标题:
STM32驱动RC522代码分享
[打印本页]
作者:
小胖波波
时间:
2018-11-29 11:59
标题:
STM32驱动RC522代码分享
这是野火的代码,自己改了以后,可以直插直用,有问题,评论区见
#include "rc522_function.h"
#include "rc522_config.h"
#include "stm32f10x.h"
#include "bsp_SysTick.h"
#define RC522_DELAY() Delay_us ( 200 )
* @brief 向RC522发送1 Byte 数据
* @param byte,要发送的数据
* @retval RC522返回的数据
void SPI_RC522_SendByte ( uint8_t byte )
uint8_t counter;
for(counter=0;counter<8;counter++)
if ( byte & 0x80 )
RC522_MOSI_1 ();
RC522_MOSI_0 ();
RC522_DELAY();
RC522_SCK_0 ();
RC522_DELAY();
RC522_SCK_1();
RC522_DELAY();
byte <<= 1;
* @brief 从RC522发送1 Byte 数据
* @param 无
uint8_t SPI_RC522_ReadByte ( void )
uint8_t counter;
uint8_t SPI_Data;
SPI_Data <<= 1;
RC522_SCK_0 ();
RC522_DELAY();
if ( RC522_MISO_GET() == 1)
SPI_Data |= 0x01;
RC522_DELAY();
RC522_SCK_1 ();
RC522_DELAY();
return SPI_Data;
* @brief 读RC522寄存器
* @param ucAddress,寄存器地址
* @retval 寄存器的当前值
uint8_t ReadRawRC ( uint8_t ucAddress )
uint8_t ucAddr, ucReturn;
ucAddr = ( ( ucAddress << 1 ) & 0x7E ) | 0x80;
RC522_CS_Enable();
SPI_RC522_SendByte ( ucAddr );
ucReturn = SPI_RC522_ReadByte ();
RC522_CS_Disable();
return ucReturn;
* @brief 写RC522寄存器
* @param ucValue,写入寄存器的值
* @retval 无
void WriteRawRC ( uint8_t ucAddress, uint8_t ucValue )
uint8_t ucAddr;
ucAddr = ( ucAddress << 1 ) & 0x7E;
RC522_CS_Enable();
SPI_RC522_SendByte ( ucValue );
RC522_CS_Disable();
* @brief 对RC522寄存器置位
* @param ucReg,寄存器地址
* @param ucMask,置位值
* @retval 无
void SetBitMask ( uint8_t ucReg, uint8_t ucMask )
uint8_t ucTemp;
ucTemp = ReadRawRC ( ucReg );
WriteRawRC ( ucReg, ucTemp | ucMask ); // set bit mask
* @brief 对RC522寄存器清位
* @param ucMask,清位值
* @retval 无
void ClearBitMask ( uint8_t ucReg, uint8_t ucMask )
uint8_t ucTemp;
WriteRawRC ( ucReg, ucTemp & ( ~ ucMask) ); // clear bit mask
* @brief 开启天线
* @param 无
* @retval 无
void PcdAntennaOn ( void )
uint8_t uc;
uc = ReadRawRC ( TxControlReg );
if ( ! ( uc & 0x03 ) )
SetBitMask(TxControlReg, 0x03);
* @brief 关闭天线
* @param 无
* @retval 无
void PcdAntennaOff ( void )
ClearBitMask ( TxControlReg, 0x03 );
* @brief 复位RC522
* @param 无
* @retval 无
void PcdReset ( void )
RC522_Reset_Disable();
Delay_us ( 1 );
RC522_Reset_Enable();
Delay_us ( 1 );
Delay_us ( 1 );
WriteRawRC ( CommandReg, 0x0f );
while ( ReadRawRC ( CommandReg ) & 0x10 );
Delay_us ( 1 );
//定义发送和接收常用模式 和Mifare卡通讯,CRC初始值0x6363
WriteRawRC ( ModeReg, 0x3D );
WriteRawRC ( TReloadRegL, 30 ); //16位定时器低位
WriteRawRC ( TReloadRegH, 0 ); //16位定时器高位
WriteRawRC ( TModeReg, 0x8D ); //定义内部定时器的设置
WriteRawRC ( TPrescalerReg, 0x3E ); //设置定时器分频系数
WriteRawRC ( TxAutoReg, 0x40 ); //调制发送信号为100%ASK
* @brief 设置RC522的工作方式
* @param ucType,工作方式
* @retval 无
void M500PcdConfigISOType ( uint8_t ucType )
if ( ucType == 'A') //ISO14443_A
ClearBitMask ( Status2Reg, 0x08 );
WriteRawRC ( ModeReg, 0x3D ); //3F
WriteRawRC ( RxSelReg, 0x86 ); //84
WriteRawRC( RFCfgReg, 0x7F ); //4F
WriteRawRC( TReloadRegL, 30 );
Delay_us ( 2 );
PcdAntennaOn ();//开天线
* @brief 通过RC522和ISO14443卡通讯
* @param ucCommand,RC522命令字
* @param pInData,通过RC522发送到卡片的数据
* @param ucInLenByte,发送数据的字节长度
* @param pOutData,接收到的卡片返回数据
* @param pOutLenBit,返回数据的位长度
* @retval 状态值= MI_OK,成功
char PcdComMF522 ( uint8_t ucCommand,
uint8_t * pInData,
uint8_t ucInLenByte,
uint8_t * pOutData,
uint32_t * pOutLenBit )
char cStatus = MI_ERR;
uint8_t ucIrqEn = 0x00;
uint8_t ucWaitFor = 0x00;
uint8_t ucLastBits;
uint8_t ucN;
uint32_t ul;
switch ( ucCommand )
case PCD_AUTHENT: //Mifare认证
ucIrqEn = 0x12; //允许错误中断请求ErrIEn 允许空闲中断IdleIEn
ucWaitFor = 0x10; //认证寻卡等待时候 查询空闲中断标志位
break;
case PCD_TRANSCEIVE: //接收发送 发送接收
ucIrqEn = 0x77; //允许TxIEn RxIEn IdleIEn LoAlertIEn ErrIEn TimerIEn
ucWaitFor = 0x30; //寻卡等待时候 查询接收中断标志位与 空闲中断标志位
break;
default:
break;
//IRqInv置位管脚IRQ与Status1Reg的IRq位的值相反
WriteRawRC ( ComIEnReg, ucIrqEn | 0x80 );
//Set1该位清零时,CommIRqReg的屏蔽位清零
ClearBitMask ( ComIrqReg, 0x80 );
//写空闲命令
WriteRawRC ( CommandReg, PCD_IDLE );
//置位FlushBuffer清除内部FIFO的读和写指针以及ErrReg的BufferOvfl标志位被清除
SetBitMask ( FIFOLevelReg, 0x80 );
for ( ul = 0; ul < ucInLenByte; ul ++ )
WriteRawRC ( FIFODataReg, pInData [ ul ] ); //写数据进FIFOdata
WriteRawRC ( CommandReg, ucCommand ); //写命令
if ( ucCommand == PCD_TRANSCEIVE )
//StartSend置位启动数据发送 该位与收发命令使用时才有效
SetBitMask(BitFramingReg,0x80);
ul = 1000; //根据时钟频率调整,操作M1卡最大等待时间25ms
do //认证 与寻卡等待时间
ucN = ReadRawRC ( ComIrqReg ); //查询事件中断
ul --;
} while ( ( ul != 0 ) && ( ! ( ucN & 0x01 ) ) && ( ! ( ucN & ucWaitFor ) ) );
ClearBitMask ( BitFramingReg, 0x80 ); //清理允许StartSend位
if ( ul != 0 )
//读错误标志寄存器BufferOfI CollErr ParityErr ProtocolErr
if ( ! ( ReadRawRC ( ErrorReg ) & 0x1B ) )
cStatus = MI_OK;
if ( ucN & ucIrqEn & 0x01 ) //是否发生定时器中断
cStatus = MI_NOTAGERR;
//读FIFO中保存的字节数
ucN = ReadRawRC ( FIFOLevelReg );
//最后接收到得字节的有效位数
ucLastBits = ReadRawRC ( ControlReg ) & 0x07;
if ( ucLastBits )
//N个字节数减去1(最后一个字节)+最后一位的位数 读取到的数据总位数
* pOutLenBit = ( ucN - 1 ) * 8 + ucLastBits;
* pOutLenBit = ucN * 8; //最后接收到的字节整个字节有效
if ( ucN == 0 )
ucN = 1;
if ( ucN > MAXRLEN )
ucN = MAXRLEN;
for ( ul = 0; ul < ucN; ul ++ )
pOutData [ ul ] = ReadRawRC ( FIFODataReg );
cStatus = MI_ERR;
SetBitMask ( ControlReg, 0x80 ); // stop timer now
return cStatus;
* @brief 寻卡
* @param ucReq_code,寻卡方式 = 0x52,寻感应区内所有符合14443A标准的卡;
寻卡方式= 0x26,寻未进入休眠状态的卡
* @param pTagType,卡片类型代码
= 0x4400,Mifare_UltraLight
= 0x0400,Mifare_One(S50)
= 0x0200,Mifare_One(S70)
= 0x0800,Mifare_Pro(X))
= 0x4403,Mifare_DESFire
char PcdRequest ( uint8_t ucReq_code, uint8_t * pTagType )
char cStatus;
uint8_t ucComMF522Buf [ MAXRLEN ];
uint32_t ulLen;
//清理指示MIFARECyptol单元接通以及所有卡的数据通信被加密的情况
//发送的最后一个字节的 七位
WriteRawRC ( BitFramingReg, 0x07 );
//TX1,TX2管脚的输出信号传递经发送调制的13.56的能量载波信号
SetBitMask ( TxControlReg, 0x03 );
ucComMF522Buf [ 0 ] = ucReq_code; //存入 卡片命令字
cStatus = PcdComMF522 ( PCD_TRANSCEIVE,
ucComMF522Buf,
1,
ucComMF522Buf,
& ulLen ); //寻卡
if ( ( cStatus == MI_OK ) && ( ulLen == 0x10 ) ) //寻卡成功返回卡类型
* pTagType = ucComMF522Buf [ 0 ];
* ( pTagType + 1 ) = ucComMF522Buf [ 1 ];
cStatus = MI_ERR;
return cStatus;
* @brief 防冲撞
* @param pSnr,卡片序列号,4字节
char PcdAnticoll ( uint8_t * pSnr )
char cStatus;
uint8_t uc, ucSnr_check = 0;
uint32_t ulLen;
//清MFCryptol On位 只有成功执行MFAuthent命令后,该位才能置位
//清理寄存器 停止收发
WriteRawRC ( BitFramingReg, 0x00);
//清ValuesAfterColl所有接收的位在冲突后被清除
ClearBitMask ( CollReg, 0x80 );
ucComMF522Buf [ 0 ] = 0x93; //卡片防冲突命令
ucComMF522Buf [ 1 ] = 0x20;
ucComMF522Buf,
2,
ucComMF522Buf,
& ulLen); //与卡片通信
if ( cStatus == MI_OK) //通信成功
for ( uc = 0; uc < 4; uc ++ )
* ( pSnr + uc ) = ucComMF522Buf [ uc ]; //读出UID
ucSnr_check ^= ucComMF522Buf [ uc ];
if ( ucSnr_check != ucComMF522Buf [ uc ] )
cStatus = MI_ERR;
SetBitMask ( CollReg, 0x80 );
return cStatus;
* @brief 用RC522计算CRC16
* @param pIndata,计算CRC16的数组
* @param ucLen,计算CRC16的数组字节长度
* @param pOutData,存放计算结果存放的首地址
* @retval 无
void CalulateCRC ( uint8_t * pIndata,
uint8_t ucLen,
uint8_t * pOutData )
uint8_t uc, ucN;
ClearBitMask(DivIrqReg,0x04);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
for ( uc = 0; uc < ucLen; uc ++)
WriteRawRC ( FIFODataReg, * ( pIndata + uc ) );
WriteRawRC ( CommandReg, PCD_CALCCRC );
uc = 0xFF;
do
ucN = ReadRawRC ( DivIrqReg );
uc --;
} while ( ( uc != 0 ) && ! ( ucN & 0x04 ) );
pOutData [ 0 ] = ReadRawRC ( CRCResultRegL );
pOutData [ 1 ] = ReadRawRC ( CRCResultRegM );
* @brief 选定卡片
char PcdSelect ( uint8_t * pSnr )
char ucN;
uint8_t uc;
uint32_t ulLen;
ucComMF522Buf [ 0 ] = PICC_ANTICOLL1;
ucComMF522Buf [ 1 ] = 0x70;
ucComMF522Buf [ 6 ] = 0;
ucComMF522Buf [ uc + 2 ] = * ( pSnr + uc );
ucComMF522Buf [ 6 ] ^= * ( pSnr + uc );
CalulateCRC ( ucComMF522Buf, 7, & ucComMF522Buf [ 7 ] );
ucN = PcdComMF522 ( PCD_TRANSCEIVE,
ucComMF522Buf,
9,
ucComMF522Buf,
& ulLen );
if ( ( ucN == MI_OK ) && ( ulLen == 0x18 ) )
ucN = MI_OK;
ucN = MI_ERR;
return ucN;
* @brief 验证卡片密码
* @param ucAuth_mode,密码验证模式= 0x60,验证A密钥,
密码验证模式= 0x61,验证B密钥
* @param uint8_t ucAddr,块地址
* @param pKey,密码
char PcdAuthState ( uint8_t ucAuth_mode,
uint8_t ucAddr,
uint8_t * pKey,
uint8_t * pSnr )
char cStatus;
uint8_t uc, ucComMF522Buf [ MAXRLEN ];
uint32_t ulLen;
ucComMF522Buf [ 0 ] = ucAuth_mode;
ucComMF522Buf [ 1 ] = ucAddr;
for ( uc = 0; uc < 6; uc ++ )
ucComMF522Buf [ uc + 2 ] = * ( pKey + uc );
ucComMF522Buf [ uc + 8 ] = * ( pSnr + uc );
cStatus = PcdComMF522 ( PCD_AUTHENT,
ucComMF522Buf,
12,
ucComMF522Buf,
& ulLen );
if ( ( cStatus != MI_OK ) || ( ! ( ReadRawRC ( Status2Reg ) & 0x08 ) ) )
cStatus = MI_ERR;
return cStatus;
* @brief 写数据到M1卡一块
* @param pData,写入的数据,16字节
char PcdWrite ( uint8_t ucAddr, uint8_t * pData )
char cStatus;
uint32_t ulLen;
ucComMF522Buf [ 0 ] = PICC_WRITE;
CalulateCRC ( ucComMF522Buf, 2, & ucComMF522Buf [ 2 ] );
ucComMF522Buf,
4,
ucComMF522Buf,
& ulLen );
if ( ( cStatus != MI_OK ) || ( ulLen != 4 ) ||
( ( ucComMF522Buf [ 0 ] & 0x0F ) != 0x0A ) )
cStatus = MI_ERR;
if ( cStatus == MI_OK )
//memcpy(ucComMF522Buf, pData, 16);
for ( uc = 0; uc < 16; uc ++ )
ucComMF522Buf [ uc ] = * ( pData + uc );
CalulateCRC ( ucComMF522Buf, 16, & ucComMF522Buf [ 16 ] );
ucComMF522Buf,
18,
ucComMF522Buf,
& ulLen );
cStatus = MI_ERR;
return cStatus;
* @brief 读取M1卡一块数据
* @param ucAddr,块地址
* @param pData,读出的数据,16字节
char PcdRead ( uint8_t ucAddr, uint8_t * pData )
char cStatus;
uint32_t ulLen;
ucComMF522Buf [ 0 ] = PICC_READ;
…………限于本文篇幅 余下代码请从51黑下载附件…………
F103-指南者开发板配套例程.rar
(343.49 KB, 下载次数: 25)
2018-12-2 01:49 上传
点击文件名下载附件
下载积分: 黑币 -5
欢迎光临 (http://www.51hei.com/bbs/)
Powered by Discuz! X3.1
