查看: 3660|回复: 8
2019过年还有多少天____看过来
ID:21069 发表于 2018-12-18 18:57 | 显示全部楼层 |阅读模式
名称:2018过年倒计时
#include<reg51.h>
#include<intrins.h>
#include "delay.h"
#define clock_segment XBYTE[0xBFFF] //时钟段码地址
#define clock_sel XBYTE[0x7FFF]     //时钟位码地址
#define year_segment XBYTE[0xEFFF]  //日历段码地址
#define year_sel XBYTE[0xDFFF]      //日历位码地址
#define retime_segment XBYTE[0xFBFF]//倒计时段码地址
#define retime_sel XBYTE[0xF7FF]    //倒计时位码地址
unsigned char time_num=0;//定时一秒次数
unsigned char shi_num=24;//小时位计数
unsigned char miao_ge=0; //秒个位
unsigned char miao_shi=0;//秒十位
unsigned char fen_ge=0;//分个位
unsigned char fen_shi=0;//分十位
unsigned char shi_ge=0;//时个位
unsigned char shi_shi=0;//时十位
unsigned char year_thousand=2;
unsigned char year_hundred=0;
unsigned char year_decade=1;
unsigned char year_unit=8;
unsigned char month_decade = 1;
unsigned char month_unit=2;
unsigned char day_decade=1;
unsigned char day_unit=8;
unsigned char retime_unit=3;
unsigned char retime_decade=1;
unsigned char retime_hundred=0;
unsigned char retime_thousand=0;
unsigned char year_thoustore; //保存年千位数据
unsigned char year_hundstore; //保存年百位数据
unsigned char year_decastore; //保存年十位数据
unsigned char year_unitstore; //保存年个位数据
unsigned char month_unitstore;//保存月个位数据
unsigned char month_decastore;//保存月十位数据
unsigned char day_unitstore;  //保存日个位数据
unsigned char day_decastore;  //保存日十位数据
unsigned char year_unitstore2;//保存年各位数据
unsigned char year_decastore2;//年位组合子程序用来保护数据用
unsigned char year_hundstore2;
unsigned char year_thoustore2;
unsigned char retime_ustore;  //保存倒计时各位数据
unsigned char retime_dstore;
unsigned char retime_hstore;
unsigned char retime_tstore;
unsigned char day_numj=31;  //奇数月31天
unsigned char day_numo=30;  //偶数月30天
unsigned char day_numooo=30;
unsigned char day_numoo;
unsigned char month_num=12;
unsigned int year_jointed; //年各位组合在一起,以便进行闰年判断
unsigned int year_help1;
unsigned int year_help2;
unsigned char xiaoshi_ge;//闪烁时存小时个位
unsigned char xiaoshi_shi;//闪烁时存小时十位
unsigned char fenzhong_ge;//闪烁时存分钟个位
unsigned char fenzhong_shi;//闪烁时存分钟十位
unsigned char cort=0;//判断第几次按下确认键
sbit key_sure=P1^0;//调时或确认键
sbit key_dec=P1^2;//调时减键
bit first_sure=0; //第一次按下确认键
bit second_sure=0;//第二次按下确认键
bit third_sure=0; //第三次按下确认键
bit fourth_sure=0;//第四次按下确认键
bit fifth_sure=0; //第五次按下确认键
bit sixth_sure=0; //第六次按下确认键
bit seventh_sure=0;//第七次按下确认键
unsigned code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};//段码表
/************函数声明*************/
void shannum_jian(void);
void inc_key(void);
void dec_key(void);
void dis_dingshi(void);
void hour_shanshuo(void);
void min_shanshuo(void);
void kbscan(void);
void display(void);
void year_joint(void);
unsigned char judgement_leap(void);
void retime_flash(void);
    year_joint();       //调用年各位组合子程序
    if((year_jointed%4==0&&year_jointed%100!=0)||(year_jointed%100==0&&year_jointed%400==0))return(29); //是闰年二月29天
    else return(28);    //是平年二月28天
按键扫描子程序
void kbscan(void)
    unsigned char sccode;
    P1=0xff;
    if((P1&0xff)!=0xff)
        //delay(5);
        display();
        display();
        display();
        if((P1&0xff)!=0xff)
             sccode=P1;
             //while((P1&0xff)!=0xff)     //按键后消陡
             switch(sccode)
                case 0xfe:shannum_jian();break;
                case 0xfd:inc_key();         break;
                case 0xfb:dec_key();         break;
                default:                                  break;
确认键按键次数子程序
    cort++;
    if(cort==1)          //第一次按下确认键
        first_sure=1;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==2)    //第二次按下确认键
        first_sure=0;
        second_sure=1;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==3)    //第三次按下确认键
        first_sure=0;
        second_sure=0;
        third_sure=1;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==4)   //第四次按下确认键
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=1;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==5)   //第五次按下确认键
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=1;
        sixth_sure=0;
        seventh_sure=0;
    else if(cort==6)   //第六次按下确认键
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=1;
        seventh_sure=0;
    else if(cort==7)  //第七次按下确认键
        cort=0;
        first_sure=0;
        second_sure=0;
        third_sure=0;
        fourth_sure=0;
        fifth_sure=0;
        sixth_sure=0;
        seventh_sure=1;
void year_flash(void)
    unsigned char i;
    if(third_sure)
         year_thoustore=year_thousand;
         year_hundstore=year_hundred;
         year_decastore=year_decade;
         year_unitstore=year_unit;
         while(third_sure)
            for(i=0;i<18;i++)       //年位不显示,其它位都显示
                year_thousand=10;
                year_hundred=10;
                year_decade=10;
                year_unit=10;
                fen_ge=fenzhong_ge;
                fen_shi=fenzhong_shi;
                display();
                kbscan();
                if(!third_sure)i=51;   //如果不满足立即跳出
            if(third_sure)
                for(i=0;i<18;i++)      //年位和其它位都显示
                     year_thousand=year_thoustore;
                     year_hundred=year_hundstore;
                     year_decade=year_decastore;
                     year_unit=year_unitstore;
                     fen_ge=fenzhong_ge;
                         display();
                         kbscan();
月位闪烁子程序
void month_flash(void)
    unsigned char i;
    if(TR0==0)                                  //为日位润平年二月天数做准备
            day_numo=judgement_leap();
            day_numoo=day_numo;
    if(fourth_sure)
        month_unitstore=month_unit;
        month_decastore=month_decade;
        while(fourth_sure)
            for(i=0;i<18;i++)
                 month_unit=10;
                 month_decade=10;
                 year_thousand=year_thoustore;    //送原始数据避免取到不显示数据
                 display();
                 kbscan();
                 if(!fourth_sure)i=51;
            if(fourth_sure)
                 for(i=0;i<18;i++)
                    month_unit=month_unitstore;
                    month_decade=month_decastore;//送原始数据避免取到不显示数据
                        display();
                        kbscan();
日位闪烁子程序
void day_flash(void)
    unsigned char i;
    if(fifth_sure)
        day_unitstore=day_unit;
        day_decastore=day_decade;
        while(fifth_sure)
            for(i=0;i<18;i++)
                day_unit=10;
                day_decade=10;
                month_unit=month_unitstore;       //送原始数据避免取到不显示数据
                display();
                kbscan();
                if(!fifth_sure)i=51;
            if(fifth_sure)
                for(i=0;i<18;i++)
                     day_unit=day_unitstore;
                     day_decade=day_decastore;
                         display();
                         kbscan();
倒计时位闪烁子程序
    unsigned char i;
    if(sixth_sure)
        retime_ustore=retime_unit;
        retime_dstore=retime_decade;
        retime_hstore=retime_hundred;
        retime_tstore=retime_thousand;
        while(sixth_sure)
             for(i=0;i<18;i++)
                retime_unit=10;
                retime_decade=10;
                retime_hundred=10;
                retime_thousand=10;
                display();
                kbscan();
                if(!sixth_sure)i=51;
             if(sixth_sure)
                for(i=0;i<18;i++)
                   retime_unit=retime_ustore;
                   retime_decade=retime_dstore;
                   retime_hundred=retime_hstore;
                   retime_thousand=retime_tstore;
                   display();
                   kbscan();
        if(seventh_sure)                 //第八次确认键按下,启动定时器,将各位的数据全部弹出,时钟正常显示
            seventh_sure=0;
            fen_ge=fenzhong_ge;
            shi_ge=xiaoshi_ge;
            shi_shi=xiaoshi_shi;
            TR0=1;
小时位闪烁子程序
void hour_flash(void)
    unsigned char i;
    if(first_sure)
        TR0=0;                //关定时器,进入闪烁
        xiaoshi_ge=shi_ge;    //保存时个位显示的数据
        xiaoshi_shi=shi_shi;  //保存时十位显示的数据
        while(first_sure)     //第一次确认键按下,在小时位闪烁
            for(i=0;i<18;i++) //小时位不显示,其它位显示
                shi_ge=10;
                shi_shi=10;
                display();
                kbscan();
                if(!first_sure)i=51;
            if(first_sure)
                for(i=0;i<18;i++)//小时位和其它位都显示
                    shi_ge=xiaoshi_ge;
                        display();
                        kbscan();
分钟位闪烁子程序
void min_flash(void)
    unsigned char i;
    if(second_sure)
            fenzhong_ge=fen_ge;     //保存分个位显示的数据
            fenzhong_shi=fen_shi;   //保存分十位显示的数据
            while(second_sure)      //第二次确认键按下,在分钟位闪烁
                for(i=0;i<18;i++)//分钟位不显示,其它位都显示
                        fen_ge=10;
                        fen_shi=10;
                    shi_ge=xiaoshi_ge;  //送小时个位的原始数据,避免调到小时个位不显示时的数据
                    shi_shi=xiaoshi_shi;//送小时十位的原始数据,避免调到小时十位不显示时的数据
                        display();
                        kbscan();
                    if(!second_sure)i=51;
                if(second_sure)
                    for(i=0;i<18;i++)      //分钟位和其它位都显示
                        fen_ge=fenzhong_ge;
                                display();
                                kbscan();
年位组合子程序
    year_unitstore2=year_unitstore;       //保存年各位数据
    year_decastore2=year_decastore;
    year_hundstore2=year_hundstore;
    year_thoustore2=year_thoustore;
    year_jointed=year_unitstore;
    year_decastore=year_decastore<<4;
    year_decastore=year_decastore&0xf0;
    year_jointed=year_jointed+year_decastore;       //得到年的抵8位
    year_jointed=year_jointed<<8;               //将年的低8和高8互换
    year_jointed=year_jointed+year_hundstore;
    year_thoustore=year_thoustore<<4;
    year_thoustore=year_thoustore&0xf0;
    year_jointed=year_jointed+year_thoustore;   //得到年,需将其进行高8与低8互换
    year_help1=year_jointed&0xff00;
    year_help1=year_help1>>8;                       //得到年低8位
    year_help2=year_jointed&0x00ff;
    year_help2=year_help2<<8;                       //得到年高8位
    year_jointed=year_help1+year_help2;         // 得到年位
    year_unitstore=year_unitstore2;
    year_decastore=year_decastore2;
    year_hundstore=year_hundstore2;
    year_thoustore=year_thoustore2;             //弹出年各位数据
定时器0中断子程序
void timer0(void) interrupt 1 using 1
    TH0=0x3c;
    TL0=0xb0;
    if((++time_num)==20)
            time_num=0;
            ++miao_ge;   //定时一秒到,秒个位加一
当秒个位加到9时进一,
    if(miao_ge==10)
        miao_ge=0;
        if((++miao_shi)==6)
            miao_shi=0;
            if((++fen_ge)==10)
                fen_ge=0;
                if((++fen_shi)==6)
                        fen_shi=0;
                    if((--shi_num)!=0)
                        if((++shi_ge)==10)
                                        shi_ge=0;
                                    ++shi_shi;
                    else if(shi_num==0)
                            shi_num=24;
                                shi_ge=0;
                                shi_shi=0;
                            if(retime_unit==0&retime_decade==0&retime_hundred==0&retime_thousand==0)//倒计时减一
                                 if((--retime_unit)==10)
                                              retime_unit=0;
                                    if((--retime_decade)==10)
                                                     retime_decade=0;
                                            if((--retime_hundred)==10)
                                                         retime_hundred=0;
                                                if((--retime_thousand)==10)
        retime_thousand=0;
                        if((month_unit|0xfe)==0xff)     //是奇数月,日为31天
                                    if((--day_numj)!=0)                        //31天没到
                                                if((++day_unit)==10)
        day_unit=0;
        ++day_decade;
                                    else if(day_numj==0)                        //31天到了
                                                       day_numj=31;
                                                           day_unit=1;
                                                       day_decade=0;
                                        if((--month_num)!=0)                 //12个月没到
                                                            if((++month_unit)==10)
        month_unit=0;
        ++month_decade;
                                        else if(month_num==0)         //12个月到了
        month_num=12;
        month_unit=1;
                                                            month_decade=0;
                                            if((++year_unit)==10)        //年个位是否到9
        year_unit=0;
                                                             if((++year_decade)==10)
        year_decade=0;
        if((++year_hundred)==10)
        year_hundred=0;
                                                        if((++year_thousand)==10)year_thousand=0;
                        else if((month_unit|0xfe)!=0xff)    //是偶数月,日为30天
                            if((--day_numo)!=0)                        //30天没到
                                                 day_unit=0;
                                                ++day_decade;
                            else if(day_numo==0)                        //30天到了
                                       if(month_unit==2)
                                            if(day_numoo==28)
                                                        day_numo=28;
                                                        day_unit=1;
                                                        day_decade=0;
                                        else if(day_numoo==29)
                                                        day_numo=29;
                                                        day_unit=1;
                                                        day_decade=0;
                                                day_numj=30;
                                                   day_unit=1;
                                               day_decade=0;
                                                        month_unit=0;
                                                    ++month_decade;
                                                month_num=12;
                                                month_unit=1;
                                                month_decade=0;
                                                          year_unit=0;
                                                             year_decade=0;
        year_hundred=0;
/*************主程序**************/
void main(void)
    TMOD=0x01;
    TH0=0x3c;
    TL0=0xb0;
    EA=1;
    ET0=1;
    TR0=1;
        kbscan();       //调按键扫描
        display();      //六个数码管显示
        hour_flash();   //调小时位闪烁
        min_flash();    //调分钟位闪烁
        year_flash();   //年闪烁
        month_flash();  //月闪烁
        day_flash();    //日闪烁
        retime_flash();
        dis_dingshi();  //到一秒加一,到一分加一,到一小时加一,到24点清零
2019过年还有多少天.zip (22.81 KB, 下载次数: 42)
ID:449256 发表于 2018-12-18 20:19 | 显示全部楼层
你们都好厉害......
ID:472242 发表于 2019-2-3 21:11 | 显示全部楼层
收下了,很不错的例子
ID:472268 发表于 2019-2-7 00:33 | 显示全部楼层
好的话不多说,收下了你的资料
ID:471066 发表于 2019-2-7 15:10 | 显示全部楼层
棒极了,最好资料
ID:469417 发表于 2019-2-7 21:38 | 显示全部楼层
2019年!好样的
ID:475444 发表于 2019-2-11 13:35 | 显示全部楼层
谢谢分享!实力超强!
ID:478073 发表于 2019-2-19 19:22 | 显示全部楼层
谢谢分享!很好
ID:403303 发表于 2019-2-19 23:56 | 显示全部楼层
等我刷到这个帖子的时候离过年还有  -15  天
