LCD12864温度检测显示程序(ATmega16)
制作出来的实物图如下:
- ATmega64并行控制不带字库的12864程序
- 实验内容:LCD12864
- 硬件连接:
- LCD12864 -------- ATmega64
- 1.GND -------- GND
- 2.VCC -------- VCC
- 3.V0 -------- NC
- 4.RS(CS) -------- PB0
- 5.R/W(SID) -------- PB1
- 6.E(SCLK) -------- PB2
- 7.D0 -------- PA0
- 8.D1 -------- PA1
- 9.D2 -------- PA2
- 10.D3 -------- PA3
- 11.D4 -------- PA4
- 12.D5 -------- PA5
- 13.D6 -------- PA6
- 14.D7 -------- PA7
- 15.PSB -------- VCC
- 16.NC -------- NC
- 17.RST -------- VCC
- 18.NC -------- NC
- 19.LED+ -------- VCC
- 20.LED- -------- GND
- 编译烧写该程序到ATmega64
- 上电,如果操作正确,这时您可以看到显示的内容了
- //头文件定义
- #include<iom16v.h>
- #include<macros.h>
- //#include<string.h>
- //#include <stdio.h>
- //#include<stdlib.h>
- //宏定义
- #define uchar unsigned char
- #define uint unsigned int
- //LCD12864液晶显示(数据线端口)
- #define rs_h PORTB |= BIT(PB0)//数据/命令选择
- #define rs_l PORTB &=~BIT(PB0)
- #define rw_h PORTB |= BIT(PB1)//读/写选择
- #define rw_l PORTB &=~BIT(PB1)
- #define en_h PORTB |= BIT(PB2)//使能信号
- #define en_l PORTB &=~BIT(PB2)
- //温度18b20(数据线端口)
- #define tmp (PINB&BIT(PB3))
- #define temp_h PORTB |= BIT(PB3)
- #define temp_l PORTB &=~BIT(PB3)
- #define temp_o DDRB |= BIT(PB3)
- #define temp_i DDRB &=~BIT(PB3)
- //数组定义
- unsigned char dis1[]={"黄俊华,啊蠢。"};
- unsigned char dis2[]={"曾志成,啊成。"};
- unsigned char dis3[]={"梁毓毅,啊毓。"};
- unsigned char dis4[]={"柳艺明,啊明。"};
- unsigned char dis1[]={"温度检测"};
- unsigned char dis2[]={"℃"};
- //温度18b20(变量定义)
- unsigned char dat1=0x00;//保存读出的温度 L
- unsigned char dat2=0x00;//保存读出的温度 H
- unsigned long int dat=0;//保存读出的温度 XS
- unsigned char flag=0;//错误标志位
- unsigned char keyvalue=0;//返回值变量
- unsigned char tempH=30;//温度H
- unsigned char tempL=20;//温度L
- //按键定义
- unsigned char key1=0;
- unsigned char key2=0;
- //unsigned char key3=0;
- //unsigned char key4=0;
- //************************* IO 端口定义 **********************//
- void IO_init(void)
- DDRA = 0XFF;
- DDRB = 0XFF;
- //DDRC = 0XFF;
- //DDRD = 0XFF;
- //PORTA = 0X00;
- //PORTB = 0X00;
- //PORTC = 0X00;
- //PORTD = 0X00;
- //************************* 延时函数 **********************//
- void delayms(uint z) //8M晶振下,延时1ms
- uint x,y;
- for(x=z;x>0;x--)
- for(y=1333;y>0;y--);
- //************************* LCD12864 **********************//
- void LCD_clear(void)//清屏函数
- write_com(0x01);
- delayms(5);
- void lcd_en(void) //en端产生一个高电平脉冲,控制LCD写时序
- delayms(5);//延时5ms
- en_h;
- en_l;
- void write_com(uchar com)//向LCD12864写命令
- rs_l;
- rw_l;
- en_h;
- PORTA=com;
- lcd_en();//写入命令
- void write_dat(uchar dat)//向LCD12864写数据
- rs_h;
- rw_l;
- en_h;
- PORTA=dat;
- lcd_en();//写入数据
- void LCD_init(void)//LCD显示屏初始化函数
- write_com(0x30);//设置8位数据总线,DB7~DB0;
- write_com(0x0c);//开显示,光标不显示;
- write_com(0x01);//清屏
- void LCD_pos(uchar x,uchar y)//字符显示初始地址设置
- uchar pos;
- if(x==0)//第一行显示
- x=0x80;
- else if(x==1)//第二行显示
- x=0x90;
- else if(x==2)//第三行显示
- x=0x88;
- else if(x==3)//第四行显示
- x=0x98;
- pos=x+y;
- write_com(pos);
- void LCD_write_str(uchar x,uchar y,uchar *s)//在第X行Y列开始显示,指针*S所指向的字符串
- LCD_pos(x,y);//设置初始字符显示地址
- while(*s)//逐次写入显示字符,直到最后一个字符"/0"
- write_dat(*s);//写入当前字符并显示
- s++;//地址指针加1,指向下一个待写字符
- void LCD_write_char(uchar x,uchar y,uchar Wdata)//在第X行Y列开始显示Wdata所对应的单个字符
- write_dat(Wdata);//写入当前字符并显示
- //************************* 18B20 **********************//
- void Ds18b20_reset(void)//DS18B20初始化
- uint count;
- temp_o;
- temp_l;
- for(count=700;count>0;count--);//延时480us
- temp_h;
- temp_i;//不须配置PORT内部上拉电阻,MCU输入输出自动切换
- while((tmp==0x08));//&&(i>0)) i--;
- void Ds18b20_write(uchar dat)//向DS18B20写一个字节
- uchar count;
- uchar i;
- temp_o;
- for(i=8;i>0;i--)
- temp_l;
- for(count=2;count>0;count--);
- //temp_h;//不能有此语句
- if(dat&0x01==0x01)
- temp_h;
- else
- temp_l;
- for(count=120;count>0;count--);//延时60us
- temp_h;
- dat>>=1;
- uchar Ds18b20_read(void)//从DS18B20读一个字节
- uchar i,datt;
- uchar count;
- for(i=8;i>0;i--)
- datt>>=1;
- temp_o;
- temp_l;
- temp_h;//此语句必须有,参考datasheet的P15
- for(count=1;count>0;count--);
- temp_i;
- if(tmp==0x08)
- datt|=0x80;
- for(count=120;count>0;count--); //延时60us
- return datt;
- void temp_display(void)//温度显示
- Ds18b20_reset();//DS18B20初始化
- Ds18b20_write(0xcc);//跳过ROM
- Ds18b20_write(0x44);//发送温度转换命令
- delayms(1000);//延时1s,等待温度转换完成
- Ds18b20_write(0xbe);//发送读温度寄存器命令
- dat1=Ds18b20_read();//读温度值的低字节
- dat2=Ds18b20_read();//读温度值的高字节
- if(dat2>=240)//dat2温度值的高字节为1时为负温度
- dat=(~(dat2*256+dat1)+1)*0.625;//负温度:取反加一,保留一位小数
- flag=1;
- else
- dat=(dat2*256+dat1)*0.625;
- flag=0;
- /******************************************************* 正负温度显示 **/
- if(flag==1)//负温度显示
- LCD_write_str(0,0,"18B20 温度检测"); //字符:18B20 温度检测
- LCD_write_str(1,0,"负温度:"); //字符:负温度
- LCD_write_str(1,6,"℃"); //符号:℃
- LCD_write_char(1,4,0x30+dat/100);
- LCD_write_char(1,5,0x30+dat%100/10);
- if(flag==0)//正温度显示
- LCD_write_str(1,0,"正温度:"); //字符:正温度
- void tempH_Setting(void)//最高温度设置显示
- LCD_write_str(0,1,"18B20 (高)"); //字符:18B20 高温度设置
- LCD_write_str(1,0,"温度设置:"); //字符:高温度设置
- LCD_write_str(1,7,"℃"); //符号:℃
- LCD_write_char(1,5,0x30+tempH%100/10);
- LCD_write_char(1,6,0x30+tempH%10);
- void tempL_Setting(void)//最低温度设置显示
- LCD_write_str(0,1,"18B20 (低)"); //字符:18B20 低温度设置
- LCD_write_str(1,0,"温度设置:"); //字符:18B20 低温度设置
- LCD_write_char(1,5,0x30+tempL%100/10);
- LCD_write_char(1,6,0x30+tempL%10);
- void temp_police(void)//温度报警
- if(dat/10>=tempH)//最高检测温度>=设定温度:D1灯亮
- PORTC&=~BIT(0);
- LCD_write_str(3,0,"D1: 亮");
- else//反之:灯灭
- PORTC|= BIT(0);
- LCD_write_str(3,0,"D1: 灭");
- if(dat/10<=tempL)//最低检测温度<=设定温度:D2灯亮
- PORTC&=~BIT(1);
- LCD_write_str(3,4,"D2: 亮");
- else//反之:灯灭
- PORTC|= BIT(1);
- LCD_write_str(3,4,"D2: 灭");
- //*************************** 按键扫描 ************************//
- uchar keys(void)
- if(!(PIND&BIT(0)))//温度显示
- delayms(20);
- LCD_clear();//LCD清屏
- keyvalue=0;
- while(!(PIND&BIT(0)));//等待按键抬起
- if(!(PIND&BIT(1)))//最高、最低温度设置选择
- delayms(20);
- key1=key1+1;
- switch(key1)
- case 1:
- tempH_Setting();//最高温度设置显示
- temp_police();//温度报警
- //temp_display();//温度显示
- keyvalue=1;//按键最高温度返回值:1
- break;
- case 2:
- tempL_Setting();//最低温度设置显示
- keyvalue=2;//按键最低温度返回值:2
- key1=0;//按键清零
- break;
- while(!(PIND&BIT(1)));//等待按键抬起
- if(!(PIND&BIT(2)))//温度加
- delayms(20);
- if(keyvalue==1)
- tempH++;
- if(tempH>=100)
- tempH=100;
- else if(keyvalue==2)
- tempL++;
- if(tempL>=100)
- tempL=100;
- //while(!(PIND&BIT(2)));//等待按键抬起
- if(!(PIND&BIT(3)))//温度减
- delayms(20);
- if(keyvalue==1)
- tempH--;
- if(tempH<=10)
- tempH=10;
- tempL--;
- if(tempL<=10)
- tempL=10;
- //while(!(PIND&BIT(3)));//等待按键抬起
- //*************************** 主函数 ************************//
- void main()
- uchar i;
- IO_init();//端口初始化
- LCD_init();//LCD显示屏初始化函数
- while(1)
- keys();//按键扫描
- if(keyvalue==0)
- temp_display();//温度显示
LCD12864(ATmeg16).zip
(58.13 KB, 下载次数: 38)
