查看: 1313|回复: 1
51单片机超声波测距+12864显示
ID:438586 发表于 2018-12-12 21:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        #include   <intrins.h>
//引脚定义
    sbit     RX    =  P1 ^ 1;
    sbit     TX    =  P1 ^ 2;
    sbit     CS    =  P3 ^ 3;        //片选 高电平有效 单片LCD使用时可固定高电平
    sbit     SID   =  P3 ^ 4;        //数据
    sbit     SCLK  =  P3 ^ 5;        //时钟
//Function Definition 函数声明
void Delay(int num);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
unsigned int ReadTemperature(void);
void clock_out(unsigned char dd);
unsigned char clock_in(void);
unsigned char read_clock(unsigned char ord);
void write_clock(unsigned char ord, unsigned char dd);
void Disp(void);
void id_case1_key(void);
void id_case2_key(void);
void Set_time(unsigned char sel,bit sel_1);
void Timer0_Init(void);
void Init_1302(void);
void Set_Bell(unsigned char sel, bit sel_1);
void Bell(void);
//12864
void Write_char(bit start, unsigned char ddata);
void Send_byte(unsigned char bbyte);
void Delaynms(unsigned int di);
void Lcd_init(void);
void Disp_img(unsigned char *img);
void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_set_xy( unsigned char x, unsigned char y );
unsigned char code num[]={"0123456789 :.-"};
unsigned char code waves[]={"超声波测距系统"};
unsigned char code znwk[] ={"智能微控工作室"};
unsigned char code CM[] =  {"M"};
unsigned int  time=0;
         long S=0;
         bit  flag =0;
unsigned char disbuff[4]           ={ 0,0,0,0,};
unsigned char code logo[]={
/*--  调入了一幅图像:logo.bmp  -- */
/*--  宽度x高度=128x64 欢迎使用本产品LOGO --*/
/*--  调入了一幅图像:C:\Documents and Settings\lwd\桌面\新建文件夹\X.bmp  --*/
/*--  宽度x高度=128x64  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x0C,0x00,0x00,0x40,0x70,0x00,0x00,0x00,0x80,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x1E,0x00,0x00,0x60,0x70,0x00,0x00,0x0F,0xE0,0x00,
0x00,0x00,0x01,0xC0,0x00,0x60,0x3C,0x00,0x00,0xE0,0x60,0x00,0x1F,0xFF,0xE0,0x00,
0x00,0x00,0x03,0x80,0x00,0x70,0x70,0x40,0x00,0xE0,0x7E,0x00,0x1F,0xE0,0xC0,0x00,
0x00,0x00,0x03,0x00,0x00,0x73,0xC3,0xF0,0x01,0xC3,0xFC,0x00,0x38,0xE1,0xC0,0x00,
0x00,0x03,0xC6,0x3C,0x00,0x33,0x9F,0xF0,0x03,0x8F,0xC0,0x00,0x30,0xC1,0xC0,0x00,
0x00,0x3F,0xEF,0xFE,0x00,0x03,0x1C,0xE0,0x07,0x01,0xCC,0x00,0x31,0xF1,0x80,0x00,
0x00,0x79,0xDF,0xBC,0x00,0x06,0x18,0xC0,0x0E,0x01,0xFE,0x00,0x77,0xF9,0x80,0x00,
0x00,0x01,0xB0,0x30,0x01,0xC6,0x19,0xC0,0x1E,0x7F,0xDE,0x00,0x6F,0x83,0x80,0x00,
0x00,0x23,0xAC,0x60,0x0F,0xE6,0xF1,0x80,0x3E,0x7B,0x38,0x00,0x61,0x83,0x00,0x00,
0x00,0x37,0x0E,0x00,0x0F,0xC7,0xB7,0x80,0xEC,0x63,0x30,0x00,0xE3,0x03,0x00,0x00,
0x00,0x3E,0x0E,0x00,0x01,0x8F,0x37,0x01,0xCC,0x6F,0xF0,0x00,0xC7,0xF7,0x00,0x00,
0x00,0x1E,0x0C,0x00,0x03,0x1E,0x66,0x03,0x0C,0x7F,0x00,0x01,0xFF,0xE6,0x00,0x00,
0x00,0x1E,0x1C,0x00,0x03,0x1C,0x60,0x02,0x19,0xAC,0x00,0x01,0x96,0x06,0x00,0x00,
0x00,0x3E,0x3E,0x00,0x03,0x18,0x60,0x00,0x19,0xFC,0x00,0x03,0x86,0x0E,0x00,0x00,
0x00,0x7E,0x36,0x00,0x03,0x00,0xC0,0x00,0x38,0x78,0x00,0x03,0x06,0x0C,0x00,0x00,
0x00,0xE6,0x67,0x00,0x03,0x00,0xC0,0x00,0x30,0x78,0x00,0x06,0x0C,0x0C,0x00,0x00,
0x01,0xC6,0xC3,0x80,0x7F,0xF0,0xC0,0x00,0x30,0xFE,0x00,0x0E,0x0C,0x1C,0x00,0x00,
0x03,0x81,0x83,0xC0,0x78,0xFF,0x80,0x00,0x61,0xCF,0x80,0x1C,0x08,0x18,0x00,0x00,
0x06,0x07,0x03,0xE0,0x00,0x1F,0xFF,0xE0,0x67,0x07,0xE0,0x38,0x18,0xF8,0x00,0x00,
0x08,0x0E,0x01,0xF8,0x00,0x07,0xFF,0x80,0xCE,0x03,0xF8,0x60,0x00,0x70,0x00,0x00,
0x00,0x18,0x01,0xF8,0x00,0x01,0xFC,0x00,0xC0,0x01,0xFC,0xC0,0x00,0x70,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x0C,0xE0,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0E,0x00,0x00,0x00,0x3F,0xE0,0x00,0xFF,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0x00,0x00,0x0F,0xFF,0x80,0x00,0xF8,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0xF0,0x00,0x0F,0xC7,0x00,0x00,0x60,0xE0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x1F,0xF0,0x00,0x01,0x8E,0x00,0x00,0x60,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xFF,0x80,0x00,0x01,0x8C,0x00,0x00,0xE1,0x80,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xF8,0x00,0x00,0x01,0x98,0x00,0x00,0xDF,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x00,0x78,0x00,0x00,0x01,0xBF,0xE0,0x00,0xFF,0x00,0x00,0x60,0x01,0x80,0x00,
0x00,0x00,0xFC,0x00,0x00,0x7F,0xFF,0xE0,0x00,0xC0,0x00,0x00,0xE0,0x03,0x80,0x00,
0x00,0x01,0xFE,0x00,0x00,0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0x00,0x00,
0x00,0x03,0xB7,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x3C,0x00,0xC0,0x03,0x00,0x00,
0x00,0x07,0x67,0x00,0x00,0x60,0x00,0x00,0x03,0x9F,0xFE,0x00,0x80,0x02,0x00,0x00,
0x00,0x0E,0x63,0x80,0x00,0xE0,0x00,0x01,0xFF,0xCF,0x1E,0x01,0x80,0x06,0x00,0x00,
0x00,0x1C,0xE1,0xE0,0x00,0xC0,0x00,0x00,0xE3,0x9C,0x38,0x01,0x80,0x06,0x00,0x00,
0x00,0x38,0xC1,0xF8,0x01,0xC0,0x00,0x00,0xC3,0x18,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0xFC,0xFE,0x03,0x80,0x00,0x01,0xC7,0x18,0x60,0x00,0x00,0x00,0x00,0x00,
0x01,0xDF,0xF8,0xFE,0x03,0x00,0x00,0x01,0x8E,0x1B,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x07,0x07,0x80,0x00,0x07,0x00,0x00,0x01,0xFF,0x3F,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x0C,0x03,0x80,0x00,0x0E,0x00,0x00,0x01,0xF0,0x38,0x00,0x0F,0x00,0x3C,0x00,0x00,
0x00,0x03,0x00,0x00,0x1C,0x00,0x00,0x01,0x00,0x20,0x00,0x06,0x00,0x18,0x00,0x00,
0x00,0x03,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x03,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void Lcd_init(void)        //初始化LCD
        Delaynms(10); //启动等待,等LCM讲入工作状态
          CS=1;
          Write_char(0,0x30);  //8 位介面,基本指令集
          Write_char(0,0x0c);  //显示打开,光标关,反白关
          Write_char(0,0x01);  //清屏,将DDRAM的地址计数器归零
void Write_char(bit start, unsigned char ddata) //写指令或数据
        unsigned char start_data,Hdata,Ldata;
          if(start==0)
                start_data=0xf8;         //写指令
            start_data=0xfa;  //写数据
          Hdata=ddata&0xf0;                  //取高四位
          Ldata=(ddata<<4)&0xf0;  //取低四位
          Send_byte(start_data);          //发送起始信号
          Delaynms(5); //延时是必须的
          Send_byte(Hdata);              //发送高四位
          Delaynms(1);  //延时是必须的
          Send_byte(Ldata);                  //发送低四位
void Send_byte(unsigned char bbyte) //发送一个字节
        unsigned char i;
        for(i=0;i<8;i++)
                   SID=bbyte&0x80; //取出最高位
                SCLK=1;
                   SCLK=0;
                   bbyte<<=1; //左移
void Delaynms(unsigned int di) //延时
        unsigned int da,db;
        for(da=0;da<di;da++)
                   for(db=0;db<10;db++);
void Disp_img(unsigned char  *img)        //图形方式12864显示字模221 横向取膜
        unsigned char i,j;
        unsigned int k = 0;
        Write_char(0,0x36); //图形方式
        for(i=0;i<32;i++)
                Write_char(0,0x80+i);
                Write_char(0,0x80);
            for(j=0;j<16;j++)
                        Write_char(1,img[k++]);
        for(i=0;i<32;i++)
                Write_char(0,0x88);
            for(j=0;j<16;j++)
void Clr_Scr(void)//清屏函数
        Write_char(0,0x01);
{        //设置LCD显示的起始位置,X为行,Y为列
    unsigned char address;
        switch(x)
                case 0: address = 0x80 + y; break;
            case 1: address = 0x80 + y; break;
                case 2: address = 0x90 + y; break;
                    case 3: address = 0x88 + y; break;
                case 4: address = 0x98 + y; break;
                default:address = 0x80 + y; break;
    Write_char(0, address);
{        //        中英文字符串显示函数
        LCD_set_xy( X, Y );
    while (*s)
                Write_char( 1, *s );
            s ++;
                Delaynms(1);
void LCD_Write_number(unsigned char s)//        数字显示函数
        Write_char(1,num[s]);
        Delaynms(1);
void Lcd_Mark2(void)
        Clr_Scr();//清屏
        LCD_Write_string(1,0,znwk);//
        LCD_Write_string(2,0,waves);//
        LCD_Write_string(3,7,CM);//
    void Conut(void)
           time=TH0*256+TL0;
           TH0=0;
           TL0=0;
           S=time*1.87/100;       //算出来是CM          11。0592M晶振
           if(flag==1)                      //超出测量
           flag=0;
           LCD_set_xy( 3, 4 );
           LCD_Write_number(13);
           LCD_Write_number(12);
           LCD_set_xy( 3, 5 );
           disbuff[1]=S%1000/100;
           disbuff[2]=S%1000%100/10;
           disbuff[3]=S%1000%10 %10;
           LCD_set_xy( 3, 4 );
           LCD_Write_number(disbuff[1]);
           LCD_set_xy( 3, 5 );
           LCD_Write_number(disbuff[2]);
           LCD_Write_number(disbuff[3]);
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
     void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
    flag=1;                                                         //中断溢出标志
   void  StartModule()                          //T1中断用来扫描数码管和计800MS启动模块
          TX=1;                                         //800MS  启动一次模块
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
void main(void)
    TMOD=0x01;                   //设T0为方式1,GATE=1
        TH0=0;
        TL0=0;
        TR0=1;
        Lcd_init();       //设置液晶显示器
        Clr_Scr();        //清屏
        Disp_img(logo);          //显示欢迎使用本产品LOGO
        Delaynms(1000);
        Lcd_init();       //从图形显示状态下返回
    Lcd_Mark2();
         StartModule();
                                         //计算
         while(!RX);                //当RX为零时等待
         TR0=1;                            //开启计数
         while(RX);                        //当RX为1计数并等待
         TR0=0;                                //关闭计数
         Conut();
         delayms(80);                //80MS
ID:1 发表于 2018-12-14 01:22 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
