查看: 2690|回复: 1
机器人自动导航建图源码 xbot_slam-master
ID:232294 发表于 2018-11-30 10:56 | 显示全部楼层 |阅读模式
机器人自动导航建图源码
  1. #include "ros/ros.h"
  2. #include "std_msgs/String.h"
  3. #include <sstream>
  4. int main(int argc, char **argv)
  5. {
  6.   ros::init(argc, argv, "subgoal");
  7.   ros::NodeHandle n;
  8.   ros::Publisher chatter_pub = n.advertise<std_msgs::String>("chatter", 1000);
  9.   ros::Rate loop_rate(10);
  10.   int count = 0;
  11.   while (ros::ok())
  12.   {
  13.     /**
  14.      * This is a message object. You stuff it with data, and then publish it.
  15.      */
  16.     std_msgs::String msg;
  17.     std::stringstream ss;
  18.     ss << "hello world " << count;
  19.     msg.data = ss.str();
  20.     ROS_INFO("%s", msg.data.c_str());
  21.     /**
  22.      * The publish() function is how you send messages. The parameter
  23.      * is the message object. The type of this object must agree with the type
  24.      * given as a template parameter to the advertise<>() call, as was done
  25.      * in the constructor above.
  26.      */
  27.     chatter_pub.publish(msg);
  28.     ros::spinOnce();
  29.     loop_rate.sleep();
  30.     ++count;
  31.   }
  32.   return 0;
  33. }
xbot_slam-master.zip (390.82 KB, 下载次数: 24)
ID:232294 发表于 2018-11-30 10:59 | 显示全部楼层
这个包含了仿真程序,可以直接在linux下使用
