查看: 1908|回复: 0
LCD显示环境温度 proteus+keilC51
#include<reg51.h>
#include<intrins.h>
#define uint unsigned int
sbit rs=P2^0;
sbit rd=P2^1;
sbit lcden=P2^2;
sbit DQ=P3^0;
float TM;
int tvalue;
unsigned char tflag;
unsigned char data disdata[5];
void delay(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(unsigned char com)
        rs=0;
        rd=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(unsigned char date)
        rs=1;
        rd=0;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void delay_18B20(unsigned int i)
         while(i--);
void ds1820rst()     /*ds1820¸′λ*/
         unsigned char x=0;
         DQ = 1;
         delay_18B20(4);
         DQ = 0;
         delay_18B20(80);
         DQ = 1;
         delay_18B20(20);
   x=DQ;
   delay(30);
   DQ=1;
uchar ds1820rd()
                unsigned char i=0;
          unsigned char dat = 0;
          for (i=8;i>0;i--)
                        DQ = 0;
                  dat>>=1;
                  DQ = 1;
                  if(DQ)
                  dat|=0x80;
                  delay_18B20(10);
           return(dat);
        void ds1820wr(uchar wdata)
                unsigned char i=0;
    for (i=8; i>0; i--)
                        DQ = 0;
      DQ = wdata&0x01;      //
      delay_18B20(10);
      DQ = 1;
      wdata>>=1;
read_temp()
        unsigned char a,b;
  ds1820rst();
  ds1820wr(0xcc);
  ds1820wr(0x44);
  ds1820rst();
  ds1820wr(0xcc);
  ds1820wr(0xbe);
  a=ds1820rd();
  b=ds1820rd();
  tvalue=b;
  tvalue<<=8;
  tvalue=tvalue|a;
        TM=tvalue*0.625;
        tvalue=TM*1+0.5;
    if(tvalue<0x0FFF)
    tflag=0;
   {tvalue=~tvalue+1;
         tflag=1;
    tvalue=tvalue*(0.425);
        return(tvalue);
        void ds1820disp()
                unsigned char flagdat;
          disdata[0]=tvalue/1000+0x30;
    disdata[1]=tvalue%1000/100+0x30;
    disdata[2]=tvalue%100/10+0x30;
    disdata[3]=tvalue%10+0x30;
    if(tflag==0)
            flagdat=0x20;
       flagdat=0x2d;
    if(disdata[0]==0x30)
          {disdata[0]=0x20;
                if(disdata[1]==0x30)
                {disdata[1]=0x20;
           write_com(0x80+0x40);
           write_date(flagdat);
           write_com(0x80+0x41);
           write_date(disdata[0]);
           write_com(0x80+0x42);
           write_date(disdata[1]);
           write_com(0x80+0x43);
           write_date(disdata[2]);
           write_com(0x80+0x44);
           write_date(0x2e);
           write_com(0x80+0x45);
           write_date(disdata[3]);
           write_com(0x80+0x46);
           write_date('C');
void InitLcd1602()
  write_com(0x38);
  write_com(0x0C);
  write_com(0x06);
  write_com(0x01);
  lcden=0;
        InitLcd1602();
                read_temp();
          ds1820disp();
新手勿喷。
