资源全部原创,有任何问题欢迎联系
基于stm32f103r6的pwm输出,再经过RC低通滤波实现正弦波输出,使用protues仿真实现
仿真文件
示例代码
- #include "pbdata.h"
- u16 fre;
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void TIM3_Configuration();
- void Delay (uint32_t nCount)
- for(; nCount != 0; nCount--);
- int main(void)
- u16 arr=42000;
- u16 led_dt = arr/2;
- RCC_Configuration(); //系统时钟初始化
- GPIO_Configuration();//端口初始化
- TIM3_Configuration(arr);//定时器和pwm配置
- while(1)
- TIM_SetCompare2(TIM3,led_dt); //用的是TIM3的通道2,输出PWM 送到相应的寄存器中 //满占空比为900
- GPIO_SetBits(GPIOB,GPIO_Pin_5); //LED 发光
- Delay(0x2ffff);
- GPIO_ResetBits(GPIOB,GPIO_Pin_5);//LED 熄灭
- Delay(0x2ffff);
- // if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7)== Bit_RESET)
- // //LED 发光
- // GPIO_SetBits(GPIOB,GPIO_Pin_5);
- // else
- // //LED 熄灭
- // GPIO_ResetBits(GPIOB,GPIO_Pin_5);
- SystemInit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);//这个是必须的,仿真软件必须的
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//端口复用,一定在APB2的时钟线
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
- GPIO_InitTypeDef GPIO_InitStructure;
- //PWM
- GPIO_InitStructure.GPIO_Pin= GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //通过PWM控制,端口为复用方式输出
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- //LED
- GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB,&GPIO_InitStructure);
- //BUTTON
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPD;
- GPIO_Init(GPIOC,&GPIO_InitStructure);
- void TIM3_Configuration(arr)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
- TIM_OCInitTypeDef TIM_OCInitStructure; //PWM的结构体
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE);//TIM3 复用功能部分映射,可以此找到对应的管脚
- //关于部分映射可以参考“STM32参考手册”119面
- //定时器初始化
- TIM_TimeBaseStruct.TIM_Period=arr;//初值
- TIM_TimeBaseStruct.TIM_Prescaler=2;//预分频
- //不分频,在晶振为72MHz的情况下,定时器执行到899后即会溢出,表示计数满
- TIM_TimeBaseStruct.TIM_ClockDivision=0;
- TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;//向上
- TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStruct);
- //pwm初始化
- TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1; //使用模式1
- TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; //使能位
- TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High; //设置输出极性,一定注意
- TIM_OC2Init(TIM3,&TIM_OCInitStructure);
- TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable); //与装载使能,不会说执行一次后就不执行了
- TIM_Cmd(TIM3,ENABLE);
- /*PWM不是中断,所以不需要设置中断优先级 */
Keil代码与Proteus8.8仿真下载(注意要是用Proteus8.8这个版本,其他版本可能会出现异常):
protues仿真stm32f103输出PWM.7z
(241.15 KB, 下载次数: 878)
