-i,i+1,7-i,7-i,1,1);
- box(i,6-i,6,i+1,7-i,7,1,1);
- box(0,6-i,6-i,1,7-i,7-i,1,1);
- delay(30000);
- for (i=0; i<4; i++) {
- an[i]=6*i;
- for (i=0; i<35; i++) {
- clear(0);
- for(j=0; j<4; j++) {
- t=an[j]%24;
- x=dat3[t]>>4;
- y=dat3[t]&0x0f;
- box(x,y,0,x+1,y+1,1,1,1);
- box(x,y,6,x+1,y+1,7,1,1);
- an[j]++;
- delay(10000);
- clear(0);
- t=an[j]%24;
- x=dat3[t]>>4;
- y=dat3[t]&0x0f;
- an[j]--;
- delay(10000);
- clear(0);
- t=an[j]%24;
- x=dat3[t]>>4;
- y=dat3[t]&0x0f;
- box(x,0,y,x+1,1,y+1,1,1);
- box(x,6,y,x+1,7,y+1,1,1);
- an[j]++;
- delay(10000);
- for (i=0; i<36; i++) {
- clear(0);
- t=an[j]%24;
- x=dat3[t]>>4;
- y=dat3[t]&0x0f;
- an[j]--;
- delay(10000);
- for (i=6; i>0; i--) {
- clear(0);
- delay(30000);
- void flash_11()
- uchar i,j,t,x,y;
- uchar code daa[13]= {0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
- for (j=0; j<5; j++) {
- for (i=0; i<13; i++) {
- if (daa[i]>>4) {
- t=daa[i]&0x0f;
- line (0,0,t+1,0,7,t+1,1);
- } else
- t=daa[i];
- line (0,0,t,0,7,t,1);
- transss();
- delay(10000);
- for (j=1; j<8; j++) {
- if (j>3)
- t=4;
- else
- t=j;
- for (i=0; i<24; i+=j) {
- x=dat3[i]>>4;
- y=dat3[i]&0x0f;
- box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
- transss();
- delay(10000);
- if (j>3)
- t=4;
- else
- t=j;
- x=dat3[i]>>4;
- y=dat3[i]&0x0f;
- point (0,x,y,1);
- transss();
- delay(10000);
- void main()
- sinter();
- while(1) {
- // clear(0);
- /*play list*/
- //flash_1();
- clear(0);
- flash_2();
- flash_3();
- flash_4();
- flash_4();
- flash_5();
- flash_5();
- flash_6();
- flash_7();
- flash_8();
- flash_9();
- flash_10();
- clear (0);
- flash_11();
- flash_9();
- flash_5();
- flash_7();
- flash_5();
- flash_6();
- flash_8();
- flash_9();
- flash_10();
- //P0; //573 in
- //P1; //uln2803
- //P2; //573 LE
- void print() interrupt 1
- uchar i;
- static uchar layer=0;
- P1=0;
- P2=1<<i;
- delay(3);
- P0=display[layer][i];
- delay(3);
- P1=1<<layer;
- if (layer<7)
- layer++;
- else
- layer=0;
- TH0=0xc0;
- TL0=0;
